09-19-2013, 12:56 PM | #14941 |
so i have arp extended studs on the front of my car , i pressed them in at work and i even welded the backs just to be sure . so put on a 20 mm spacer but was still hitting the coilover with my current camber settings , rather than pull out some camber i banged the studs out of 25mm bolt on spacers i had and made them a slip on now , wheels clear fine at full lock and such now . is this a bad idea? i have them torqued properly and i re torqued them after driving a few miles . shouldnt be a problem right?
also in the rear i have a 25mm bolt on but the old studs were able to poke threw just enough that my wheels wouldnt sit flush on the new spacer ,so i put on a 3 or 5mm slip on to help clear the studs . everything is torqued so i should be good right? i will re torque them if needed after a few miles. i never used spacers before and dont really love them but i noticed that after changing my arms out and other stuff like camber settings and things that they would touch my coilovers or rear body every so often , so i feel like the spacers were a good alternative to having the wheels re sized for now they are 18x10 +9 and 18x12+9 ,im now using 25mm slip ons in the front and the rear is the 25mm bolt on with 5 mm slip on .so i guess the offset now would be front -16 rears -21. |
09-19-2013, 01:02 PM | #14942 | |
For 1, it is totally pointless to weld the studs onto your hub, because the act of tightening the wheel lugs holds it in. If you needed welds to hold the stud to the hub, it means you don't have a lug on it (or it isn't tightened).
* S14SR22 * 9.0 c/r * GT3071R * |
09-19-2013, 01:10 PM | #14943 |
[QUOTE=bc.;5420335]I am trying to understand the second half of your post here, but not really sure what is going on.
For 1, it is totally pointless to weld the studs onto your hub, because the act of tightening the wheel lugs holds it in. If you needed welds to hold the stud to the hub, it means you don't have a lug on it (or it isn't tightened). they were in fine , i know it was pointless ,i kinda just did , no real reason .we had a new welding machine at the shop i wanted to use. dumb i know |
09-19-2013, 01:12 PM | #14944 |
i guess i should have just asked , arp extended studs will be fine with a spacer that used to be bolt on but then was made into a slip on by removing the studs?
09-19-2013, 01:43 PM | #14945 |
Might want to verify its hub centric, but other than buy correct offset wheels, you should be fine.
09-19-2013, 02:56 PM | #14946 |
So I noticed that my wheel sits further back than it should.. I know that caster isn't adjustable in the rear so I'm leaning towards a bent control arm.. Does anyone have any input
09-19-2013, 03:15 PM | #14947 |
What makes you think it sits further back than it should? Did you measure something that tells you that it does or is it just your perception?
09-19-2013, 04:33 PM | #14948 |
Its not hard to tell that it sits further back.. I have three fingers from right side of my tire to my quarter and not even 2 fingers on the other side. My drivers side is dead even and the wheel sits directly in the middle of the fender arch
09-19-2013, 08:04 PM | #14950 |
ok so i need to take off my door panel but my window crank is super glued on. how do i take it off? i tried goo gone but its not reaching the super glue. HELP PLEASE!
09-19-2013, 09:10 PM | #14951 |
09-19-2013, 09:16 PM | #14952 |
AFC #1
Thrust angle or 4 wheel?
FSM has geometry measurements in it to check for bent parts.
09-20-2013, 06:53 AM | #14956 | |
Your Tanabe system will be fine. What you really need is to go somewhere where they know what they are doing, really well, and get your AEM tuned for what you are doing. In a 1 -2 high angle drift, you are scrubbing rear wheel speed more and more with higher angle. If you are entering the drift as an inertia drift, and not a true powerslide, that is why you are bogging. Same thing for an e-brake entry. You are slowing the rear wheels too much. If you set the car by flicking steering, and can get back into the throttle and slide the tires you won't bog. I have a small piece of back road with a few really nicely set up S's that are 1-2 gear drifts...STOCK KA with intake, ecu, pipe and 205's on SE's... If I enter the corner at speed, flip the steering into an full on inertia entry, kick the clutch so slide the tires and power through the apex, my car doesn't bog. The key is fast entry, inertia based angle that is smoother than ebrake angle, then power THROUGH the apex moment as you car gains angle, but does not lose rear wheel speed. I think, maybe, you might need to adjust your 'tune' on that AEM, and maybe work on inertia drift style. As the man said in an interview a couple years ago,"Musta drivu fastuh in corner, car usah inertia, fulluh powa through middle and outu." "OH, but I see you have a drift kit on your emergency brake?" "No. Thatuh PARKING BRAKU, mustuh parkah HILL sometime!" What this grand master of the drift was saying, was no ebrake drift, inertia and power. http://www.youtube.com/watch?v=0PAo096CS70 and a little more relevant... http://www.youtube.com/watch?v=cxvPdFt16-8
09-20-2013, 02:52 PM | #14957 |
?? The window crank should not be glued on. If I remember correctly, it is slip fit onto a metal dowel and should pull right out with some force. Now if you glued yours on for some reason, that is a different story.
09-20-2013, 03:27 PM | #14959 | ||
Bandwagon.
yeah if its for s13, the crank should have a clip holding it in. |
09-21-2013, 03:28 PM | #14960 |
Which wire is for the fuel level gauge in an S13? My fuel pump has:
Red/Blue Yellow Yellow w/ Blue Stripe Black White w/ Purple Stripe I've got it narrowed down to either of the yellow wires. FSM says it's a green wire with a blue stripe, which doesn't make sense. Can anyone else chime in? |
09-22-2013, 08:27 AM | #14962 | |
09-22-2013, 08:34 AM | #14963 |
My car has no muffler but sometimes I can smell gasoline coming from the exhaust, every time I go and look there is no gas on the floor and no leaks from what I see.
Is it normal since I don't have a muffler on my car to sometimes smell gasoline? |
09-22-2013, 06:04 PM | #14965 | |
AFC #1
Does the exhaust still exit at the bumper?
09-22-2013, 07:59 PM | #14967 |
Nm.. Found what I'm looking for
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html Last edited by EnemyS15; 09-22-2013 at 09:21 PM.. |
09-23-2013, 02:10 AM | #14968 | |
09-23-2013, 08:05 AM | #14969 |
It is possibly coming from your emissions stuff under the hood. I pulled my carbon canister and evap lines in my KA and found out that my car would leak gas when the tank is full.
09-23-2013, 12:05 PM | #14970 | |
