02-25-2014, 01:32 PM | #61 |
Trader Rating: (24)
Feedback Score: 24 reviews
Very low means your front roll center is underground which means the car handles meh at best, esp with bouncy pbm coils and goofy geometry.
Any car can go drive backroads competently, pretty much. That's why these threads go so screwball. It's my overused phrase, but "limited frame of reference" makes everyone an expert. Rear bar preferences depend on the rest of the car setup and what you're actually doing with the car. Tires are still the most important factor, though. |
02-25-2014, 01:37 PM | #62 | |
02-25-2014, 01:41 PM | #63 | ||
Future Moderator
That is kind of what I want for this thread, almost like an entry into suspension geomerty before they dive into the other thread which at this point is can be like advance calculus to some. I am hoping Def comes in here eventually to drop some knowledge too..... Since we are own the topic how does one deal with the roll center and bump steer issue, without modifying arms? Is that something someone can "tune" out with an alignment?
02-25-2014, 01:44 PM | #64 |
Trader Rating: (24)
Whatever you say.
I take the susp/handling side of 240s more seriously than most (and I've driven a 1st gen set of PBMs and they were awful). I have spent a lot of time and money making an objectively good handling car (despite everyone telling me 240s are only good at drifting) and that's what I try to share in these threads. Nissanroadracing.com is the place to go learn about how to build a proper handling 240. It's all very well documented. edit: roll center is fixed by ride height. If you want to be low, then you need drop spindles (or some sort of custom flca/spacer setup). Bumpsteer is a different issue, and that usually involves shimming the tie rod pickup up or down and then using a bumpsteer gauge to track toe change through the travel of the susp (at the extreme). Roll center I would worry about (or don't dump your car) but bumpsteer is less of a problem. |
02-25-2014, 01:48 PM | #65 | ||
Future Moderator
I figured I'd keep the discussion going delete stuff that is not helpful or along the lines of (I rode XX type of coil and it was great!!!). I just hope you don't get tired of posting haha
02-25-2014, 10:11 PM | #67 | |
But that aside, since drifters don't want it to properly "dig in", and drifters tend to call the shots with 240s, I'd assume that his sway bar set will have a heavier rear one than is necessary, F/R grip requires softer rear suspension, to let it move fluidly with the front, considering how much less weight it has to compress it. Many people don't like ANY rear sway bar. I mantain that the first thing he needs to do is put it at stock height, and play with it like that. that and fix his bumpstop issue, be it by coilover adjustment or new coilovers or struts/springs or however.... |
02-25-2014, 11:34 PM | #69 |
The really funny thing is though....That to properly control a car in competition (regardless of specialty), the hot suspension setups are going to be eerily similar...
You guys are right about NRR...reading some of the suspension info there is crazy informative, especially in a few of the autox builds... @ e1. ..A question regarding sway bar..specifically end links...My s14 is lowered, not excessively, on OEM swaybar endlinks...I've always read that one should connect the bars with suspension at static ride height (and it should be easy)..This is not the case with my ride...The rear in particular is a bitch to mount...Any advice regarding cheap but strong adjustable end links. ..? @ All... I've forum searched..Posted this in another thread..Does anyone know where I can find concrete info on OEM s14 LCA lengths? TIA Ch Sent from my SM-N900V using Tapatalk |
02-26-2014, 11:38 AM | #70 |
I'll share my set-up since I'm still learning and converting..
S13 MCA Blues NT05 235/40/17f and 255/40/17r Sways, strut bars, control arms, etc. I'm thinking -3.5 and -2/2.5 and 0 toe for the alignment.
02-26-2014, 12:16 PM | #71 |
My car seems to handle decently, not bad for a skid car. Here's what I run:
Isis "pro" coilovers Every isis adjutable arm s14 flca's PBM modded knuckles (roll center corrected) Im not sure on the size but it has some beefy swaybars front and rear strut bars 17x9.5 front, 17x10 rear. -4* front 0* rear camber viscous s13 diff used to have bfg G forces on it as well. |
02-26-2014, 01:02 PM | #72 |
My S14 ,which is my daily driver, has a street inspired setup, but I think it handles pretty well. I can only realistically compare it to my girlfriend's RSX with BuddyClub coilovers,RUCA and Nitto NeoGens(used to have anyway). The steering on it feels way better than mine, I can only guess it's a better firmer front end. I'm not an expert but trying to learn as I go setup wise.
