12-28-2013, 11:39 PM | #6121 |
The FSM shows that the standard rack is 3.1 turns lock to lock, HICAS 2.6. I imagine the benefit of the HICAS rack would be the smaller amount of input required for any sort steering, whether it be initial turn in, feint initiations or mid-corner corrections. I don't think there would be any improvement in counter-steering as the wheel moves faster than your hands can turn it.
12-29-2013, 07:34 AM | #6122 | |
12-29-2013, 08:38 AM | #6123 | |
Sent from my SGH-T989 using Tapatalk 2 |
12-29-2013, 12:53 PM | #6124 |
Interesting, I did not know this, and have never seen it explained, which they do a good job of. Must have been one of those things they snuck in there with product development .
12-30-2013, 04:36 PM | #6125 |
Would it be possible to compile a list for the first page of how each change to one of the front and rear suspension characteristics (ride height/camber/toe/caster/etc.) affects the others?
For example, adding negative camber in the rear adds toe-in and caster, and probably other stuff. I know there a lot of factors and it has all been said before, but it would be nice to have a general reference guide for the S-chassis suspension behaviour. |
12-30-2013, 04:50 PM | #6126 |
Also, this one time, years ago, I pressed the ball joints into my FLCA's upside down, and I ran the tension rods and FLCA's upside down (on the opposite side of course), because I thought that the FLCA-to-knuckle angle would be easier on the ball joint on an over-lowered car where the arm points straight up.
[/embarrassingsecret] |
12-30-2013, 06:03 PM | #6127 | |
Sent from my SPH-L710 using Tapatalk
ACE マジック HEART |
12-31-2013, 07:41 AM | #6128 | |
settings make the car handle. http://http://www.motoiq.com/Tech/Th...Handeling.aspx |
01-03-2014, 09:47 PM | #6130 |
Make it double adjustable and ill paypal you the money right now.
Gee Spot Garage, doing things you don't. |
01-03-2014, 09:48 PM | #6131 | |
Seriously, i want/need asap
01-05-2014, 11:47 AM | #6132 | |
01-05-2014, 09:56 PM | #6133 |
I am putting a threaded rack spacer on with 25mm extended S14 LCAs and 25mm roll center corrected cut spindles. I Have Tein Inner and Outer tie rods.
Should I run 2 Rack Spacers or Longer Inner rods? |
01-07-2014, 12:36 AM | #6136 |
I want to extend my front lower control arms on my s14. I was thinking 25mm. all I have in front suspension wise is bc coilovers and hardrace castor rods. I heard all I will need to suit is Maxima tie rod ends. What year model is best to get?
01-07-2014, 12:44 AM | #6137 |
See above...........
01-07-2014, 12:51 AM | #6139 |
Nope, you need maxima inners and S14 ends.
01-07-2014, 06:17 AM | #6141 |
Read one page back you lazy ****
01-15-2014, 12:14 PM | #6145 |
Just a minor nitpick, but the final "tear drop" cut out would be stronger if the metal remaining was more inline with the stresses going through the arm. Basically it should form a triangle and not a bent curve. (not saying it'll fail, just friendly advice)
01-24-2014, 09:18 AM | #6146 | |
Best way to move the rack forward? Is there a "rack forwarding kit" readily available?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
01-24-2014, 09:26 AM | #6147 | |
Eccentric bushings. They are probably the closest you'll get without actually moving your rack forward. |
01-27-2014, 04:55 PM | #6148 |
Has anyone received their gktech bolt-on roll center / bump steer / steering angle kit yet?
They are supposed to be arriving end of january.
01-28-2014, 10:05 AM | #6149 | |
hope this helps
[email protected] |
01-30-2014, 02:19 PM | #6150 |
Edit: Nevermind, thought we were talking about a different gktech piece
cONtRol FReAkS Last edited by conrad_s13.5; 02-04-2014 at 07:37 AM.. |
