Old 01-04-2013, 11:40 AM   #1201
2js1392
2js1392 is an unknown quantity at this point
I rev mine to 7200
2js1392 is offline   Reply With Quote
Old 01-04-2013, 12:57 PM   #1202
CDD200
CDD200 is an unknown quantity at this point
Stock springs are good for 8000 rpm but unless you have cams it is not needed
93 s13 coupe 5 speed- Ls2 swap in the works
97 sc300-gte/v160
CDD200 is offline   Reply With Quote
Old 01-05-2013, 03:11 PM   #1203
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
If you guys got the cams out might as well upgrade to BC springs and skip the TI retainers if budget is tight
Brian Crower Valve Spring Kit - MK4 Supra
Mr. Phonso is offline   Reply With Quote
Old 01-05-2013, 06:06 PM   #1204
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
has anybody who's done a 2jzge swap considered running 7mgte electronics?
bullfrogg0 is offline   Reply With Quote
Old 01-08-2013, 07:55 PM   #1205
BoostedVR4
BoostedVR4's Avatar
BoostedVR4 is an unknown quantity at this point
Just wanted to thank everyone for this thread, its an amazing wealth of information. I'm not even completely finished reading it yet.
Quick back story, a few years ago I had an S14 SR swap w/T67 H.O/AEM EMS setup in the car. Fuel cell, Bosch pump, etc. Built the head built w/solid lifters, springs retainers, cams, etc, but stock bottom end. It didn't like 8700rpms. After that I decided instead of building the SR, I would swap in a 2JZ. Its rare around these parts, and I have a few Poopra friends. Started doing lots of the research, but life happened so the car went away for damn near 3 years. I recently got a wild hair up my ass, and decided its time to do something with the car again. (selling would be stupid, I would lose huge)
So now I'm trying to delve back into it, and I'm noticing some things have changed. Different transmissions are being used, Tech2 isn't the only game in town, things are cheaper... This time I'm trying to set realistic, attainable goals. I just want to get the car started, and running. Stock twins are fine. (my Supra friend tells me USDM twins are easily had for $200-$300) I already have quite a bit that can be used, SR20 Koyo/fans/controller, Tial BOV, exhaust, FMIC, fuel/FPR, guages, etc. I would love to know I can at least get the car running on stock twins for $6500-$7000 before I pull the trigger.
But it seems the r154 has gotten outta hand $$$ wise. After some research I'm leaning towards the 350z CD009 tranny. I daily drove a 350z for a couple years, and loved the transmission. Right now I'm looking into how much a used BS manifold/single turbo would be....
For giggles if anyone wants to look. Pics of the car I've taken since I've owned it: https://www.dropbox.com/sh/rnu2novzra1t8um/8CQRI8m6W5
My YouTube channel, has a bunch of vids of the car: William Boschert - YouTube
lol @ my join date, and post count...
BoostedVR4 is offline   Reply With Quote
Old 01-08-2013, 08:08 PM   #1206
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
They have adapters to mate a 350z tranny to the JZ motors?
Old 01-08-2013, 08:17 PM   #1207
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Lol you not wanting to build the SR and goin 2j is pretty much my same reason also, and i just read a huge thread on the Z tranny to 2jz, you need to mix and match a bunch of stuff to make it work, pressure plate from one thing, clutch from SR, flywheel from something else.. once you add all that stuff up its pretty much the same cost as the R154.
2stepGoesPowPow is offline   Reply With Quote
Old 01-08-2013, 10:03 PM   #1208
BoostedVR4
BoostedVR4's Avatar
Same cost, but stronger from what I read...
2JZGTE 2jz 1JZ 2JZGE Engine to 350Z 6 Speed Tranmission Adapter Kit V160 W58 | eBay
Old 01-08-2013, 10:07 PM   #1209
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
R154s are hit or miss. I have seen guys blow them at low 500 lbs/tq and also up near 750 lbs/tq. Could also consider auto as those things have been kicking some serious ass on the Drag Forums even with very minor mods
2muchboost is offline   Reply With Quote
Old 01-08-2013, 10:20 PM   #1210
erict90
erict90's Avatar
erict90 is an unknown quantity at this point
Interesting!!
erict90 is offline   Reply With Quote
Old 01-08-2013, 10:23 PM   #1211
BoostedVR4
BoostedVR4's Avatar
This is a reply to en email I sent him yesterday. Some decent info...
Hey William,
Yes, I make the 2JZGTE to 350Z adapter plate, along with the complete engine to transmission kit! the only thing you would need would be the motor mounts since I make the Transmission mount for this already.
So a stage 3 kit that can handle up to 475ftlbs of torque at the flywheel, would be $1250+shipping
This Kit includes the following parts to get everything to work together:
The 2JZ/1JZ Engine to 350Z/370Z Transmission adapter plate,
Light weight Aluminum Flywheel MADE TO FIT THIS SWAP
Six Puck sprung hub clutch disc FOR THIS SWAP
Stage Three pressure plate MADE TO FIT THIS SWAP
Pilot bearing adapter
The bolts to fasten the adapter plate to the engine only(no starter bolts).(you supply the bolts to bolt the transmission to the adapter plate).
