11-13-2012, 10:05 PM | #12032 |
Trader Rating: (24)
Feedback Score: 24 reviews
What rails will work with Recaro sr3 in a S13? Will either Bride MO or LR work?
How low is the Birde MO or LR seat rails? For example: I'm 5'6 and I have the bride MO and I can't see the hood of my car. |
11-14-2012, 04:10 AM | #12033 |
1)my s14 tein lower front coilover bracket is seized. what do I do? the car height needs to be adjusted. (already soaked in pb blaster for 2days and still wont budge)
2)can I buy a replacement if I angle grind it off? |
11-14-2012, 06:36 AM | #12034 | |
The cars came with 205's because they got better fuel mileage for the fleet average and nothing more. The reason for moving to a larger size, even from 205 to 215 is for a larger contact patch which translates to better grip. The measurable performance grip moving from width dim to width dim will translate to a faster lap time by full seconds, 10th seconds, and 100th seconds. The difference from going from a 205 to 225 would make a case analogy as running a track event in dress shoes vs a good lightweight pair of track shoes in overall grip, braking, and acceleration performance through both straight and technical sections of track. Lap times would be faster by full seconds. Then again, there is also the overall look with wider tires as applied to stance and overall look. Wider tires on correctly sized rims fill the wheel house better and either tuck or poke as the individual prefers
11-14-2012, 08:16 AM | #12035 |
can you use the stock lines instead of the s13 to z32 lines? whats the difference in the lines?
Corgis, R34 GTR, LS-14, S13 sil-40, LS-260z IG=@gallo_915 |
11-14-2012, 11:02 AM | #12036 |
Trader Rating: (77)
Feedback Score: 77 reviews
Yes, the MO fits just fine. I have a Recaro SR4 which has the exact same mounting holes with the SR3 and it fits perfectly. It doesnt mount too low to the floor imo. I'm 6' and I have no visibility problem at all in my s13.
11-15-2012, 12:04 AM | #12038 |
considering buying a 92' s13 as a side project that could turn into a daily, it has some problems.
Sellers Quote: "i recently just bought this, car was running 100% before,something shorted in the radio harness, so far iv replaced ecu and mafupdate: fixed the limp mode, now car just bogs down if any more than 20% throttle is given, (might be a simple fix)?" what do you guys think the problem is? how expensive could it run to fix, worst and best case? would it be worth it or is the car toast? |
11-15-2012, 07:46 AM | #12040 |
There's a fs thread and you can base it off his listing price. The offset is too high. But m5 are rare. Btw Nsx guys love the m5s and usually have deeper pockets. Just saying.
11-15-2012, 10:23 AM | #12041 |
hey guys i have a small question i hope it doesn't seem too silly....I've been an evo owner whilst admiring the s14 and i think/know i'm about to take the plunge.
the S14 I'm about to buy has rounded park lights but i want the sharp edged lights. So my question is: to attain the headlight conversion with the sharp edges do i have to change the bonnet and fender?.....hope i haven't angered u too much lol....oh and no i dont mean the s15 head light conversion to |
11-15-2012, 10:30 AM | #12042 | |
11-15-2012, 10:56 AM | #12043 |
oh i thought it was a conversion....i saw some post on the net suggesting there was a conversion that could be done, if so how?...well here in Barbados we dont have huge diversity in cars as we would like but cheers anyway
11-15-2012, 11:58 AM | #12044 |
i have a small problem, i snapped one one ofthe studs on my front coilover, how do i remove what left of the stud on my coilover? do i twist is off, or do i hammer the bitch out?
11-15-2012, 12:27 PM | #12045 | |
S13 uses a banjo with a bolt the Z32 does not the fitting looks similar to a hardline going into a MC. You can use the S13 line but you need a smaller bolt. Keep in mind the Z32 caliper does not have anything to hold on to the banjo so it 'might' come loose. Pic of stock Z32 brake lines used on an S13 |
11-15-2012, 12:32 PM | #12046 |
If its the top hat stud then yeah just hammer that bitch out. If its from the strut to knuckle mount just buy a bolt extractor it's a handy tool to always have
11-15-2012, 02:08 PM | #12047 |
thanks, all done !!
11-15-2012, 02:40 PM | #12048 | |
11-15-2012, 03:47 PM | #12049 | |
*headlights (usdm, or jdm) *corner lenes *front bumper (usdm, or jdm) *both fenders *front bumper retainer *headlight brackets (optional) *hood *grill (usdm, or jdm) *fender brackets(optional) *front bumper stays(two brackets that connect to the front bumper) Correct me if I forgot something, well hope this helps, I'd recommend saving up and buying a front clip from ebay. That way you would have everything you need, it would be cheaper in the long run believe me, good luck. On to my question, where do you buy the side markers for the s14 (blinker on the fender?)... |
11-15-2012, 05:01 PM | #12050 | |
Trader Rating: (29)
Feedback Score: 29 reviews
S15 would work. Not the pure oval, but nobody will mind. NissanParts.cc - Your #1 Source for OEM Parts and Accessories Doo eeeet |
11-15-2012, 09:06 PM | #12051 |
Randomly got this slack in my throttle cable yesterday:
I tried tightening the cable with the little 2 nut/bracket deal, but it did not help get rid of the slack at all.. What could be the problem? |
11-15-2012, 10:26 PM | #12052 |
Does anyone have any reference pictures that show good amounts of detail between origin type 2 coupe rear overs vs coupe origin tatakidashi rear overs, i cant make up my mind..
11-16-2012, 10:30 AM | #12054 |
has anyone here got a accord lip to fit on a s14????? let me know.. dont wanna start a thread for this lol
AND IM NOT TALKING ABOUT THE REAR ONE.. askin bout the FRONT type R lip style one
11-17-2012, 08:28 AM | #12056 |
help???
can anyone help me?? i have a 96 s14 and im in chicago, i tuck my car to the emission test and it got rejected it just says not ready on the codes, i have fixes my o2 sensor and some other sensor that have to do with the emissions, but nothing then the mechanic said drive it far to get the ecu to read the codes but nothing then, they said to ad 98% alchol and drive it far and still nothing. so i really dont know what to do know im thinking of disconnecting the ecu and pluging it back in to see if that works and reset something at this point i dont care if it fails cause if it does i could still get my license plate sticker with the waiver cause i have waisted more than the requiered to be eligible for the waiver
11-17-2012, 08:49 AM | #12057 | |
Trader Rating: (32)
Feedback Score: 32 reviews
Very first result, really?? |
11-18-2012, 07:04 AM | #12058 | |
2 cans for three gallons of gas. Empty the car down to 3 gallons, add the alcohol. It will clean up the exhaust to passable standards. What you are doing here is hyperoxygenating your fuel:air mix so that there is more O2 in the mix. When the fuel burns it expresses a higher ratio of O2 than NO or CO thus dropping the NO and CO ratios down to an acceptable level. Comprende?
11-19-2012, 07:42 AM | #12059 |
Can anybody tell me if the middle brake line port is flared? Trying to do z32 bmc conversion on my s chassis. They are not suppose to be flared but i cant tel if it is or not.
11-19-2012, 07:56 AM | #12060 |
From the looks of it, All three ports looked flared. What makes you say they shouldn't be? Flaring helps seal the line to the Master cylinder.
