Old 08-31-2010, 09:14 AM   #151
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
FML!!!!!!!!!!!!!!!!!
so lifter are bled and installed went to put the cams in....and the number 2 exhaust cam cap hole decided to be a little bitch and all the fucken threads pulled out...lovely....just my fucken luck.....
so i decided im tired of this shit!!! gonna buy another motor stick it in get the car running for now....take the old one out and take the head to a machine shop to see if it can be repaired...if not source another head...and build the PISS out of the motor...
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 09-03-2010, 04:43 PM   #152
japslapsilvia
big thanks to Robert at Zerolift auto lab!
got this on the way......
Old 09-03-2010, 06:42 PM   #153
Fender Defender
Fender Defender's Avatar
Fender Defender is an unknown quantity at this point
damn man this is a really sick build!!! keep up the good work
Fender Defender is offline   Reply With Quote
Old 09-03-2010, 06:54 PM   #154
g0dzuki
g0dzuki is an unknown quantity at this point
damn this is a fresh build
goodluck
g0dzuki is offline   Reply With Quote
Old 09-03-2010, 10:15 PM   #155
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
awesome build...
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 09-04-2010, 10:06 PM   #156
kalypso123
(ノಠ益ಠ)ノ彡
This is so mean... I hope the flares get swapped for D-MAX OVER FENDERS :[]
Old 09-26-2010, 09:34 AM   #157
japslapsilvia
Thanks!!
so before i put my motor in i decided that i would start doing a wire tuck and brake line tuck.
Harness all layed out removing tape etc
here is another harness i have that i was using for some refrence since somone has my FSM atm
here it is all laid out. removing some circuits that i do not need
here is the bundle of wires that will still have to run to the engine bay
here is the mocked up length (the big loop on top will be cut out)
so i will only end up cutting and shortning about 28 or so wires, everything else has to be extended to the engine compartment.
The final location of the fuse and relay box will be in the Glove box
just have place an order for a few things and i will have everything i need to do my brake line tuck as well
Thanks!
Old 10-07-2010, 07:18 PM   #158
japslapsilvia
ok so wiring is now cut to length..
all joints have been soldered and heat shrinked...all that it left to do it install and test..
also got all this shit form summit racing..
drilled 2 holed in firewall for bulkhead fittings
then ran 2 SS lines from BMC via banjos to bulkhead
from there it will go to hardline to the other side of firewall. then 1 ss line to passenger caliper and a hard line to rear stock brake union.
the front Driverside gets 1 SS line from BMC to caliper.
THANKS!!!
Old 10-07-2010, 07:41 PM   #159
Edwin562
Edwin562's Avatar
sexy build
Old 10-12-2010, 10:29 AM   #160
japslapsilvia
Originally Posted by Edwin562 View Post
sexy build
Thanks!!
does anyone have a solution to flare 3/16ths SS line, im needing to put in a 37 degree flare in it and i cant seem to get it to work.
whats happening is the tubing is being pushed down rather then being flared. also the die on the tool has also been damaged from the tubing. the tool it a summit racing peice..(POS!!!!) so do i need to get a special 37 degree flare tool for SS line?
also i read that i shouldnt be using a regual tuding cutter for SS tubing...somthing about cutting it cold n making the material super hard to flare.
do i just need to dtich the SS line infavor for regual steel brake line???
Thanks!!
Old 10-26-2010, 11:14 AM   #161
japslapsilvia
got the wiring harness in the car and starting the lay-out
final location of fuse box and relay box will be in the glove compartment
Thanks!!
Old 10-27-2010, 11:53 AM   #162
japslapsilvia
got the passenger side brake lines done. Braided SS for front pass side and a custom hard line for the rear
and the lines runnin across the inside of the firewall
also got dash bar installed and set up routing of the main harness and dash harness..
Thanks!!
Old 10-27-2010, 12:28 PM   #163
Edwin562
Edwin562's Avatar
u really like green dont you??? lol
Old 10-27-2010, 08:25 PM   #164
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Green is for money!
jdm2191 is offline   Reply With Quote
Old 10-28-2010, 10:22 AM   #165
japslapsilvia
not really but it beats rusty metal look lol
Originally Posted by jdm2191 View Post
Green is for money!
yea this^^ LOL!!!
