09-26-2014, 12:35 PM | #17281 |
Oil smoke. oil consumption. coolant is fine.
hey i have been trying for about half a year to stop the smoke coming out of my car. im running 10w40 it drops like half a quart of oil every 20 miles so i have to refill after every stop. it smokes up when the oil is low. i have swapped the headgasket with mls and arp studs, i rebuilt my turbo new seals, i have new dual radiator cuz i thought the oil was getting burned somehow, new valve cover gasket, my 3rd cylinder is little less shiny than the other cylinders but its not DIRTY, i put an air compressor on each of the cylinders to check for cracks in the head/block but no bubbles came out of the radiator so i think im fine, my compression is 140 on the front two; 150 on the back two, im replacing the pvc and adding a oil catch can on the left side of the valve cover "T" right now ill let you know if it works, next is the valve stems seals but im not sure if thats the problem. could it be the piston rings?
09-26-2014, 02:10 PM | #17282 |
How long are the m6x1.0 bolts that hold on the sr front cover? Anybody able to measure one?
@UpshiftEngineering |
09-26-2014, 08:19 PM | #17283 |
I was going to say valve stem seals and then you said it at the end... 140/150 seems low.. I would not rule out rings. Do a wet compression test and see what that yields..
09-26-2014, 08:21 PM | #17284 | |
Thanks again. |
09-27-2014, 04:38 PM | #17285 |
Injen cold air intake
I recently installed a CAI on my 1989 240 coupe. The problem is that the MAF sensor is too small and seems to cause a vacuum leak. I tried putting electrical tape around the MAF to make it fit more snug but the tape got hot and kind of fell off. So i was wondering what i could do to make it fit tighter?
09-27-2014, 05:30 PM | #17286 |
Put the factory intake pipe back on because those things do absolutely nothing. Then sell the cai, and treat your lady to a night out or something.
09-28-2014, 08:10 AM | #17288 | |
Import Tuner Magazine, 240SX SE build CAI good for CONSISTENT 8hp, 8#T, GAINS, yes, CONSISTENT GAINS I don't know about you, David, but 8 horsepower, and 8 pounds of torque is not only seen on the dyno, it is noticeable on the ol butt dyno too, and this gain, AS TESTED was AT mid range on the rev. So whoever told you a CAI doesn't do jack, son, you just been schooled with the PROVEN NUMBERS so if you peddle the numbers and accurate info, you will show you CAN be brought out of ignorance, but if you continue to peddle facts that are bullshit opinions, you only show everyone here you MIGHT be stupid. In point of fact, a CAI, Cat back, and ECU upgrade(Nisstune, RS Enthaply, et al) will show a consistent gain of around 18 - 20 hp, or enough to make these little KA's run a 3 series all day long, and make that civic's v-tec look like a wheezing attack To fix your loose connector, try using silicone sealer. You MUST allow the sealer to GAS OUT completely(we call this curing)
09-28-2014, 10:23 AM | #17289 | |
AFC #1
09-28-2014, 03:57 PM | #17291 |
I've got what is probably a dumb question, but I'd like a definite answer before I throw it out. When swapping to manual from auto all the write ups say " unbolt/unplug this for now" when referring to the auto shift control module that is where the clutch pedal goes. They never come back to it. So can I throw it away and tuck the wires up under the dash?
it's a 95. |
09-28-2014, 04:12 PM | #17292 |
Stupid question but just checking my sanity...
S13 handbrake lever sections are longer than s14 handbrake lever sections? I believe I have a s13 handbrake which doesn't fit my S14, the section between the lever and the rear mount where it goes through the tranny tunnel, is too long... I assume its a s13 handbrake lever but not sure... Does anyone know by any chance?
