Old 07-26-2019, 05:52 PM   #61
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
Originally Posted by cole d View Post
My battery is relocated to the trunk. What guage wire did you use for the power and ground?
For future reference for anyone. I used 10 gauge for everything and it works fine. Anything less and I don’t think it works.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 01-20-2021, 12:04 AM   #62
cole d
cole d is an unknown quantity at this point
Originally Posted by sentradude View Post
Sorry everyone interested , I don't know when I will have time to actually do a write up but here is the bypass wiring in short:
You will need a relay and wire it per below ; You will need to locate the large black/white wire in the fuse box next to the battery, this is the starter wire running from your ignition (please make sure to verify with volt meter before cutting any wires!!) this wire will be cut and spliced into the relay..
86 = Signal Wire FROM ignition (Black/White)
30 = 12V+ From battery (New Wire)
85 = Ground to body (New Wire)
87 = Signal wire TO starter (Black/White)
This will provide a new 12V signal to the starter, basically strengthening the worn/out wire from the ignition. PM me with any questions, One day I will write this up with photos..
Dude, this is GOLD and should be stickened up top. My car start like a champ now no more issues. Thank You
cole d is offline   Reply With Quote
Old 06-10-2022, 05:46 PM   #63
jumboflan
jumboflan's Avatar
jumboflan has a little shameless behavior in the past
One thing wrong with this. 87 should go to black/yellow wire. Cuz hat to starter on s13.
Im immune to bullshit....so put your shovel away.
jumboflan is offline   Reply With Quote
Old 09-27-2022, 11:30 PM   #64
cole d
Nothing wrong with this I set minei up exactly and it works everytime. This post should be stickied.
