04-24-2013, 06:57 AM | #63 |
Looks really good man. The low mount power steering is a cool idea!
04-28-2013, 06:53 PM | #64 | ||
thanks!
Merica' Quote:
Ok so last post i had this fucking genious idea to mount the electric bs in the glove box. That plan has since been trashed. basically the space retrictions were kiling me, it got super cluttered super fast. so i did some thinking, and some drinking, and came up with this even sillier idea. i rele liked the idea of using the glovebox to hide it all. i gutted the box itself and will just be using the front portion as a 'door' to the fuses and such. everything is mounted to a piece of wood i had laying around... so far seems like a much better plan. may have gone overkill on relays, better safe than sorry. i separated as much of the electric systems as possible in the whole build. this way when issues occour its easy(er) to troubleshoot where the problem is. this is on the passenger floor, always ends up looking like a mess...as per usual im not a pro.. i dont have any pictures, but i wleded up some brackets to the dash bar the plywood bolts too. turned out fairly well. i like it....for now notice ignitor location at this point ive got power to the ecu, engine, starter, and fuel pump. lights, cluster, etc will be coming soon. fluids in the car, brakes and clutch bled! Lets also note the bay is fully wired! Pretty well tucked, no ugly brake lines on firewall. But that damn booster line is still there. Throttle cable bracket is a mockup, and the cable is too. Need a s14 or dohc cable since this is a sohc car it's too short I just put it in for looks..doesn't connect. shits about to get real! stay tuned ladies and gents
@UpshiftEngineering Last edited by KoukiMonsta; 04-28-2013 at 07:56 PM.. |
04-29-2013, 10:59 AM | #66 |
not a real update, some pics that never made it.
dont think i mentioned it, no wiring runs through the wheel wells. headlight and fan come up the passenger frame rail. all the wiring goes through the ac water dump tube hole, almost out of sight. its amazing seeing the space under the fender since i cut it all up too. hopefully no rubbing.... and very low is the plan In these pics there's no wiring..
@UpshiftEngineering Last edited by KoukiMonsta; 04-30-2013 at 11:00 AM.. |
05-11-2013, 10:00 AM | #69 |
***A bit of an update, few pics for your viewing pleasure.
Picked up this boost gauge Ive got this rediculous shit going on, cannot wait to be past the wiring phase factory fucking bumper! now thats sweet not haveing a massive FMIC like previous setups.. bumper on, lights work! Man its the little things that seem easy and really start to add up once your finally trying to get it started. We are getting very close though! shameless plug - someone buy my FS junk so i can keep working on this!
@UpshiftEngineering |
05-18-2013, 12:21 PM | #70 |
*****This update is kinda a big deal guys*****
cluster and gauges have power, blue leds will be swapped for white ones. the red "11.5" is a voltage reading, just a digital display i epoxied into the cluster So at this point it is time to give the first attempt at starting the motor! fingers crossed my wiring is correct.... and it doesn't start... starter turns, fuel pump is on, pressure at rail...after a bit i smell fuel turn it over some more, backfire loud as hell. at this point i begin to think about the ignitor wiring, essentially firing order. i found 2 sources of contradicting info on which color wire is what cylinder. decided top de-pin and swap cylinders 1 and 2... FIRED RIGHT UP!! Whats a better way to host videos? my usual flickr account is "full of videos" for basic user..cuz that site sucks balls didnt leak any oil which is cool, busted a coolant hose as soon as some pressure was built after bleeding..also need a new brake booster. So at this point im pretty pumped that the motor is running, but ive got a big issue...the head was never really serviced, it previously overheated, valve guides are worn, and leakdown proved lots of leakage past valves.. it is evident the motor has low vacuum (~10 in hg) and a leakdown did verify its from the head. So this is sorta shitty, but i expected it. the head will be serviced via Mazworx, slap in on with new apexi HG and we should be rolling..but thats gonna take some time. In the mean time i will begin working on the interior, got some good stuff in store.
05-30-2013, 05:04 PM | #71 |
******Update
Glad I am the only one excited this POS started haha. I pulled the head, heres some pics..helps to show how i did some other stuff too. hit the pistons with acetone..yay shiney the problem... The head will be sent to Mazworx like i said. then this sucker should be better than ever! Ive been working on the interior, but you will have to wait for that.
