Old 06-13-2012, 07:05 AM   #61
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Sounds like you have the majority of it figured out! Good find on those front hubs too, GTR front axles might not work, BUT at least you have a cheaper alternative to GTR hubs and front suspension. That multi-link front suspension is crap, idk why Nissan decided to use it on everything, Z32, Q45, GTR, etc, IT'S CRAP!
I have a GTS-4 axle laying around at one time. . . I'm 99% sure it's missing the inner part that would bolt to the front diff flange tho, but maybe that would at least give you a direction to go with the front axles? Just trying to help. I can't wait to see videos of this thing when it's on the ground and driveable!
onehundredoctane is offline   Reply With Quote
Old 06-15-2012, 12:22 PM   #62
dat925stunna
dat925stunna's Avatar
dat925stunna is an unknown quantity at this point
damn you have huge balls to take this on
dat925stunna is offline   Reply With Quote
Old 06-16-2012, 12:08 AM   #63
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
Originally Posted by pokey_ View Post
Oh also for the transmission I upgraded to a 370z clutch fork. Way tougher than factory 300z or GTR.
you upgraded the pivot ball too, right?
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 06-18-2012, 06:39 PM   #64
bb4_96
bb4_96 is an unknown quantity at this point
the jdm stuff is going to be pricier just for the sake of being pricier. G35x and M35x both use a seperable atessa transfer case from the auto trans. Use g35x transfer case on vq manual trans with x front diff and axles. swap x front hubs onto your altima spindles and your spline count is golden. as far as oil pan is concerned, pull g35x pan, take measurements and have a halfway decent fab shop replicate the axle tunnel.
done and done.
the g/m35x stuff is coming down since it isn't 2005 anymore.
bb4_96 is offline   Reply With Quote
Old 06-20-2012, 05:40 PM   #65
pokey_
pokey_ is an unknown quantity at this point
Yes I did upgrade the pivot ball too, ;-)
pokey_ is offline   Reply With Quote
Old 06-20-2012, 05:42 PM   #66
pokey_
Sorry about the lack of posts lately. The s13 needed new brake lines, then I found out that the threads were stripped on one of the rear 300z calipers. Have several project cars and it spreads me thin time from time.
Old 06-20-2012, 06:35 PM   #67
Slims
Slims's Avatar
Slims is an unknown quantity at this point
wow and i though i had high goals in the works, this shit is on another level. cant wait to see some more progress on this. keep it rollin!
Slims is offline   Reply With Quote
Old 06-21-2012, 12:53 AM   #68
dawagarage
dawagarage's Avatar
jus backin you up, my bro
the pivot ball you got is shorter than the original, yes?
Old 06-24-2012, 06:52 PM   #69
pokey_
Well life has been throwing me curve balls lately so haven't had much time to play. Fuel pump went out in the yellow boomerang (92 SR20DET). Me and my son put a little time in the Louisiana 100F 50-70% humidity to get the dash out. Have to pull the rest so we can start cutting, and cleaning and welding and painting....
Old 06-24-2012, 06:56 PM   #70
pokey_
Yes but barely, at first you think this is a waste of time until you hold them side by side.....
Old 06-24-2012, 11:54 PM   #71
dawagarage
dawagarage's Avatar
ive heard only good things from the z32 community about fork upgrade, which lead me to buy the kit from z1
havent had the change to install it yet, because i have to drop the tranny, booooo.
but when i was first in the market, i was confused about the 2 different chromoly balls available. the longer one is a direct swap for the stock ball (to be used with the stock fork,) and the shorter ball is to be used for the solid fork.
Old 06-27-2012, 08:07 PM   #72
pokey_
That is what I got at the same time I did their Z1 TT Clutch & Flywheel Combo. They said it is easily streetable and can hold 600ftlbs of TQ. It can what I can afford for now.
Old 06-28-2012, 04:39 AM   #73
NismoPlsr
NismoPlsr is an unknown quantity at this point
Thanks for the lead on the clutch fork upgrade, I'll be using it on my RB25. I got my kit through Zspeed though because they have a chromoly pivot ball included.
