Old 03-23-2014, 12:37 AM   #121
ultimateirving
ultimateirving's Avatar
Originally Posted by TheRealSy90 View Post
Yeah I was just thinking, I'm going to get a daily driver before I do the trans swap anyways, so who cares I can just use a gps app when I need it.
Mind if I ask what clutch you are using on your sr? I'll be using an ORC 409D super single. George said someone has used his plate before with that clutch, but not with a internal slave trans. I got the slave spacer and everything so I'm hoping it all works out. Still trying to find a shifter.
dude i have a spare shifter i accidentally ordered 2 so please hit me up for it. ill give you a good price.
and im using my old SR clutch, Spec stage 3, its barely a year old and has plenty of life.
Z32 with lq4 swap
Old 03-24-2014, 09:45 AM   #122
ultimateirving
She is installed. Was a little bit of a pain getting the motor mounts to line up and the trans doesn't sit level until I notch the shifter hole. It's barely hitting. Also did I mention previously I had to grind down the Bellhousing where the elbow touches the would-be starter location on the stock z
Z32 with lq4 swap
Old 03-24-2014, 06:38 PM   #123
crewchief05
crewchief05 is an unknown quantity at this point
Who would everyone who has actually done this swap recommend to get their kit from? George or Collins? No slamming just personal experience.
crewchief05 is offline   Reply With Quote
Old 03-24-2014, 06:57 PM   #124
ultimateirving
George is local for me and his kit went together flawlessly. Plus it came with all the hardware you need for the transmission in the mount
Z32 with lq4 swap
Old 03-24-2014, 07:47 PM   #125
crewchief05
S13 or S14?
Old 03-24-2014, 09:29 PM   #126
ultimateirving
Originally Posted by crewchief05 View Post
S13 or S14?
S13/s13 sr with oem replacement motor mounts. Other than the shifter hole, nothing on the body needed to be modified.
Z32 with lq4 swap
Old 03-24-2014, 11:12 PM   #127
battosaii930
battosaii930 is an unknown quantity at this point
nice ultimate, i forgot to mention that i did have to also grind that area down on my transmission to make room for the bottom mount turbo elbow
the collins kit works greak but Brett is a bit slow making the parts and sending it out the issue i had with the throw out bearing carrier was not bretts fault apparently the 05+ tranny has a shorter pivot ball then the 03-04 trannies and if i would have used the 03-04 pivot ball i would not have had the issue. but the 6 speed runs super smooth even with the 6 puck act extreme clutch its not an unbearable engagement like my brothers clutchmasters clutch is and the gears fly so fast! the car feels like a beast and i have less power then i did before i took the engine out because now im running 10psi because of the untuned AEM
i love it and you will too! totally worth the money heck i spent more on my wheels then i did on the 6 speed swap
also the collins transmission crossmember lets me use the regular sr/ka transmission mount which i was happy about because ive had Nismo mounts for about 5 years now and im super happy with them and they still look new
battosaii930 is offline   Reply With Quote
Old 03-25-2014, 05:35 AM   #128
crewchief05
Yea battosaii930 I actually called and pointed them to your thread. He was pretty bumbed to see you didnt use the throw out bearing carrier. I agree the collins kit is awesome but the turn around time seems leghthy. Do you have any chattering coming from the clutch engagement or anything?
Old 03-25-2014, 06:48 AM   #129
TheRealSy90
TheRealSy90's Avatar
I also reccomend George's "Maverick Motorsports" kit just because of the ease of install. No issues. Plus he even made the new parts for us guys that wanted to use the revised 08+ HR trans.
Such a good signature.
Old 03-25-2014, 02:51 PM   #130
battosaii930
yes i do get some chattering but i really dont hear it much its not too loud with the shifter hole sealed up but the car does shift super smooth
Old 03-25-2014, 03:30 PM   #131
crewchief05
What about you TheRealSy90.since you used George's setup did you have any chattering?
Old 03-25-2014, 04:25 PM   #132
ultimateirving
His trans isn't in the car yet. I'm very close to driving so I'll let you know what kind of chattering I experience with
George's kit. I'm also using a spec stage 3 sr clutch.
Z32 with lq4 swap
Old 03-25-2014, 04:38 PM   #133
crewchief05
Im sending mine off this week. But for sure keep us all updqted. Ill be using a spec stage 2 as well.
