#7684 |
Nope you are both wrong I already said......ABC's and posted a pic
garsons are way different....and super concave face....the other wheels are flat and have the gold ABC logo ![]()
#7692 |
CR Kai's. 18x9.5 12 offset with 235/40 in the rear and 17x9 17 offset (plus a 5mm spacer for 12 offset) with 235/40 in front.
#7693 |
^What brand/model of tires?
A bit of a stretch even on the 9", that's amazing. |
#7694 |
toyo proxes4 on the rear, azenis st115's on the front.
#7695 |
![]() Join Date: Nov 2003
![]() ![]() ![]() Feedback Score: 7 reviews
How much camber are you running, front and rear?
I have the exact same wheels all around and running same size tires for rear. I'm running 225/45/17 tires up front, and putting on a 3mm spacer front next week. My camber is -3 up front, -2.8 in rear It seems like your rears are more flush than mine ![]()
268generation.com -United for His Renown- |
#7696 |
^ right now the camber is just guesstimated, i set it in little by little and rolled the fenders until it stopped rubbing, adjusted the toe a little and went with it. Same for the front, just added camber until it fit with no rub.
When I go get a real alignment after the first (I don't daily my kouki) I will be able to tell you the specs. Last edited by jrbump; 12-22-2009 at 02:43 PM.. |
#7699 |
#7703 |
Bandwagon.
add a resonator.
#7705 |
Philosopher King
4cyl should sound crisp and raspy. There is a low aspect to the sound but fart cannons tend to sound blustery.
G O L D E N B E A R R E P U B L I C |
#7706 |
![]() Join Date: Feb 2008
I can't even see your rims, let alone be able to tell if there whorish enough...
I don't know if it gets much better with 15's, my sideskirts are only 1 1/4" off the ground...they fell off the coming out of the driveway. Anyway here's my white on white daily(still need to paint sideskirts when its not so cold). 15x10 -25 205/50 all around Roll and Pull 1/2" in front 1" in rear ![]() |
#7709 |
Thanks. I'm guessing you mean like "parallel" side shots?
Front coils are max low. Old school JIC's, so I'm thinking about cutting out one of the two collars lol. The back can go 2" lower but I want to lower the front first...I hate rake. ![]() ![]() |
#7710 |
![]() Join Date: Mar 2008
raked means your front is lower than the front, so do you want it more level?
I like a little rake or an equal tuck in the front an rear wheels..I think it looks funny when a car has a massive tuck in the rear and a little wheel well gap in the front |
