#15931 |
what weight oil should I be running in my SR20DET?
I've read that the heavier oils help protect the parts where metal touches metal, like on the journal bearings for the rod and what not. The more viscous it is the less likely it is to be squeezed in. But a guy I talked to who is running a 400 some whp SR20DET is running 5w-30 oil with his reason being that it gets to all the parts of the engine much quicker. Reducing the time the engine might run without flow to some parts. What is true? I was running 15w-50 Mobil 1 synthetic for the past seasons with no problems, even the one time it was below freezing out and i had to take my car to work. But this guy is running 5w-30 conventional and has been for 2-3 years now with no mechanical problems. |
#15932 | |
#15933 |
![]() Join Date: Jun 2008
![]() Feedback Score: 11 reviews
About to sell a stock exhaust but I'm having second thoughts after looking at people getting fix-it tickets. It'd be mighty dumb of me to get one after selling a stock exhaust. Any opinions/advice? (BTW I have an aftermarket exhaust in case it wasn't recognized)
#15934 |
Bandwagon.
I've purchased the bride FG rails would i need better seat brackets for a bucket seat? Since i visit the track occasionally or would the ones that come with the FG rails be good enough
I'm getting a recaro profi spg seat. |
#15935 | |
Looking at the OE system from Calsonic sitting on my back 'put it here' spot under the deck, I noted the smoother lines and they way it tucked, and an idea came to mind. Buy the correct bends that are mandrel bent from Summit, get the straight tubes and then a stainless Non Flowmaster dual exit Muffler and a pair of slant tips. The finishing move would be some basic silver ceramic exhaust paint in a basic OE color for a system that would look dead stock with some slightly flashy tips and sound maybe like it was a little worn through, but subtly louder than oe and still meeting the 93dB rule. I have since found an old OBX that meets these requirements and all I need to do is swap out the single exit for a dual exit and it will be louder, run better due to 2.5" and look good
#15936 | |
#15937 | |
![]() Join Date: Jan 2008
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Where can I get nissan front and rear badges for a kouki s13
ಠ_ಠ |
#15938 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Stick with the Mobil1 15w-50. I've been using it for over 5 years which included 2 winters in Idaho and 3 summers in southern Arizona no problems.
IIRC the rear Nissan badge that goes on the hatch is impossible to find now. |
#15940 |
Im trying to restore my rear subframe on my S14.
Is it okay if I rattle can it for the time being, as opposed to professionally painting or powder coating it? Last edited by jdm60; 01-23-2014 at 11:14 AM.. |
#15941 | |
![]() Join Date: Jul 2013
yes painting it would be just fine just be sure your surfaces are clean!! MY QUESTION: is 95 96 zenki oem foglights a good deal for 30 bucks? ![]()
95 S14 se RB25DET 348whp ![]() |
#15944 | |
i bought my spare subframe for 20 bucks! i am refinishing mine also and plan on doing the bushings etc...the typical stuff ![]()
#15945 |
Nice. Yeah I am in the middle of my swap and I want to just get the car running for now, and want to remove any rust from the subcrame but powder coat and painting is a little out of budget now
#15946 | |
#15947 |
Wanted to know if any of you have dealt with Driftworks.com Im planning on buying 18x12 et0 Rota GT-R D's and I wanna know if they are reliable to buy from and if anyone has had any problems with shipping to the US? Get your Rota GTR-D 18" Wheels - All colours from Driftworks.com
#15954 |
Bandwagon.
should be, and s14 also.
#15956 |
Question about a redtop sr20det cam's timing. As long as the colored chain links are on the 2 dimpled teeth on the cam sprocket and the 1 dimpled tooth on the crank sprocket my timing is set right? It's just weird. I have it all set up and I have slack on the tight side and to get rid of it I have to turn the crank a little bit which leaves the head at "TDC" but the crank and pistons at a little past it.
#15957 | |
![]() Join Date: Jun 2013
#15958 |
Hello everyone, I've been having this recent problem with my turn signal switch, whenever i click it left or right it to turn, and whenever my wheel straightens out, it doesnt disengage and turn off automatically.. its not a big problem it just gets annoying having to put it in its neutral position itself. has anyone had this problem? Pms would be much appreciated. thank you.
#15959 | |
AFC #1
![]() Join Date: Oct 2003
Do you have an aftermarket hub / wheel? If all stock ether the cam or the switch is worn out.
#15960 | |||||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Mobile 15w50 is nice, and I used it for years as you couldn't pass up the 5 qt (oil change) jugs at walmart. However about 2 years ago they became harder and harder to find. I then switched to Rotella T6 5w40 and haven't looked back since. Quieter cold starts, better oil pressure on track and better oil pressure in the heat. Not a huge difference, but 5 psi is 5 psi difference (in a good way). Plus, you can't beat the 19.99 price at Advance Auto, and the fact you can get it *anywhere*, from truck stops to mom and pop stores. Quote:
With that said, be sure to have the sliders as straght as you can get them (or even left to right) as they bind easily if not set right. I lube mine up yearly too. Quote:
Front: Upper camber plates, adjustable tension arms, and adjustable tie rod ends Rear: RUCA, and rear toe arm to adjust toe You may even need to slot the lower coilover mounts in the front to get more than 3* Quote:
