#844 |
I really appreciate it, front are 0, rear are -12
ah damn, I was close! They're looking surprisingly good, what're the specs? |
#845 | ||
![]() Join Date: Feb 2010
![]() Feedback Score: 11 reviews
captain:Any spacers in the front/rear?
Looks good dude.
#846 |
![]() Join Date: Dec 2010
captain what tires? obviously small OD than stock right?
Im looking at 17x9+22 (10mm spacer up front) rpf1s with 245/40/17s to keep it the right round, on stock body s13 |
#848 |
![]() Join Date: Oct 2010
![]() Feedback Score: 13 reviews
I'm running a 5mm spacer up front to clear my coilovers but nothing in the rear. And thanks she's def no where near done haha
They are 235/40's with a mild stretch. |
#849 | |
I am running that wheel up front, i needed to add a small spacer to clear Z32 brakes. I'm running 225/45s with -4.8* of camber. If you don't mind running that much neg camber those tires MIGHT fit depending on the brand. They will be very square on that wheel, and i would guess that you would have to run like a 3mm spacer rather than a 10mm. If you want less neg camber it will probably be hard to fit those with out some serious fender massaging. Check the pictures of my car a page or two back. A buddy of mine had 235/40s on a 17x9 rpf1 for drifting and ended up switching to fiberglass wide fenders cause it was rubbing everywhere. Also, 240cali, WTF are you posting those in here for? This is the ANTI-AERO thread. |
#850 |
![]() Join Date: Jul 2009
![]() Feedback Score: 6 reviews
Hey Captain, I've got 18x10 +25 wheels and thinking of stretching 225/35/18's. I don't know how well it's going to fit with stock fenders.
Can anyone help me with this? |
#855 |
![]() Join Date: Feb 2011
![]() Feedback Score: 21 reviews
http://monkeyboysyo.blogspot.com/ |
#858 | |
Im surprised youre having issues with brake clearance. I was planning on running the z32 brakes myself. |
#859 | |
Yea i needed just a tiny spacer to clear the brakes with the 17x9 +22 offset. |
#860 |
Im getting solid advice from road racers, they know the chassis. So youre just saying wheel well rubbing not fender.
What part of the caliper would contact the wheel? |
#861 |
no the fender rubs. with a 225/45 mine will rub under hard cornering IF i hit a bump at the same time.
If you have seen examples of that set up that works then by all means run that. I am just guessing that it'll rub based on what i run and what i have seen friends run. Also ride height will make a huge difference, that hasn't been mentioned. I am pretty low and my friend's car with the 235/40s is even lower. At a more reasonable ride height it might not be an issue. But yea, if you are getting advice from dudes that are using that tire size on that size/offset wheel on the track then copy their suspension settings and go for it. There is no replacement for direct experience. And the caliper was touching at the point of the caliper furthest from the center of the car (I don't know where else it would hit?). |
#863 |
