10-03-2014, 04:12 PM | #17311 | |
10-04-2014, 04:21 PM | #17314 |
I bought an s14 and it came with an aftermarket steering wheel. Luckily the guy gave me the oem steering wheel.
I tried looking around the site and other various sites but I couldn't find out if installing the oem steering wheel was the same as installing an aftermarket steering wheel. Obviously, the difference between the two is that the oem has airbag. But, I need to know if it is a simple task to complete. Thank you. |
10-04-2014, 04:57 PM | #17315 | |
10-04-2014, 05:40 PM | #17316 |
I'm wondering if I can take my parts car dash out as one piece by just unbolting the dash bar from the car and unplugging everything and removing it all at once (radio, a/c controls, etc.) without taking it apart in a million pieces, then putting it back like that, but in my car.
10-04-2014, 06:23 PM | #17318 |
Just installed a new control arm everything had to be taken apart and retightened including the tie rods/tension rods and swaybar ends, but when put back together and if I turn slight left it makes a clunk sound. If I turn all the way left or even right it makes no sound at all only if it is slightly left it makes a clunk sound could this be a sign of over tightening something like the tie rod castle nut?
10-04-2014, 06:44 PM | #17319 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
10-04-2014, 09:16 PM | #17322 |
Does anyone know the difference between the 2 HKS wastegate actuators on frsport for the S15 turbo? There's one that's purple that cost double what the silver one costs. Is the purple one just fancier? As always any help is appreciated! Thanks guys!
10-04-2014, 10:55 PM | #17324 |
10-05-2014, 10:25 AM | #17325 |
Coilovers make noises sometimes if there is too much preload. The spring binds up because there is nothing allowing it to rotate/articulate. Not sure what type of coils you have.
10-05-2014, 01:04 PM | #17326 |
10-05-2014, 08:16 PM | #17328 |
Hey I didn't want to start a new post for this dumb question but do you guys have any horror stories with the police (mainly LAPD since i live in SoCal) pulling you guys over and making you pop open your hood and seeing your engine swap the reason i'm asking is because I'm debating on getting a SR20 in my car right now or selling it and getting something more modern and reliable. My KA is going to need a rebuild soon and I'm about to smog my car so i won't have to worry about smog for a while.
10-06-2014, 09:53 AM | #17329 |
I think I found out the culprit just haven't changed it yet or replaced it, but on further inspection it seems to be that my sway bar end link has lost one of the bushings and is probably the reason for the clunking noise only on the left side. Will replace them and see if that is the problem or not.
10-06-2014, 05:04 PM | #17330 |
Trader Rating: (22)
Feedback Score: 22 reviews
I've searched and I'm not really getting a definite answer. Hopefully someone will clear it up. I'm planning on using a z32 vlsd in my s14. I want to use the tt model axles aswell but it won't work. From what I read, I have to use two N/a driver side axles to make them fit?
10-06-2014, 09:27 PM | #17331 |
BOV set-up info
So I have a mostly stock 94 Redtop. It has a BOV (idk the brand) venting to atmosphere and I'm having that common problem of running really really rich, car almost dies when going to neutral or after revving the engine and loud backfires.
So my question is how could I recirculate my BOV without having to spend sooo much money? I've searched everywhere for days and couldn't find a good setup for the right amount of money. PS: I still have rubber intake tube. Should I replace? |
10-06-2014, 09:38 PM | #17332 |
I haven't had any problems with my swap and I honestly don't think you will either. Just as long as your not driving like an asshole. Cops will only ask you to pop your hood if you give them a reason too, like having your car gutted (or giving them a reason to believe you use the car for the track
I've only seen one car get towed and that was because he was driving like a dick and he didn't even have a hood covering his 2Jz swap |
10-06-2014, 09:38 PM | #17333 | |
Trader Rating: (92)
Feedback Score: 92 reviews
as with all older engines ... especially ones that you haven't personally maintained .. first would be to change all you vac lines (when's the last time those were changed) if the answer is "idk" most likely it's time to change its fairly a cheap fix to typically a backfire would mean that you have a exhaust leak some where .. so that would probably be you next fix common places (down pipe connector) Sent from my iPhone using Tapatalk |
10-06-2014, 09:57 PM | #17334 | |
Don't you go to Mira Costa ? Hahaha |
10-06-2014, 10:00 PM | #17335 | |
Trader Rating: (92)
lol yes I do white coupe (some of your friends know me (and my car lol) Sent from my iPhone using Tapatalk |
10-06-2014, 11:45 PM | #17337 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
rubber intake tube is fine, just make sure you cap the re-circulation inlet with an air tight rubber plug (i found a perfect one at home depot, was like 3 dollars). if youre using those cheap thin couplers, spend the cash and buy some actual quality and thick silicone couplers from HPS. this also goes for quality t-bolt clamps as well. those autozone screw clamps are garbage! spending the cash on quality stuff to clean up your engine issues helps a ton! buying cheap parts may seem like a good idea at the time, but doing it right the first time and spending an extra $100 is ALWAYS worth it in the long run! |
10-07-2014, 04:10 PM | #17339 |
Do S14 trunks has different bars to close the trunk?
I ask that because I'm trying to install a s14 SE trunk with a wing and it does not close it's too short. Now the weird part is that the trunk I had before had a wing. Reason why I removed it is because it's red so I swapped it out for a black trunk. They both look identical, I have no idea why it does not close. |
