05-02-2014, 10:15 AM | #151 |
The 7163 is the first of the B1 framed models to come in a twin scroll iirc. So they would need new castings for that but not the single scroll.
My S13 SR Street Mod Build |
05-04-2014, 07:04 AM | #152 |
Considering the exhaust hits the turbine at a 45* angle vs the standard 90*, I don't think it's as easy as machining out the same housings.
05-05-2014, 04:04 AM | #153 |
I could be wrong, but I think the turbine volute is the same, and all the "magic" is in the geometry of the turbine blades.
05-05-2014, 07:40 AM | #154 |
Def is correct, the mixed flow turbine wheel uses the same volute as a radial flow turbine wheel. the "tip shape" and "blade contour" are what makes this wheel design so unique
05-05-2014, 03:25 PM | #156 | |
Ahhh interesting.
05-07-2014, 01:17 PM | #157 |
More people with 7163's are slowly rolling in...
http://www.iwsti.com/forums/gr-membe...-many-wow.html Listen to the induction sound, the turbo basically is always spun up. Also keep in mind he's at 1 mile elevation. Quote from the owner: "damn thing wants to spool so early literally any time you are above 3k rpms in any gear the car will want to generate 3-5lbs of boost instantly with the lightest of throttle inputs... It's fun and pretty zippy, can you believe this same car was at 608whp before? In the end the trade off from horsepower to spool was worth it."
05-07-2014, 02:17 PM | #158 |
^^ Actually, some of that sound at the beginning is the dyno rollers and not the actual turbo on boil
I like the dyno graph. But a little biased in spool since those scoobys are a 2.5 liter bottom end (although the heads are not the best flow wise). |
05-07-2014, 02:29 PM | #159 |
They actually don't spool up turbos much faster on the average dyno pull than an SR. They have so much piping length that the difference between a run immediately following another, and one 30 seconds later can be on the order of 5-10% of spool RPM. They have that much heat loss before the turbine unless everything is close to steady state.
Their heads do suck something fierce as well when it comes to flow.
05-07-2014, 02:33 PM | #162 |
Yep, but if you listen closely you can hear the turbo whistling over it. Even just on light throttle, you can hear the whistling pick up quickly.
05-08-2014, 01:18 PM | #163 | |
I wish they made something in between the 7670 and 8374 with MFT. that would be an awesome turbo.
http://zilvia.net/f/sale-items/25429...-maf-more.html |
05-09-2014, 07:11 AM | #164 |
8374 to 7163 is a big jump. my twinscroll 8374 spools identically to a singlescroll gt3076R, and while that is incredible and allows me 700+hp worth of airflow, ~500 on the top end but spooling 1000+rpm earlier is very hard to argue with... plus it will roast all (4) tires more easily. Im not into highway or drag racing anymore and really just want my evo to have a "response monster" type powerband. the chassis and differentials are sorted and it slides very predictably so i look at this as a powerband that's more fun. I think these guys putting big singlescroll turbos on their evo's are nuts 6466, 6766, hta37, etc for dyno # and drag racing gets old to me
aluminum CHRA is only for the 7163 at this time. We are still hearing from many installers who can not or dont want to connect water lines -- the steel center section is crucial for these installs (obviously the alu needs to be watercooled). Ive requested that they extend the alu option to the largest/heaviest EFR first (9180 and 8374) and we expect that option to become available around SEMA later this year as for the larger dia MFT rotor option on a B2 EFR turbo, its been discussed. Based on the results we're having with the 7163 we know there is potential for something like that, but in the lab it appears the 7163 is sort of a "sweet spot" for that blade design. There is some interest amongst the team to try out a couple other technologies, but the existing B2 turbos perform *so well* in the lab its pretty hard to top right now, so it remains to be seen what will eventually get approved and make it to market. More than likely it will be 2 years away... the good news is these guys are working on EFR stuff for 8-10 years from now already too, they are committed for the long haul |
05-09-2014, 03:37 PM | #165 |
Now they just need to work on their production capacity and being more turbos to the market!!!
05-20-2014, 12:10 PM | #166 |
Here's some footage of the 7163 equipped Jager Racing STI at Road Atlanta. Skip to 2:05 for the good stuff. Notice how quickly he's back in boost after a shift and when he's coming out of a corner too. The moment after you hear the RPM pick up, you hear the turbo too.
06-11-2014, 01:42 PM | #167 |
hey guys - just wanted to bump this for anyone looking for a 7163, we have them in stock as twinscroll IWG and vband EWG. im planning to spend my july 4th weekend putting one on my evo
06-16-2014, 02:20 PM | #168 |
More dyno results coming out of the 7163!
Green is the stock turbo and red is the 7163. 557wtq / 535whp is what it came up with and much much more area under the curve than the stock unit. Some bad new tho, I'm not the first autocrosser with a 7163 now, he's even in my class too...
06-17-2014, 06:53 AM | #169 |
That's a pretty tasty dyno. Looks like full boost around 3.7-3.8k, and very high boost at that.
Sounds like an SR with a twin scroll and more heat delivered to the turbine can do ~25 psi around the 3.8-4.2k RPM range depending on a few different factors.
06-17-2014, 02:23 PM | #170 |
fyi - that chart is the singlescroll vband 7163. they will try a twinscroll at the end of this season, I suspect it will spool 400rpm quicker but lose ~30whp on the top end. we will see..
07-02-2014, 03:48 PM | #174 |
Here's a nice quarter mile run in an STI equipped with a 7163. Doesn't show off the transients where the EFRs really shine, but still a good video.
07-02-2014, 05:24 PM | #175 | |
Put there by the manufacturer? say it aint so!!! "Integrated compressor recirculation valve (CRV) to help avoid compressor surge and backflow during a throttle lift event." |
07-02-2014, 08:51 PM | #176 |
07-03-2014, 12:54 AM | #177 |
Nope, try mid-high 10's. He ran a 10.70 at 131.39 mph (It's in the title of the video btw...)
07-04-2014, 11:45 AM | #178 |
07-05-2014, 12:37 PM | #179 |
FInished.......Dyno results coming after this wed. EFR 8374 Dual Turbosmart comp gate 40's Turbosmart upgraded BOV (not sure if it'll even perform better than the recirc) And All Powered by Flex fuel E85. 4" straight through exhaust...should give me something exciting!!
IG:@AAPARKAH #ThisIsTheWolf |
07-12-2014, 03:52 PM | #180 |
Had to cut the session short due to an obvious over boost problem. But man this turbo is an incredible piece of engineering.
