Old 10-21-2013, 08:33 AM   #91
Guilty1s
Guilty1s is an unknown quantity at this point
Originally Posted by ka-titties View Post
what are you guys doing with the alternator diode circuit?
You obviously need your large gauge wire to carry the 12v charge from the alternator to the battery.
The ground is provided through the chassis/motor
You also need to provide 12v to the LightGreen/Black wire which is the signal wire for the voltage regulator. Without 12v to it, the alternator wont put out a charge.
You can easily tap into it into the plug next to the plug that you used for the 3wires for the 12v junctions. In fact, I used the same 12v source.
Edit: Info to add about the alternator
So my alternator wasn't charging after I did what I said before. For shits and giggles, I put a 12v light bulb between the other pin on the alternator and a 12 positive. On a 350z, it outputs a ground to the dash to light up the battery light while the positive end on the light is supplied through ignition hot +. Pretty much I was simulating that dash light. Boom! 14v on the mulitmeter.
In the end, I ended up taking that signal ground from the alternator and there is a plug under the hood that runs to the dash and works just like it should. Light on when the motor is not running, light off when the alternator is charging correctly, light on when it is not.
Sent from my iPhone using Tapatalk - now Free
Guilty1s is offline   Reply With Quote
Old 10-21-2013, 08:54 AM   #92
KansaiDrifter
KansaiDrifter's Avatar
KansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud of
^That's interesting, I'm also chasing the charging right now, have 12v to the b terminal and pin 4 on the 2 wire plug, no charge, no light hooked up either though. I did hook up a nice ground this time to the case, I'll have to see if that works, if not I'll try a light.
KansaiDrifter is offline   Reply With Quote
Old 10-21-2013, 09:01 AM   #93
Guilty1s
Yeah. Must have that light or some sort of ground hooked up to get that charge.
Old 10-21-2013, 09:12 AM   #94
ka-titties
ka-titties is an unknown quantity at this point
this is mainly what i was referring to. the 12v signal is taken care of with my jumper harness. OEM FTW.
but yeah, look here, page 22: http://www.nicoclub.com/FSM/350Z/coupe/2004.5/sc.pdf
edit:
you've got to put either a light or a diode in there.
ka-titties is offline   Reply With Quote
Old 10-21-2013, 09:17 AM   #95
Guilty1s
edit:
I just hooked it up to the 240sx alternator dash light. The wire is really easy to tap into.
Old 10-21-2013, 09:47 AM   #96
ka-titties
i dont have a 240 cluster anymore.
Old 10-21-2013, 09:53 AM   #97
Guilty1s
An led set to run on 12v (single resistor) or a 12v light did the job for me when I was trouble shooting how fix the issue. You could even use it as a idiot light.
Just wire it just like the fsm says.
12v ignition switched (on)/fused on the positive side ... Negative side goes to pin 3 on the alternator.
Iirc, if the circuit isn't already there at start up, just putting it after didn't make it work.
Old 10-21-2013, 10:02 AM   #98
Guilty1s
Has anybody else that has completed this swap had an issue where the car will not start till the ecu has been on for about 20-30 seconds. I'm not sure if it is something I missed in wiring or if it takes a sec to realize that there is no BMC, nats, ac amp, or whatever it may be.
I could crank it for 20 seconds and then it will start or I could let it sit for 20-30 seconds then it will start right up. I forgot if giving it a little crank initially to get the crank sensor to register something made a difference but that is what I got into the habit of doing anyways. You could turn it off then immediately back on as long as you don't turn the ignition power fully off. I do have my ECM reminder 12v hooked up correctly.
Old 10-24-2013, 01:07 PM   #99
ClaytonTNelson
ClaytonTNelson is an unknown quantity at this point
Im having a little trouble with the the throttle control relay and the ecm relay.
I see people are doing it in diiferent ways to wire them
Can someone give me some information on how to properly wire them in.
Thanks,
Clayton.
ClaytonTNelson is offline   Reply With Quote
Old 10-24-2013, 01:25 PM   #100
Guilty1s
My way... Lol
How are they wired now. Can you hear them click on?
Old 10-24-2013, 01:27 PM   #101
ClaytonTNelson
They are wired the way you showed in the write up. But I hear the throttle body power on when the ignition is off.
Old 10-26-2013, 09:07 PM   #102
ClaytonTNelson
My way... Lol
Double checked my wiring again today. everything seems correct. but the the throttle body doesn't become powered till the ignition is closed, and then its only for about five seconds..
Im stumped... i even bought a spare ecu and flahed it to see if that was the issue. but same symptoms.
Old 10-27-2013, 09:37 AM   #103
ClaytonTNelson
Do we have other shops that are capable of making a standalone wiring harness other than zfever? I'm trying to get this car done but this wiring keeps holding me back..
