05-04-2010, 01:31 PM | #151 |
Measurement pics, may help people.....I think this is with a regular V44 Tial (old design, new ones like 1 inch shorter or so (MV-R)....
VWvortex Forums: T25-EWG-44 housing
Daily driven |
05-06-2010, 07:16 AM | #153 |
To be honest, that lools cool and all, but those pipes are TINY and have GOT to be putting a lot of backpressure on the system.....
Daily driven |
05-25-2010, 02:26 PM | #155 | |
waiting to see if there are no clearance issues w/ the MVR! im thinking about the same setup Last edited by drag113; 05-25-2010 at 02:29 PM.. Reason: mistke |
05-25-2010, 09:44 PM | #156 | |
Trader Rating: (58)
Feedback Score: 58 reviews
EH for 200 bucks seems like an awesome deal, but something seems 'a miss' here.
05-25-2010, 09:49 PM | #157 | |
Trader Rating: (58)
Probably cheaper to run a 38 off th emanifold and save the multiple pieces
05-25-2010, 10:44 PM | #158 |
05-26-2010, 07:24 AM | #159 | |
No. Also, due to the design of the manifold, it is nearly impossible to get more than an inch or two into each runner before it bends beyond the point where you could ever see what you are doing. Porting/polishing the openings could help a bit, but is nowhere near as good as the EH. If I were a baller I would do the EH, but I just can't justify the $600-$700 for that and the swain-coat right now. That is something i would do if everything else was working at it's optimum and I wanted that last little bit of an edge. ....or if the price was lower haha
Daily driven |
05-26-2010, 12:26 PM | #160 | |
05-30-2010, 07:37 PM | #161 |
Sry guys its been a while, I was in the field for a little over a week for some training and i also Purchased an Evo VIII the other week, thats why it was put on hold for a little bit. Im going to use the Tial V44 but it will have a 90* bend from the turbine housing, supposed to get that done sometime next week from the local muffler shop along with the Cutout & bung for the AIT sensor on the IC pipes. Then from there it will hit the dyno.
The only thing i know got done from last time i posted was the Ait sensor, boost solenoid, and Map sensor were pinned into the harness and the fuel setup is finished i will post pics of that as soon as the pics get e-mailed to me. |
05-30-2010, 10:57 PM | #162 | ||
Trader Rating: (58)
Coming back from an exercise is always fun...but exhausting!
05-30-2010, 11:29 PM | #163 | |
05-31-2010, 07:07 PM | #164 | |
800 hp cars of course don't use the stock mani, bc with THAT much flow, it is restrictive. However, for a 2871R, the stock manifold is right at the limit of the "break even point".... For smaller turbos, going with a tubular is just stupid, bc it steals so much torque and the turbo can't flow up top itself anyway. For larger turbos 30R and up, the stock manifold IS restrictive, and you should use a tubular and it's better up-top flow properties to match those of the turbo. Time and time again, we have seen that the best "area under the curve" dyno sheets on cars with 2871R on and SR come with stock manifold.
Daily driven |
06-01-2010, 01:49 AM | #165 |
What if the 2871R had a T3 housing instead of a T2, would it still be better to go with a cast-iron manifold, or would a tubular manifold be better. I only ask this question because i have only seen one person run a T3 housing and they didn't post up much info on it.
P.S. sorry for the thread jack, and i cant wait to see some dyno numbers =) |
06-01-2010, 06:35 AM | #166 |
I wonder if the higher velocity of exhaust gas flowing through the stock manifold would spool faster than slower exhaust gas moving through larger runners of an aftermarket tubular manifold.
06-01-2010, 08:18 AM | #167 | |
Yes, of course.
Daily driven |
07-03-2010, 01:35 AM | #169 |
i am also interested to see if that T04e housing clears the stock manifold... i have a tial bov and it causes surge at part throttle.... a good solution would be the ported option on this housing
07-03-2010, 05:05 AM | #170 |
07-03-2010, 06:24 AM | #171 | |
Not my motor but here is a clearence pic, hope this helps Well i decided to keep the setup i had for sale but now im keeping it to drive on with this because i dont want to let you guys down and have an unfinished project. My friend was supposed to get an angle welded but i guess he is too lazy or something, i keep getting the next week thing week after week so im just going to have my wife bring the V band flanges to the muffler shop to get a 2"X2" 90 bend made so this can get finished already, im pretty sure i can net somewhere around 450whp on a dynojet with this from the reasearch ive been doing. I just need to have the BOV flange welded on the new 3inch alluminum pipes and it will pretty much be done. i really just dont like posting on this thread unless i have updates. sorry guys. |
07-03-2010, 06:47 AM | #172 |
Are you still overseas? This is taking FOREVER!!!!!!!
AND I never got to see the fitment of that special turbine housing on the stock manifold.... BOOOOOOOOOOOOOOOOOOOOOOOOOO
Daily driven |
07-03-2010, 06:57 AM | #173 | |
I think my friend is too lazy to test fit it with the stock manifold, i cant even get him to mock up the intercooler pipes. |
07-04-2010, 12:31 AM | #174 | |
I haven't seen this work, but I'm sure I can make it work! I already solved my creep problem, but I wanna run an external! I don't want to change it to much (350 setup), I'm a superstitious personality. So I can bolt this on, and if it fails, Only I would know :evil laugh:
07-19-2010, 01:38 AM | #175 |
Ok guys got pics and just about everything is installed except the blow off valve and it needs some aluminum welded, the injectors and ss lines are finally on, this is real close to hitting the dyno.
After the dyno i will install coilovers, wheels and the Origin kit i already have. |
07-19-2010, 07:40 PM | #176 |
i would check those wirings by the hot pipe outlet just after the turbo....and as far as teh larger cold side to smaller hot side...dont you lose about a 1 or 2 or more PSI through the intercooler? and if soo wouldnt you just do a slightly larger hot side with a slightly smaller cold side to keep velocities up......wicked kool thread cant wait for you to be done wit it...and see how long youve been driving on it for...i deff want this turbo setup done on my 240 and pushing over 400whp on my KA-T setup with reliability and lasting....i would also wanna push it in the 7000 rpm range but im not too sure it would be able to flow for that and make power....any comments on that felow zilvians???....
07-19-2010, 10:10 PM | #177 |
The car is at GATO Performance Shop right now getting some work done to it and it will get picked up in the morning and i will provide the wastegate setup along with other goodies that ae getting done.
07-20-2010, 12:07 AM | #178 |
Thought this picture looked familiar, it's mine . That's a GT2876R and it clears, but only if you grind off some material from the motor mount bracket, just so there's no confusion here.