Old 03-25-2014, 06:19 PM   #134
battosaii930
from what i heard the chattering is from using a lightlweight flywheel and has nothing to do with whos transmission swap kit you use but im not worried at all ive seen much much much worse chattering on an evo
Old 03-26-2014, 03:32 PM   #135
ill.
ill.'s Avatar
ill. is an unknown quantity at this point
Hmmmm. Just taken the car for a long drive.
It seems I am getting some chattering off throttle. Goes away the moment you put the clutch in while rolling. Anybody getting this?
Had it up on stands and it seems to be backlash resonating through the 1 piece driveshaft.
IG
FB
ill. is offline   Reply With Quote
Old 03-26-2014, 04:41 PM   #136
battosaii930
That's exactly the chatter I get I don't think its a big deal though
Old 03-26-2014, 05:39 PM   #137
ill.
ill.'s Avatar
Yeah. I just turn the radio up haha.
My diff has huge amounts of backlash, but I'm going to a GTR rear end setup sooner rather than later so that should rule that out as the cause.
IG
FB
Old 03-26-2014, 08:28 PM   #138
battosaii930
no movement in my rear end and my j30 vlsd is quite healthy since i dont drift i just do the occasional auto-x and spirited driving
Old 03-27-2014, 12:13 PM   #139
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
Yup my trans is very loud compared to an sr and vibrates more. I think it's the nature of the transmission. 350z guys have been crying about it for ever
Black240Ct is offline   Reply With Quote
Old 03-28-2014, 07:20 AM   #140
TheRealSy90
It just makes everything more racecar. Tell people you have an osgiken dogbox with h-pattern shifter conversion.
Old 03-28-2014, 10:24 AM   #141
crewchief05
If only it were true haha. Btw sending my bellhousing, shift linkage, shift bracket today....WINNING! (Going withGeorge's kit)
Old 03-28-2014, 10:26 AM   #142
ultimateirving
Woot woot, Soon you shall be driving again!
Edited for update, new driveshaft arrived. Pretty much all my harness is reconnected and I just need to install my radiator and intercooler piping. Then fill with fluids and it's time to drive.
Z32 with lq4 swap
Old 03-31-2014, 05:55 AM   #143
crewchief05
Did you go 1 pc aluminum or steel?
Old 03-31-2014, 06:59 AM   #144
TheRealSy90
Sinced i've already had a 1pc aluminum with my sr for 3 years, i figured I would just stay aluminum with the z trans, although people have been telling me to go back to steel because of the "rotating mass". But I like the aluminum shaft.
Old 03-31-2014, 12:52 PM   #145
ultimateirving
Steel driveshaft $250 made here at a local shop.
Drove car last night and it was awesome, need to bleed clutch better and fix a coolant leak then I can rip on it.
Z32 with lq4 swap
Old 04-01-2014, 04:45 PM   #146
loucal
loucal has a little shameless behavior in the past
Chiming in here as well. Putting most of this together this weekend. Do you guys have reverse lights? I know thats random but i figured I'd ask.
2005 CD009 Trans 51k miles
Collins Adapter
Collins Throwout bearing Carrier
Collins Tans Cross member
Fidanza Flyhweel
ACT 6Puck Clutch.
Still trying to decide how to get the speedo to work. I have J30 diff so i suppose i can use the Dakota box.
Will keep you all updated as well.
This is an excellent thread btw not too many out there about this setup.
-Lou
loucal is offline   Reply With Quote
Old 04-01-2014, 09:58 PM   #147
ultimateirving
Lou I chopped my reverse light clip off the stock sr trans. And I'm gonna see if I can wire it to connect with the Z reverse sensor with some spade clips or something then make sure the harness can reach the factory plug.
This is all theory so I don't even know if the signals will interface
Z32 with lq4 swap
Old 04-02-2014, 07:29 AM   #148
TheRealSy90
Should just be an ON-OFF sensor basicaly, completing the circuit when in reverse to throw the lights on.
Old 04-03-2014, 08:15 AM   #149
Lidgsa
Lidgsa is an unknown quantity at this point
version will work also?
Lidgsa is offline   Reply With Quote
Old 04-03-2014, 08:57 AM   #150
ultimateirving
Drove to work today. Clutch chatter is definitely more noticeable. Also in getting a fair amount of vibration on the freeway around 2500-3k rpms. I don't think it's bad just a side effect of the large trans in a tight tunnel
Z32 with lq4 swap