Good luck on this build, I'll be watching.
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
Old 06-28-2012, 06:21 AM   #74
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
Why is that suspension crap and please don't copy-paste from MotoIQ
On thread: This project sounds bigtime, I hope it will be worth it
Motary is offline   Reply With Quote
Old 06-28-2012, 10:13 AM   #75
ACHTUNG
ACHTUNG is an unknown quantity at this point
This is going to be awesome
ACHTUNG is offline   Reply With Quote
Old 06-28-2012, 04:52 PM   #76
dawagarage
dawagarage's Avatar
^ Ja Wohl!
Old 07-05-2012, 09:10 PM   #77
pokey_
Sorry for the delay. I have made some progress. These pictures are unedited and not pretty! I promise it will look a little better once my brother and I are finished.
I have reshaped the AC box to provide more clearance for the passenger side head. The piece that I am holding has been moved to the left as it interfered with reshaping the firewall. The lower hard lines rotated to fit into the new location.
Initial Firewall cut (there have been more adjustments)
There is enough clearance around the transfer case to be able to change the fluid without dropping the tranny.
Floorpan cut and test fitting transmission.
I might move the engine forward just a hair to get the shifter lined up perfectly however, the further back and lower the better for balance sake.
GTR crossmember was supposed to ship today and hoping I can find some axles soon. Guys help a brother out as I am not having any luck finding them!
Old 07-05-2012, 09:38 PM   #78
pokey_
A cool side note is that there is no interference with the seats so full adjustabilty is still there. The passenger side tranny mount did have to go as it interfered with the front output shaft. Plan is to use the subframe rail on the passenger side as a mounting point and cross over to the opposite side hitting the factory spots on the drivers side.
Old 07-05-2012, 09:45 PM   #79
pokey_
I was reading an article the other day where a drift team took an r32 and converted it to a 240 front suspension. If you have anything laying around that can help me move forward I would greatly appreciate it!
Old 07-06-2012, 07:43 AM   #80
onehundredoctane
10-4, I'll snap some pics of the front end I have and see what I'm willing to let go.
Old 07-07-2012, 04:52 AM   #81
Drifting Kalamari
Drifting Kalamari is an unknown quantity at this point
Holy hell, this will be amazing!!
Drifting Kalamari is offline   Reply With Quote
Old 07-10-2012, 02:35 PM   #82
ricky508
ricky508 is an unknown quantity at this point
This thing is gonna be awesome and it's a Louisiana project! I'll be following this! Keep up the hard work and don't give up on it my fellow louisianian...
ricky508 is offline   Reply With Quote
Old 07-11-2012, 11:58 AM   #83
pokey_
Thanks man! Should be making more progress soon so I can post it up. Have a lead on axles so that will help tremendously as well....
Old 07-11-2012, 08:06 PM   #84
pokey_
AC box modified and Transfer case area almost done.
Old 07-12-2012, 01:26 AM   #85
TheRealSy90
TheRealSy90's Avatar
I love this build, can't wait for the day the pictures of the finished front end come up.
Such a good signature.
Old 07-12-2012, 12:14 PM   #86
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
loving this build! keep up the good work.
Coolwhip is offline   Reply With Quote
Old 07-12-2012, 01:27 PM   #87
pokey_
Me to! The GTR crossmember has been shipped. Hope it arrives by the middle of next week so I can make more progress...
This one has been eating my money lately. New brake MC is on its way.
Old 07-12-2012, 07:33 PM   #88
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
You need to learn to communicate with your local sliders... Since I have a Z32 bmc sitting in a box in my garage.
SLiDe_WaYz is offline   Reply With Quote
Old 07-12-2012, 07:46 PM   #89
pokey_
Under warranty! Didn't want to put anyone out, especially when you are an hour away. :-)
Old 07-13-2012, 07:14 PM   #90
pokey_
This came in today. Hope to have time to mess with it tomorrow after the MC swap in the boomerang...
450sx, awd