S14 KA NA two cylinders, 75whp limper |
09-30-2014, 06:11 PM | #17293 |
need help got an s13 with a sr20det red top. its runs and idles fine revs up fine with no issues until you drive it has no power at wot until like 3500 rpms it feels like it bogs down. checked timing and chanced the knock sensor and its still doing it,. please help im new to the sr20s
09-30-2014, 06:58 PM | #17294 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
id highly suggest you replace every coupler and clamp with brand new QUALITY silicone couplers and tbolt clamps (i run HPS couplers and tbolt clamps), most of you guys cheap out on some of the most important engine components. screw clamps suck for proper seal and can only be used a few times before they lose their clamping force, tbolt clamps can be reused over and over. cheap and thin couplers cause major problems in that you can never get them to seal properly. a dirty MAF can be the biggest bane to an any SR setup as well. get some b12 out and pull the MAF sensor itself out of the house (2 flat head screws hold it in place). spray it down with B12 carb cleaner a few times and see if that makes a difference. if the 2 wires are dark/black, then grab a q-tip, spray it down with B12 and rub the q-tip against the wires carefully. youd be amazed at what comes off. also, invest in a K&N Air Filter! and i stress this heavily!!! cheap air filters cannot be cleaned and once dirty, start causing all sorts of fun air flow issues to the MAF. the K&N is cleanable and has a great lifespan! also they flow much better than those stupid Spectre autozone specials. A conical K&N only runs like 50-60 bucks, BUY ONE!!! |
09-30-2014, 07:11 PM | #17295 | |
09-30-2014, 07:12 PM | #17296 | |
09-30-2014, 07:14 PM | #17297 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
also, if youre running rich, you have a leak AFTER the turbo... if youre running lean, you have a leak before the turbo (good bit of general information) |
10-01-2014, 05:43 AM | #17299 | |
Code:
Baseline Dyno pull: 120.6hp Aluminum Intake: 126hp 6hp gain DC 4-2-1 Header: 134hp 8hp gain 2.5" cat back: 141hp 7hp gain 232/248 cam swap: 146hp 5hp gain Tuned ECU: 149hp 4.5hp gain Total gain: 30hp
10-01-2014, 09:19 AM | #17300 | ||
AFC #1
10-01-2014, 10:11 AM | #17301 |
Gathering parts to rebuild my SR in the future. Just wondering if this is a good list of components ? If there's more please add or if such a thread already exsist, please direct me in the right direction. The build is going to be mild build ( jwt s3 cams, z32maf, tomei m7960 turbo @ 16-18psi, 740cc inj, etc ) looking for 350whp reliable/daily.
Rebuild components: all parts are new Oem s13 oil pump Oem timing chain kit Supertech valve seals Arp head & main bolts Oem full gasket kit Aem wideband O2 sensor plug Apexi metal headgasket Acl race bearings Acl thrust washers Oem pilot & throw out bearing Spec stage 3 clutch |
10-01-2014, 02:28 PM | #17302 | |
10-01-2014, 06:32 PM | #17303 |
Does anyone know which Subaru sti injectors to get for my S13 SR20DET and where to get them from? And how to get them to fit? The size I'm looking for is somewhere around 550cc's. Thanks to anyone who can guide me in the right direction!
10-01-2014, 06:48 PM | #17304 |
I'm running 04-06 sti wrx side feed injectors. They actually flow 530cc. If you can find a pair with pigtails to wire in that would be best. That's what I did.
DLG - DIRTYLOVE |
10-01-2014, 06:51 PM | #17305 |
Awesome man! You wouldn't happen to have a write up of how to do it would you? Or know where one is? I'm going to join a Subaru forum and see if someone is selling any
10-01-2014, 08:23 PM | #17306 | |
10-02-2014, 03:06 PM | #17307 |
Came into some weird problems installing my control arm on my driver side today. I installed it fine on passenger side, but when installing on driver's side the swaybar end links that connect to the control arm doesn't go in cause it's too high in the air when I connect the control arm to the hub. I don't know why it's so difficult on this side everything just doesn't wanna fit in unlike the passenger side which I had no problems with my swaybar end links going in fine and the control arm fitting perfectly in the hub allowing enough room for the cotter pin to be placed but wouldn't give enough room on the driver's side any idea?
10-02-2014, 10:52 PM | #17308 |
Stock SR....no BOV....no nipple on IC piping for wastegate vacuum line.
So is it okay to have my wastegate line go to the bottom nipple on the TB where the charcoal canister line would go? I keep seeing people say its fine...and people saying not to do it.... ~_~ |
10-03-2014, 08:20 AM | #17310 |