Old 10-29-2010, 04:18 PM   #166
pahaf
pahaf is an unknown quantity at this point
green looks sweet. lol
pahaf is offline   Reply With Quote
Old 10-29-2010, 07:07 PM   #167
miller1775
miller1775 is an unknown quantity at this point
looking good man, hope she works for i feel your pain on the money spent haha its a bish but a hell of a time doing it.
miller1775 is offline   Reply With Quote
Old 10-30-2010, 01:34 PM   #168
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
Love this build, all ss lines? Hella dope!
daftphunk is offline   Reply With Quote
Old 10-31-2010, 08:50 AM   #169
japslapsilvia
Thanks!! its my inner farm boy screaming out..LOL!!!
Thanks man!! thats just about it....its one hell of a time!!
yes sir.. for the most part all SS lines..
pulled out the red-top out..
n my good friend felix "da cat" "el Gato" getting ready to man handle the motor in
good job felix!!
Thanks!!!!!
Old 11-01-2010, 06:17 PM   #170
Jimbo_Moone
Jimbo_Moone's Avatar
Jimbo_Moone is an unknown quantity at this point
hey man, sooper sweet build. I have an odd question for you, what kind of flares are those? if you mentioned it earlier i am crazy sorry, but I was temporarily blinded by the amout of awesome
Jimbo_Moone is offline   Reply With Quote
Old 11-01-2010, 06:34 PM   #171
Chaw wee
Chaw wee's Avatar
Chaw wee is an unknown quantity at this point
Loving this build!
Chaw wee is offline   Reply With Quote
Old 11-01-2010, 07:07 PM   #172
Bubba Chaos
Bubba Chaos's Avatar
Bubba Chaos is an unknown quantity at this point
Really like to do my own wire tuck but everytime i see the mess that comes along with it.. I always change my mind haha... Good build though anxiously waiting updates..
Bubba Chaos is offline   Reply With Quote
Old 11-02-2010, 09:03 AM   #173
japslapsilvia
i origionally got them from ebay, but they came from http://www.driftlines.com/ the site is down i bought them a few years ago.
Originally Posted by Chaw wee View Post
Loving this build!
Thanks!!!!
its really not that bad...it does looko intimidating but as long as u have an FSM and take ur time its pretty straight foward.
will have more updates this weekend
THANKS!!!!!!!!!!!!
Old 03-11-2011, 11:17 AM   #174
Andrew@9K
Andrew@9K's Avatar
Andrew@9K is an unknown quantity at this point
This is awesome I love the work you did with your brake lines! AHHH I want
Andrew@9K is offline   Reply With Quote
Old 03-28-2011, 07:22 PM   #175
KingMidas
KingMidas is an unknown quantity at this point
Nice build. Keep it up
KingMidas is offline   Reply With Quote
Old 03-29-2011, 09:57 AM   #176
japslapsilvia
Thanks man!!!! its actually a very simple setup that mimics the stock lines. just behind the firewall.
thanks!
i am actually trying to get some updates and get the car running but am running into a few issues is anyone cares to chime in
http://zilvia.net/f/tech-talk/375592...-tach-fml.html
Thanks!
Old 03-29-2011, 10:48 AM   #177
two40guy
two40guy is an unknown quantity at this point
fucking BALLER.
two40guy is offline   Reply With Quote
Old 03-29-2011, 10:57 AM   #178
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
i like the brake bulk head fittings.. thats real similar to how i plumbed my hydro ebrake.. i want to redo it with the steel braided lines and replace the front passenger brake line as well...
nice job
Black240Ct is offline   Reply With Quote
Old 03-29-2011, 11:50 AM   #179
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
I like how this whole build was thanks to a leaky gas tank haha it only took 4 pages to finally get it back in!
"I am not good English, I like the drift"
CHINA DRIFT
"some guys have a better relationship with their car than their wife haha. sad but true."
SECRET SOCIETY
holybushoffire is offline   Reply With Quote
Old 03-29-2011, 12:28 PM   #180
nikkisixx69
nikkisixx69's Avatar
nikkisixx69 is an unknown quantity at this point
this gonna be seriously bad ass when its finished!
on s-body no.4!!!
nikkisixx69 is offline   Reply With Quote
