#6841 |
Guest
Posts: n/a
#6842 | |
![]() Join Date: Aug 2010
#6843 |
Searched, but can't find an answer.
I'm looking into a vq35 swap into my 92 S13 non-abs open dif. I'm trying to figure out how I can use my stock speedometer without losing my tomei 2 way LSD. My questions are: Do all s13 abs pumpkins have a vlsd? I keep reading different things... "if you have one you have the other" "both were a different option" "it's random" Is it possible to fit my s13 tomei lsd into an s15 dif housing? Is there some other way of going about this? Thanks in advance Last edited by zombiewolf513; 07-12-2011 at 10:24 PM.. |
#6844 |
![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Considering doing a wire tuck on my hatch. Not asking whether or not it's hard, I know it is, and I'm comfortable AND I've researched.
My question is whether or not anyone has ever used/considered a fuse block that uses mini atc fuses? I want to keep my amenities, and with moving all the insane relays and such from the engine bay, I would need to keep space to a minimum so I can access it without having to remove my dash to change a fuse. I mean, just imagine needing to get a tow because you popped your fuel pump fuse and can't remove your dash on the interstate? |
#6845 | |
![]() Join Date: Mar 2011
#6846 |
so i was doing some searching on whats the best place to monitor temps. got a lot of mixed answers and none of them definitive.
-why do some choose to mount an aftermarket coolant temp sensor on the engine outlet side (upper rad hose) instead of the inlet side?? -why not on the lower hose or in the factory location by the head after the thermostat? -is the reading coming out of the engine from the upper hose accurate?? -and whats the best place to monitor oil temps? -the factory location on the block? -oil pan? -would the temps be accurate if you were to monitor oil temps off a filter relocation kit? |
#6847 | ||
![]() Join Date: Aug 2007
That's my 2 cents, sounds like it'd work good that way if you think about it. ******************** Now for my third try, starting to get impatient seeing ?'s that could have easily have been solved by searching or just thinking for more the 2 seconds getting multiple answers and burying my question back 10 pages. Can my stance coils still be adjusted with the dampening knob broken off? I searched and every solution is just to have stance fix it or buy a new knob. I just want to set them to full stiff and weld them up to my Z's strut tubes. No point in fixing them since I won't be ever making them any softer and to adjust them I'd have to take apart my whole suspension once they're on the Z. Thanks to anyone that takes the time to type a response. Can I just jam an allen key in there and spin it around? |
#6848 | |
#6849 |
what kind of transmission/shifter to these japanese guys use
‪HOW TO IMPROVE YOUR DRIFTING TECHNIQUE PART 1a‬‏ - YouTube the kind where you just push up/down to change gears, but still have a clutch pedal tia
#6851 |
Ive been given a chance to pick up good tires and could get the 225's for dick cheap.
215/45/17 front 225/35/17 rear On 17x7s.(These are dd wheels) Think it would look funny?
#6852 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
They would balloon out a little bit but I dont think it would be too bad. I had 215s on 7.5s and the sidewall was flush with the lip
IG/TikTok-ThatS14_Z06guy |
#6853 | |
#6854 |
![]() Join Date: Apr 2008
This should be a simple question for you guys.
I'm currently running 18x8 +25 wheels in the front of my S14. How big of a spacer do I need to make it flush? I'm fine with having to roll my fenders and throw in some camber. I'm currently running 18x9.5 +15 in the rear. Rolled and set at -2 degrees of camber. Thanks! |
#6855 | |
Whats your tire size? ![]()
#6856 | |
Trader Rating: (26)
It's pretty easy to figure out. Turn the wheel straight then measure from your wheel lip to the fender lip to see how far in the wheel is. I'm shooting for 15s.
#6858 | ||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Mini fuses should be just fine though Quote:
Oil temp wise I was always a fan of having it in the OE Pressure Sender location, or nearest. This way you source the oil Temp on the oil entering the filter and before the cooler. With that said, the Custom Steel adapter works fantastic at providing a bolt in piece that has a provision for a water temp sensor: ![]() ![]() Quote:
IT should fit, but you're going to run camber to make it fit.
#6859 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
How much of a difference are the R200 and R200V diff covers? Since the R200V diff cover is slightly larger in shape, will the amount of oil in the VLSD make a difference if I put a R200 diff cover on the VLSD?
Will the R200 diff cover bolt right on to the rest of the R200V carrier? |
#6860 | |
![]() Join Date: Feb 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
#6862 | ||
so the most accurate oil temp reading is before it is cooled?? |
#6863 |
just wondering if these wires will work on a ka?
http://cgi.ebay.com/ebaymotors/MSD-3...Q5fAccessories |
#6864 |
For starters I am new to the forum and not yet used to it and the searching option keeps freezing up on me and i dont feel like searching through all 229 pages of the small questions to find what im looking for and ive also tried google with no luck (maybe im not looking hard enough or something). I am going to be getting a 95 240sx se pretty soon that has factory bluish green paint. it has the silvia grille and badge on the rear but not the hood emblem. so i am curious as to what emblem color came factory with this color. I'm wanting my car to look (not a fanboy and please dont hate for the term but) jdm since it has most of the badging and the s14 zenki is my favorite car. also are the side badges on the k's aero s14 the same color as the hood?
#6865 | ||
I was really kind of bothered by why no one had done it with minis, was all. The fuse-box on most modern cars is filled with the tiny bastards. I figured if you're doing a tuck as an "upgrade" why not actually move to something more current in the process? GSXRJJordan mentioned maxis were a pain at some point, but never saw anything about minis. I may just bite the bullet and get started... Quote:
#6866 | |
#6867 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Can't seem to find this in the FSM... in what order do I torque down the diff cover bolts on an S13 diff with an S14 cover?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#6868 |
If the FSM doesn't care, neither should you. Only reason it matters on things like camshafts and cylinder heads is the load needs to be spread evenly to avoid warping the component. If a camshaft isn't true straight, it wobbles. Diff cover is just a cover. Torque it down and go.
#6869 |
Quick question, I am wondering on the rarity of my sway bars. I have a 1990 s13 (first owner) and it came with brightish blue sway bays front and rear with red brushings off the Nissan dealer lot in 1990. They have held up amazingly. Just wondering. I don't see any nismo badging on them. Also the original springs and shocks were blue but very dirt y but the springs I remember had the Nissan badges printd. Anyone know?
#6870 | |
Trader Rating: (38)
But thanks for answering! |
