Old 08-26-2009, 01:04 PM   #61
240sxjohny
240sxjohny is an unknown quantity at this point
THIS IS A N S15 SR20DET WITH A PAINTED VALVE COVER, I KNOW THIS BECUASE IT HAS AN EXTRA PIECE OF ALUMINUM AND THIS HOW YOU TELL.
240sxjohny is offline   Reply With Quote
Old 08-26-2009, 03:26 PM   #62
SR20DETdatsun510
SR20DETdatsun510 is an unknown quantity at this point
^ That clears things up...... ^
Thanks for being clear about that extra piece of aluminum.
SR20DETdatsun510 is offline   Reply With Quote
Old 08-26-2009, 05:32 PM   #63
Sileighty_85
Sileighty_85's Avatar
That/You sound like a ra-tard
Originally Posted by Monooxide View Post
He doesn't need to do any of this stuff.
This is a 93-96 Zenki S14 SR20DET.
The easiest and simplest way to tell an S14 SR20DET(Zenki) from an S14a SR20DET(Kouki). Is that on the Zenki engines(93-96) the valve covers had Stud and Nut combination for the attachment, while in the Kouki(S14a) engines it used a Bolt and tapped hole in the head similar to the KA. This is one of the Minor Changes(MCS14).
This is a S15 engine
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-26-2009, 05:58 PM   #64
SR20DETdatsun510
To the untrained eye, it looks just like my motor. Which I was told was an S14.
How else can you tell an S14 from an S15?
Old 08-26-2009, 06:19 PM   #65
Sileighty_85
like Monooxide said the Valve cover fasteners, S14(Kouki's) and S15's are bolts S14's (Zenki's) are stud/colsed ended nuts
後輪駆動車1番
1986 SR86 - 200ish
Old 08-26-2009, 07:32 PM   #66
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
sick 510.. that turbo kit is baffling me though.. is that a top mount gt28? lol...
and there is lots of restriction in that intake.. cleaning that up will net you noticable HP.
aNskY is offline   Reply With Quote
Old 08-27-2009, 10:59 AM   #67
SR20DETdatsun510
Yes, I do believe it is a top mounted GT2860RS with ceramic coated turbine and manifold.
I would love to change that intake but the MAF does not like to be so close to the compressor. Any ideas?
Old 08-27-2009, 04:30 PM   #68
aNskY
I guess theres just not enough room for a turbo bottom mount? a top mount t2 mani has to be custom. you just dont see that.
as for the intake, either have someone fab you up something with less restriction, or better yet go D-Jetro