06-07-2013, 04:56 AM | #74 | |
I've always loved the kouki/type x look. But there's also a couple kits I like. It won't be super huge widebody aggressive aero. Something more 'simple' really not sure yet
06-07-2013, 02:50 PM | #75 |
Love the build man, can't wait for more updates. You bought my buddies shell, so im happy to see that you are putting it to good use and it is turning into something rad.
06-09-2013, 09:25 PM | #76 | |
*******UPDATE as i said been working on re assembling the interior. it was in pretty good shape when i got it. clean carpet is awesome. sprayed some rattle can tpo get it all one color, removed rear sound deadening seats and carpet in rear seats too got to work on something for my gauges gave it some texture test fit looks good applied power for fun, got some ABS plastic to get a switch panel going finished product something im working on thanks to inspiration from broadfield. never was a fan of those hideous buttons
06-11-2013, 08:01 PM | #78 |
I first checked the interior thread, and then the build section. Where I found 2 posts you made..
The first being and amazing cluster surround you made. Which is superd sir, I debated putting my wideband in one of the vents. Ultimately decided against it due to being too low, to look at while hammering the throttle! My plan is way more basic, and I am not good with filler/sand/fill/sand type thing... It's far from perfect, but as per my usual mantra it's my first time. Stay tuned finished product soon.
06-16-2013, 09:15 AM | #79 |
*********UPDATE
here are some process pics from the cluster surround piece, turned out kinda cool i think. definitely not perfect...who cares finished product, if you look hard enough/from the right angle you can kinda see the original cutouts, i need to up my filler/sanding skills or some shit headliner had all kinds of funky stains so i died it interior just about complete, my door panel suck though...
06-16-2013, 09:45 AM | #80 |
That dash button delete turned out pretty slick especially for just keeping it simple like you did. Nice work on getting the pig fired up as well. Too bad your glove box setup didn't turn out like you originally hoped, that's a bummer. It turned out far better than mine did. I just half assed it to get it running and racing, because I'm a lazy shit. When will you hope to have the headwork finished and back together? Keep it up, I like that it is getting cleaned up from the inside out.
in any situation....thou shalt blaze |
06-21-2013, 04:41 PM | #81 | |
Really the glovebox thing turned out just fine. In the end it's a much better design. It will be up and running very soon...apexi HG to seal it up. image by Koukimonsta, on Flickr
06-21-2013, 05:51 PM | #83 |
Everything looks pretty damn good so far. I wish I would've gotten rid of more creature comforts in my car so I could take the wiring down to an extreme, but it should work for now.
Keep the updates flowing.
06-22-2013, 03:00 PM | #85 | ||
I've said it before, can't fucking wait to hear your setup! Hope to see it in person one day. Thanks for the kind words, and help diagnosing my low vac issue. Thanks man! Update coming soon, until then fdnj live feed.
06-22-2013, 03:54 PM | #86 | |
06-22-2013, 04:37 PM | #87 | |
Tore it apart, found excessive play in valve guides. And 2 bent valves. At that point it was clear, it needed some attention. The valves weren't seating and sealing properly, thus not creating vaccum, compression, or leak down numbers up to spec. So do it once, and do it proper. (Crosses fingers) at this point I should have everything ready to make some solid power. But there's always something.
07-08-2013, 01:00 PM | #88 |
**********Update
The drivers side e-brake cable snapped on me, easy enough to replace but still dumb I picked up this aluminum sheet... and created this cooling panel seems like it should delp direct air through the rad instead of over this was a beautiful sight. valve job and freshly decked by Mazworx! this showed up, its an 8815 headgasket in place, dont think i ever posted the PS high pressure line i made, here it can be seen. thanks to Toby for XRP materials, awesome stuff now its coming along I also did a manual seatbelt conversion, using the original interior panels extended bolts were made up s13 belts used, modified panels very good phot here... picked up this bulkhead fitting for my main starter power wire, you can also see clutch line routing
07-08-2013, 01:08 PM | #89 |
*******Bonus Update
during the head installation my buddy setup the go pro to take a pic every minute, turned out kinda cool. made this sweet edit for me
