#17851 |
YO
whre can i find these tail lights? ![]() look closely at the lens. It is molded like the OEM tail lights. I realize the lens is not usually transparent red. Yes, i've looked on eBay.
#17852 | |
![]() Join Date: Oct 2013
#17853 |
![]() Join Date: May 2013
Okay, I have been wondering this for a while now. USDM has a different rear bumper than the JDM S14 kouki rear bumper correct? If so, whats the major difference between the two?
Thanks. |
#17856 |
Which oil feed lines work for a KA24DE Bottom Mount ISIS T28? Should I use the S13 or S14 SR20DET variant (Only for SR20DET lines)? If it makes a difference I have an S14 KA24DE.
#17857 | |
#17858 | |
![]() Join Date: Jun 2009
![]() Feedback Score: 11 reviews
http://www.jgstools.com/turbo/
#17859 |
hey, im new here so im not exactly sure if this counts as a small question, but ive been looking for a s14 preferably a kouki, but i haven't been able to find one, if someone could help me out that would be great thanks
#17860 |
#17861 |
![]() Join Date: Dec 2012
Trader Rating: (22)
![]() Feedback Score: 22 reviews
So I'm having an issue removing my oil pressure switch. I can't fit a socket onto the switch because there is a tube leaning right onto it. I unbolted the tube but it's not moving. It seems like I need to remove the alternator just to remove that piece so I can unbolt the switch. I did search but no thread mentioned an issue like mine
#17863 | |
#17864 |
s15 interior lights to and s14?
Hey guys. Was wondering whether the Interior lights from the s15 roof will fit in an s14 roof and roof liner? I was wondering whether the units are relatively the same dimensions and mounting points? thanks
#17868 |
![]() Join Date: Jan 2011
I've seen several post of gen 1 CTS V 4 piston brembos being swapped but can't find any answers
-what brake lines Mazworx bracket uses Evo 8 rotors Ctsvbrakeswap.com bracket uses z33 track rotors I know z32 calipers w/ track rotors clear 17" wheels but will the brembos clear also? Also haven't been able to find any write ups |
#17869 |
Okay, so I'm rebuilding my ka24e, keeping her stock. I'm stuck on my pistons though, namely the wrist pins. The ones I received seem to be a press fit but the ones I've removed from my car have snap rings holding the wrist pins in. Is that going to cause any problems if I install these or should I just clean and reuse my old ones??
#17870 |
What female plug does the s13 m/t speed sensor male plug go into?? Having a real hell of a time finding the answer online. Does it use the same female that the a/t sensor utilizes?
#17871 | |
PS. Give me my ID pic back!!
* S14SR22 * 9.0 c/r * GT3071R * |
#17873 |
How do you tell the difference between a rep/fake/knockoff Type X/180SX wing and an authentic OEM Type X/180SX wing through just pictures, without comparing them in person? I know you can simply check the underside of the wing where it mounts onto the trunk, but is this the only way? I've seen pictures of where it's obvious, for example:
![]() But I feel like there are knockoffs that even have the same looking underside (i.e. they have those two circles on the bottom of the wing ends). Should I just trust that if I see one online that looks exactly like the white one in the picture, it is an authentic one? I have been looking online trying to tell the differences between them and I'm not sure how legit some of the current eBay listings are, especially since the OEM wings don't appear to have a Nissan logo on them anywhere. Last edited by tacobellman_2007; 02-10-2015 at 01:29 AM.. Reason: Additional info |
#17875 |
![]() Join Date: Nov 2014
![]() It seems most people who do the VH swap go with a twin turbo z trans, but I'm pretty adamant about having a 6 speed to go with mine. Any suggestions on what would have a good longevity/require least amount of fab and modding?
Thanks |
#17876 | ||
I have been experiencing the same problem, but the one on the right looks like it has factory attachments. I suppose without a brand in the plastic, that is the best way to tell, ask for a photo that show's the bottom of the foot/feet Quote:
I would begin at the fuel pump and work toward the front of the car to the injectors, then from the air filter to the throttle body. My guess is you figure it out by the time you get to the injectors The Z33 trans takes care of the 3rd/4th synchro issue the Z32 trans had. Yes, you will need an adapter, and adapter drive-shaft kit, but you keep your KA/SR clutch and flywheel. This is the same information I have found in NICO, Grassroots Motorsports, and a few other places where guys actually road race, or auto x these cars instead of drift where they are using all the gears and hammering the trans just as hard
#17877 |
Zenki headlight harness has 3 inputs 1 ground, 1 low beam, and 1 high beam. For the kouki's the connector only has 2 inputs which consists of 1 power and 1 ground right? So if that's the case how do I make that work so my low beams and high beams work at the same time once I activate my high beams?
Also my corner lights are really weird. I have a connection coming out of the kouki corner light but there is not one plug that fits into it (I have zenki harness). The only one that has a direct fit is the kouki headlight low beam connector. I'm confused here because how do I make that work? Only having 1 connector to make 2 lights work? I hope someone understands what I'm saying because I'm confusing myself. By the way I have no knowledge with electrical work. Thank you. |
#17879 |
![]() Join Date: Jun 2011
Is the fwd sr20 alternator hardware/ tensioner the same as rwd? I lost that shit when I moved
zenki time! "Cant buy weed and pussy with disney dollars" |
