12-09-2014, 01:45 AM | #17611 |
Does anyone know if nismo lmgt1 can be reverse mounted? As in the face mounted from the inside of the barrel, instead of sitting on top of the lip.
12-09-2014, 01:31 PM | #17612 |
Trader Rating: (22)
Feedback Score: 22 reviews
I have a graveyard of KA and SR trans that are burnt. I need space in the warehouse... Does anyone know someone who buys cores for stupid cheap? Or are these junk and I have to give them away or throw them out?
Thanks in advance |
12-09-2014, 05:29 PM | #17613 |
Update!
Finally removed the damn screw. I then proceeded to remove the injector and successfully replaced it. The car started as soon as I turned the key, I was excited about that. But with 240's there's always another problem. As I went to back up the car began acting up, the whole car began shaking feeling like it wanted to shut off. The lights dimmed as soon as I pressed the brakes. When I hit the gas pedal the car had a strange sound, it sounded like it didn't have any force to it. The sound was weak, which never happened before. There is NO idle issues by the way, it's just the car feels weak. Fuel pump works, as I can hear it. I think it might be fuel related but I'm not sure. I checked all the lines, no vacuum leaks. Already checked the brake booster, looks fine. Things I did recently to it: Fuel filter Spark plugs Spark plug wires Fuel injector (cylinder 2) Thank you. |
12-09-2014, 09:23 PM | #17614 |
Bandwagon.
might be a vacuum leak where the booster connects to intake manifold? I had that prob last time didnt detect it with brake cleaner but it def was hard and cracked.
12-10-2014, 02:51 PM | #17616 |
Trader Rating: (31)
Feedback Score: 31 reviews
Ok someone please clarify. ARP sr20et flywheel bolts, torque specs? I've searched so many different sites. I have the assembly lube from them as well. I've seen:
Factory 94-101 70 60 50 Where the fuck do I need to torque them? Threads I searched ranged 2007-13. I want to obviously make sure they're where they need to be and not be too tight. Sent from my iPhone using Tapatalk |
12-10-2014, 03:06 PM | #17617 | ||
* S14SR22 * 9.0 c/r * GT3071R * |
12-10-2014, 03:10 PM | #17618 |
This was answered, but if you are using a compression tester and it isn't sealed correctly, it could show low compression.
12-11-2014, 03:58 PM | #17620 |
12-11-2014, 04:40 PM | #17621 | |
AFC #1
WTF are you talking about?
12-11-2014, 08:01 PM | #17622 |
I seemed too have stated my response so poorly that it didn't even make sense. I was just saying the fender are different because for one the corner lights (the cutouts for them I didn't really know another way to describe it) don't fit in the opposing models fenders. Sent from my iPhone using Tapatalk |
12-12-2014, 11:25 AM | #17624 |
Hey guys, I've some questions about replacing engine mounts.
1. in what order do I remove and replace the engine and tranny mounts during the repair? 2. what are the trq specs for the engine mount bolts.. I tighten them up, drive the car for a while then re-tighten them some more after the engine has settled? 3. is it safe to jack the engine up from the PSpump bracket and alternator bracket? thanks. |
12-12-2014, 11:32 AM | #17625 | |
They did not modify a zenki bumper. Zenki bumper has nothing in common with JDM/USDM kouki bumpers except for marker and turn signal lenses. They modified the JDM bumper to retrofit zenki lights in it for USDM front ends. The other issue one will run into on JDM vs USDM fitment is on some plugs for side marker lights, corner lights, turn signal lights and in some cases headlights. IF you convert to a JDM kouki front, make sure you get the harnesses too so you can rewire the plugs to function correctly at each light position. When upgrading your zenki to kouki tails, JDM will need to have plugs rewired as well in many cases. USDM kouki tails should have no issues, BUT may if it is a early year model
12-12-2014, 11:53 AM | #17626 | |
2. German-spec: guten-tight. 3. I'm sure using the PS pump and alternator bracket is fine but I've used the oil pan with a floor jack/wood block without issue. Just don't go too crazy jacking the engine up and keep double checking you aren't ripping wires or what not. Remember, the wider the block of wood the better. The wood isn't used because it's softer, rather to spread the load. |
12-12-2014, 12:01 PM | #17627 |
Ever since I installed an Aem short ram on my stock ka it randomly hiccups but then runs normal. I also noticed hesitation on medium pulls. Sometimes when cruising it will lose all power and eventually stall(stalls if I turn it on normally, but if I keep the revs up during start it will run fine after that). ecu reads knock sensor and maf. '93 hatch
Has anyone had this problem? Figured id ask before i start buying unnecessary parts. THANKS! stuff replaced or fixed: -fuel filter -cap and rotor -loose vacuum hose clamp -cleaned maf sensor unplugging the maf does not stall the car. |
12-12-2014, 12:01 PM | #17628 | |
AFC #1
12-12-2014, 12:17 PM | #17629 | |
Thank you for the quick reply,man. I appreciate it. ..and yeah I might as well replace the tranny mount while I'm at it. |
12-12-2014, 01:12 PM | #17630 |
Is there a difference in 180 and 240 front finders? will a 180sx front bumper bolt up. Other than the lighting situation.
12-12-2014, 03:58 PM | #17632 | |
When I replaced my mounts for Nismo ones. All the write ups/ how to's I've read said it was just a matter of jacking the engine up enough to pull them out.... well, that didn't work for me.lol. I ended up raising it to the point that the car would lift off the jack stands. So, I ended up removing the mount's bracket, off the engine block. WAY EASIER.(for me anyways) . . . Oh, and I too used a block of wood.(oil pan, AC mount & alt worked) Sent from my MB855 using Tapatalk 2 |
12-12-2014, 06:07 PM | #17633 | |
Trader Rating: (31)
Any one else have input? Have yet to hear back from ARP Sent from my iPhone using Tapatalk |
12-12-2014, 07:53 PM | #17634 |
SR20 Red Top overboosting but still feels sluggish
Gauge will read levels way past 7psi if I continue to mash the throttle but yet the car doesn't pull... I've looked online for weeks and found nothing Help me pleaseeee |
12-13-2014, 08:03 AM | #17635 | |
The only two things left in the equation to replace the injectors and O2 sensors. OE is very small at 350cc~. You can go up to 550cc on a stock or basic stock tuned ECU If you are unplugging the MAF, you may want to try replacing the upstream and downstream O2 sensors
12-13-2014, 10:13 AM | #17637 | |
AFC #1
OP needs to get a multimeter and read Ignition on and idle voltages at the maf.
12-13-2014, 10:34 AM | #17638 | ||
Hmm, that's actually a good idea. I'll try it. Quote:
Ok guys, I have some followup questions. so.. I went down to autozone and got some Duralast OEM mounts but they only offer the L side mounts. I assumed the mounts were basically the same for both sides so I ordered them. Now that I have them in my hands I can see that they look completely identical. but.... aren't they actually supposed to be mirror opposites instead?? should I just return these and go to my Nissan dealer? |
12-13-2014, 11:55 AM | #17639 |
2 small questions
1. What o2 sensor does a j4 ecu use? Having funny idle issues only with it plugged in. I think i may have the wrong one. 2. What boost will a s15 spec r dbb turbo hold? On my stock redtop im kind of disappointed because it spikes to 17 but lowers down to about 13.5 by redline |
