07-14-2010, 05:29 PM | #1261 | |
Toe out with give more angle on the outside (leading tire in drift), less on the inside tire. Toe in the opposite. Ackerman doesn't really have to do with the angle you can achieve, just with the relationship between the inside wheel's angle vs the outside one's. Yes, you could measure it roughly like that.
07-14-2010, 05:30 PM | #1262 |
For drifting you probably want zero or very close to zero ackerman(aka parallel steer). Ackerman gives you more steering angle on your inner wheel so that it follows a tighter arc than the outer wheel. This is good when you're cruising in a parking lot or at lower speeds on the street/autocrossing etc.
When you're drifting, you've got extreme amounts of steering angle put in, and so the ackerman effect is really huge, especially if you add more angle to the car. You end up having a really loaded "inner" tire in the drift that dictates the car's direction, then the "outer" wheel(the trailing front wheel in a drift) has quite a bit less steering angle on it. You essentially drag that outer front wheel along to some extent. That's why some people find it's easier to drift with a ton of preload on their coilovers which kills droop travel and picks up the outer front wheel in a drift. The car would be fastest if it had all four wheels on the ground and the front wheels pointing the same direction, but it's better to just pick that dragging outer front up and let the inner one do all the work with stock ackerman. So parallel steer or something close to it is probably the best way to go for drifting.
07-14-2010, 05:32 PM | #1263 |
Ok, so with the max knuckles parts kit, how would you want to set up the knuckles so that you can get minimal to 0 ackerman?...I am currently installing my knuckles...
07-14-2010, 05:35 PM | #1264 | |
Good explanation Def.
07-14-2010, 05:38 PM | #1265 |
Do you have their knuckles? If so, did you get the parts kit and do it yourself?
07-14-2010, 05:40 PM | #1266 |
No I don't. I'm going to let them do it when I do get a set.
07-14-2010, 05:56 PM | #1267 | |
To put it in terms of the article, I would want true ackerman with zero toe then? It doesn't tell you how to measure for parallel steer. I've always run zero toe, but I am about to cut and weld my new knuckles up, so I want to try and get it as close to 0 ackerman as possible, and want to be sure I measure it properly.
Instagram - SJKnoop |
07-14-2010, 06:05 PM | #1268 |
True ackerman usually means 100% - S13s have LESS than this stock. You want LESS than stock.
Basically line up the tie rod pivot with the ball joint pivot to get a parallel steer setup. Adjust toe for best turn-in and steady state grip during a drift . You can basically use small amounts of toe as a set amount of differential angle for the front wheels. I'd think the car would respond well with a bit of toe out and parallel steer for a drift, but the only way to know is try it out.
07-14-2010, 06:09 PM | #1270 | |
Get a square and jig it up. Make it the same side to side.
07-14-2010, 06:17 PM | #1271 |
Haha, at least your honest. Sounds like a good idea...I gotta work on the knuckles when I get off work tonight, so I will try and figure something else out. Thanks!
07-14-2010, 06:28 PM | #1273 | |
Make sure that when your wheels are pointed straight forward, your tie rod holes are inline with your ball joints holes (front to back). This makes zero ackerman because the knuckle rotates around the ball joint. Because I am formulating a much better post than my original one, since I have learned a lot since then and can't edit it anymore.
07-14-2010, 06:45 PM | #1274 |
I'm still trying to understand how it would be possible to improve this with grip in mind... everyone's talking about drift
How does an m3 or s2000 have its ackerman? Those are pretty well put together cars... the m3 also has a mcpherson strut front like our cars. What about porsches? Although porsches are rear engined... |
07-14-2010, 06:58 PM | #1276 | ||
07-14-2010, 09:09 PM | #1277 |
I think this is making sense to me now.
I feel like I'm beating a dead horse but......basically, if the ball joint hole on the spindle is angled just slightly then I want the tie rod hole angled just slightly. OR Does the ball joint hole need to be in a straight line from ball joint hole... My photoshops explain what I am asking better. Do I need to make sure both of these are changes are made, or is just the angle of the bolt hole important? I understand the angles are not right in these pictures, but they illustrate what I am asking. or
07-14-2010, 09:25 PM | #1278 |
This picture.
In order to have zero ackerman, you would move the tie rod hole (up) so the center is perfectly aligned with the ball joint hole. You can see by the angle they're sitting at that the MA-motorsports ones have less ackerman.
07-15-2010, 01:05 AM | #1281 | |
The reason the Ackerman is adjustable is this: When you look down on the steering arm of the knuckle, if the extension is welded evenly/ centered on the arm then it is about 49 degrees of steering angle and a mild reduction in Ackerman. Now if you shift the part 1/4 inch to the outside then you get 52 degrees of angle and additional reduction of Ackerman as seen here: One of the benefits of the Super angle kit is more angle with no sticky steering at lock but when you offset the parts for more angle and less Ackerman then you are also reintroducing overcentering. A more extreme offset that was pictured on the gold knuckles a few pages back was offset about .5" for a car with mad horsepower. Here is a better view:
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 07-15-2010 at 01:41 AM.. |
07-15-2010, 01:55 AM | #1282 |
WOW! THANK YOU! That is EXACTLY what I was looking for! lol @ the CAPS I just used. So since my car has roughly 300hp I should maybe move the extension about 1/8" to the outside from the centerline then? Thanks for your help Dan. Oh, quick question about the kit...with the LCA, do you weld the threaded back-plate for the bumpstops to the LCA, or just leave it?...I can see it working either way, just wanted to know what you recommend. Thanks!
07-15-2010, 02:31 PM | #1283 |
Sure that sounds good.
For the SAK, you should look here for more info: POWERED BY MAX: Forums?????? / ??????MAX??????????Parts Shop MAX Products Forum / ????????????? Super angle steering knuckle project But basically this is how the standard method LCA mod goes: (flush mount the base plate!) There is also a more extreme LCA mod, but its the same compromise, more angle but more overcentering, so it should only be used in combination with moving the rack forward.
07-15-2010, 03:01 PM | #1285 |
what about the driftworks rack spacers that move it forward? could you use those in conjuction with your SAK parts?? i've been wondering this for a while..
07-15-2010, 07:46 PM | #1286 | |
07-16-2010, 01:51 AM | #1287 | ||
Exactly