I just want to send a harness to someone and be done with it.
Any suggestions or referrals to someone that could handle this for me would be greatly appreciated.
Old 10-30-2013, 10:17 AM   #104
DEMo
DEMo is an unknown quantity at this point
I'm using a Nexus 7 tablet with bluetooth OBD2 port.
Edit: Click for VQ S-chassis FB group
Instagram: @hexagarage for VQ S Chassis Parts
DEMo is offline   Reply With Quote
Old 11-08-2013, 10:09 AM   #105
dkim1985
dkim1985's Avatar
Trader Rating: (28)
dkim1985 is an unknown quantity at this point
Feedback Score: 28 reviews
is there a difference in the DE and HR tranny? will an 09 tranny fit an 04 engine?
FS: Nismo R-Tune Camshafts for VQ35DE.
dkim1985 is offline   Reply With Quote
Old 11-08-2013, 10:47 AM   #106
ka-titties
you have to use the bell housing from the cd001 trans
Old 11-08-2013, 11:29 AM   #107
Guilty1s
Yes^ but that job isn't a simple bolt on affair
http://m.my350z.com/forum/showthread...906&styleid=69
350z HR trans are pretty much the same as 370z trans.
Old 11-08-2013, 11:29 AM   #108
unwtdhero
unwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-known
Tried to join the vq schassis group on facebook, cant find it.
Look me up and add me Logan Hartley
unwtdhero is offline   Reply With Quote
Old 11-08-2013, 04:13 PM   #109
dkim1985
dkim1985's Avatar
Trader Rating: (28)
370Z to 350Z Transmission Conversion - MY350Z.COM Forums
what if its an 2009 DE trans?
Old 11-08-2013, 04:16 PM   #110
Guilty1s
I think you mean cd009 which is the on for the transmission in 04-06 Zs. The cd001 was found in 03s but had temperamental 3rd gear syncros. Many where warrentied and replaced with the revised cd009
Old 11-08-2013, 04:29 PM   #111
Guilty1s
Wait... I read that wrong... There is no 09 de trans.. Atleast from a Z... Maybe from a G.. Idk
Old 11-11-2013, 09:27 AM   #112
DEMo
S-Chassis VQ Facebook Group: https://www.facebook.com/groups/252353284918213/
Old 11-12-2013, 07:37 PM   #113
ClaytonTNelson
I think i read somewhere that 350z test pipes will fit a VQ'ed s chassis. Can anyone confirm this?
Old 12-07-2013, 03:21 PM   #114
ClaytonTNelson
350Z test pipe DON'T FIT. just in case anyone else was wondering.
They hang to low and if the were shortened to the correct height the flange that faces the rear of the car would hit the frame rails.
Old 12-08-2013, 08:37 PM   #115
ka-titties
Getting ready to build some headers. 2" primaries
Old 12-12-2013, 02:25 PM   #116
ka-titties
Anyone figure out a way to run the fans off of the CAN system? The stock fan signal comes from the IPDM and gets the signal to turn on/off through CAN lines from the ECU. That'd be pretty slick if there was a way.
Old 12-12-2013, 02:36 PM   #117
Jissan
Jissan's Avatar
Jissan is an unknown quantity at this point
I wired Mishimoto Fans through the stock wiring with this writeup.
Installed a Mishimoto fan shroud today... - MY350Z.COM Forums
EDIT: Admittedly, I'm running stock VQ35HR 07 Z wiring. DOH!
VQ Build Insta
Jissan is offline   Reply With Quote
Old 12-13-2013, 09:33 AM   #118
ka-titties
yeah, you've got the IPDM installed i think. from reading your thread you have the whole wiring system installed in your s13 right?
Old 12-13-2013, 10:40 AM   #119
Jissan
Jissan's Avatar
Yeah, my original wiring was so hacked up there was no making any sense of it. I decided to just gut the car and go with the complete untouched wiring for the Z. The IPDM is a pain though. It consolidates a lot of relays and such that should be accessible for maintenance, thus making it necessary to replace the whole unit should an enclosed circuit fail. This is often the case and there are recalls related to Nissan IPDMs. The techs don't like diagnosing them and will tell you that there is no way to check one, even though the FSM states that connecting the unit to a Consult III will give you a status report of individual issues...
VQ Build Insta
Old 12-25-2013, 01:55 PM   #120
PoorMans180SX
PoorMans180SX's Avatar
Do any of you guys have a jig for shortening the shifter bracket? My trans came with the linkage already shortened, so I have no idea how much to shorten the bracket. I know DEMo said he could do it, but I can't get a hold of him, and I'm not looking to spend $250 on a billet piece that no one will ever see.