Transmission mount for S14
This adaption Kit Does not include:
The proper Flywheel bolts Toyota part number: 90910-02115 you need a quantity of 8
Clutch release bearing adapter(required, you must tell me which revision transmission you have so I can get you the right parts) for the external slave cylinder(CD001-CD009), it is an extra $105....For the internal Slave cylinder (CD009-JK40C) it is an extra $225(billet aluminum)
you will also need The bolts to fasten the transmission to the adapter plate(required).. the lengths will differ which is why it is up to you to supply them.
The stage 4 kit is the exact same, except it can handle 670 ftlbs of torque at the flywheel and is $1790+shipping.
Let me know if you have any questions
Thanks,
Brett
Brett Collins
Jr. Mechanical Engineer
Mechanical Engineering Student
SWAP1UZ.com
PH. 803-SWAP-1UZ
Old 01-08-2013, 11:53 PM   #1212
mrpeanut
mrpeanut is an unknown quantity at this point
found another option...might not completely work but someone out there has got to give it some sort of try...its the AR5 from a solstice the look of it, and lightly reading about the subject, its apparently a beefed up r154...anyone know more about this tranny?
http://www.supraforums.com/forum/sho...related-thread
mrpeanut is offline   Reply With Quote
Old 01-09-2013, 08:17 AM   #1213
BoostedVR4
BoostedVR4's Avatar
Does anyone have a an r154 and extended shifter sitting out? So they can measure from the bell housing mating surface to the center of where the shifter sticks out? Or has this been posted somewhere else and I missed it?
On this 350z setup its 34.5". I'd like to know where this thing is going to end up length wise.
Old 01-09-2013, 09:09 AM   #1214
2js1392
A lot of work I think when u can get a r154 for 4-600 and build it for another 1000 and save all the headache but that's just my opinion
Old 01-09-2013, 09:18 AM   #1215
2muchboost
Trader Rating: (33)
I agree its a lot of work and if I were looking to use a Nissan trans I am almost positive that the 300zx trans is stronger than the 350 trans.
Old 01-09-2013, 09:52 AM   #1216
BoostedVR4
BoostedVR4's Avatar
If you can show me an r154 *today* for $400-$600, I'll buy it. I can't find one anywhere for anything near that price, other than looking for old mk3's in a junkyard.
Old 01-09-2013, 10:01 AM   #1217
2js1392
Supra forums on north east section he's from pa
Old 01-09-2013, 10:32 AM   #1218
JDM SPUG
JDM SPUG is an unknown quantity at this point
The cheapest I've ever seen an R154 was $650 and it needed a rebuild. I got mine for around $1,000 a year ago.
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 01-09-2013, 10:35 AM   #1219
BoostedVR4
BoostedVR4's Avatar
Sold. And it did look scary.
FS: MK3 Supra R154
Old 01-09-2013, 10:41 AM   #1220
2muchboost
Trader Rating: (33)
I would check out Supramania...most of those guys are MK3 guys. Yes I agree the price has inflated some since I bought mine 2 years ago.
Old 01-09-2013, 12:15 PM   #1221
2js1392
How much u looking to pay for a r154 with 1jz bell housing and clutch. Ill consider geting rid of mine
Old 01-09-2013, 12:15 PM   #1222
2js1392
Might bite the bullet and v160
Old 01-09-2013, 01:00 PM   #1223
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
Im selling my swap engine/trans kit if anyone interested!!!
fdrea
florante rea is offline   Reply With Quote
Old 01-09-2013, 01:18 PM   #1224
2muchboost
Trader Rating: (33)
No way JR.....dont make me cry.
Old 01-09-2013, 01:20 PM   #1225
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
going with a different mount kit? or parting out the car?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 01-09-2013, 02:35 PM   #1226
BoostedVR4
BoostedVR4's Avatar
Both of you email me, and we'll talk.
Gmail = boosted2jz Gtalk works also. I'm always on.
Old 01-09-2013, 03:24 PM   #1227
Flicktitty
Flicktitty's Avatar
Sold
Old 01-09-2013, 03:25 PM   #1228
BoostedVR4
BoostedVR4's Avatar
Originally Posted by Flicktitty View Post
Sold
Gee. Nevermind then.
Old 01-10-2013, 05:25 PM   #1229
mrpeanut
ive got one with a 2 3/4 extention... center of the shifter is 28.5in...34.5 is a long ways out!
Old 01-10-2013, 05:41 PM   #1230
BoostedVR4
BoostedVR4's Avatar
I have a friend with a motor and r154 mounted, he measured for me about an hour ago. Said 28.5" from the bell to the center of the hole, and his shifter was sitting at 29". That's using the Tech2 mount kit.
What the heck? How is this even doable? I get that this kit is intended for an SC300, but I swear I've seen someone somewhere with the Z tranny in a 240.
Here is a quick photo I took a few minutes ago...
https://dl.dropbox.com/u/50315473/CAM00124.jpg
I asked Xcessive Manufacturing about it, this was the reply:
The concern with the motor is the placement of the oil pan, the slots allow you to fit it nicely into the space between the sway bar and cross member. The shifter is just going to land where it will. I think the length of 34.5" should work out ok, it may be just a touch long to fit the factory center console plastic. I don't have an R154 with an extended housing right now to measure.
Thanks
Rich Kobliha