Gen4 Fortune Auto 500 coilovers Front 7k, Rear 6k,clicked to full soft front and back . I am lowered but nowhere near slammed, the back I think is a bit too high actually, I have a raked stance right now. Either I don't notice or something but I don't feel myself bouncing around while driving on the streets. Whiteline rear subframe bushings. Rear arms, except for LCA, are SPC arms which have harder rubber bushings than OEM. Alignment is (F/R): ~ -2°/-1.5° Camber.(F/R): 0.0“/ 1/16” Toe. (Was anyway I need to have it realigned). Tires are Brigdestone Potenza RE92A, size 205/50/16 (IIRC) on S14 SE wheels. I have a vlsd which I'm pretty sure is worn out. Sway bars, well to be honest I think the front one is OEM and I don't think I have a rear. I wanted to have a firmer and more direct steering feel (closer to the RSX mentioned above), and I keep reading that I should try to stiffen up the front end. I have Battle Version tension rods which I haven't put in yet, I want to get a front strut bar, Nismo Power brace or StealthFab tension rod brace, and fender brace. Those who have better suspension knowledge, like e1_griego, can please comment on improvements or suggestions. EDIT: The tire model I might have to double check, now I'm not sure if it's that exact model. |
02-26-2014, 01:41 PM | #73 | |
02-26-2014, 01:57 PM | #74 | |
02-26-2014, 02:00 PM | #75 | |
Yeah put those tension rods and a StealthFab brace in, and your front suspension/steering will feel lightyears better. Get some urethane or solid steering rack bushings as well.
02-26-2014, 02:41 PM | #76 |
Came to say tension rods. They will give you the biggest improvement in handling, compared to other arm upgrades, by far. Driving 240s without upgraded tension rods makes me want to throw up, now that I've seen the light XD
02-26-2014, 03:46 PM | #77 |
My $.02 I say go with a front sway bar and leave the rear stock. If you are looking on the cheaper side of things Koni Yellows with good springs. If you want a step up from that go with a custom coilover setup using Koni shocks. Or just buy some KW V3s and call it a day.
02-26-2014, 04:49 PM | #79 | |
Trader Rating: (24)
If you are looking for more than a street setup I would go with something other than V3s (6k/4k, no camber plates and voided warranty if you add them) but prob the best bolt-on street setup. |
02-26-2014, 06:05 PM | #80 | |
Future Moderator
I've seen braces for the fender too. Do those do anything or for show?
02-26-2014, 06:07 PM | #81 | |
I'm betting they work quite well, but I have no experience with them yet.
02-26-2014, 06:57 PM | #83 | |
I prefer shock tower plates myself as it reinforces the shock tower to the firewall. The fender braces are just 'additional' braces, but felt more like addition reinforcement than adding regitity. |
02-26-2014, 09:09 PM | #84 | |
I'm waiting until spring/summer time to get different wheels and better tires. Yea, stock tensions rods. I'll add steering rack bushings to the list of stuff to get. |
02-26-2014, 10:56 PM | #85 | |
Trader Rating: (38)
Feedback Score: 38 reviews
But even then, people think the number of clicks in damping adjustment is what makes a coilover go from "comfortable" to racing. So an EDFC is commonly used like some sort of switch to "dial" in "adjustments" to suit the mood. |
02-26-2014, 11:03 PM | #87 |
Agreed.....The only plus I can see to something like the EDFC and similar products would be for a street car (ie: comfort) or for a long distance endurance racer in changing weather, specifically say dry to rain then back where being able to soften the setup for wet conditions would be beneficial. However as e1_griego keeps hammering good dampening is essential to good ride quality.
02-27-2014, 01:48 AM | #90 |
If I had it to do over again I would go with a Koni setup over the KWs. I got them for a good price but after I got some decent camber plates/mounts I could have been within a couple hundred bucks of the 8611/8610 setup.
I have 8610s on my Subaru and they are badass for the price. Oh, and spending $4000 on forged wheels and then slapping on some shitty tires is retarded. So many people here only care about the "cool" factor. I spent as much money on tires as I spent on wheels and would do it again in a heartbeat. My cast wheels haven't shattered into a million pieces as some might suggest. |
