11-13-2013, 08:14 PM | #5971 |
I'm in 9/8k and it's too soft. I bottom out a really often. Every intersection and in hard turns. Yes even flat surface corners. But my struts are blown, and springs are drooped.
11-24-2013, 11:56 AM | #5973 |
Im currently running the new forged PBM knuckles along with extended LCA. I have been told I shouldn't run aftermarket outer tie rods due to them binding. I was told to run stock outers.
My current tie rod setup are Kazama s14 inners along with SPL V5 outers. |
11-24-2013, 12:20 PM | #5974 |
The cheap aftermarket outers usually don't have bearings with enough misalignment. A quality name brand like SPL will work fine.
S12 || KN13 || S13 || B16 |
11-25-2013, 01:15 AM | #5975 |
So I have been doing my research but I haven't found a straight foeard answer so here is my issue.
First my setup that I just installed: S14 FLCA's Inner Tein Tie Rods with rack spacers SPL Tie Rod Ends S13 Modded Knuckles However it still has stock traction rods And I got everything aligned. So I turned the wheel to full lock and I noticed my angle has decreased and I can only turn the wheel one full time around and it locks due to the outer tie rod hitting the s14 bump stop. I have read that many people grind or cut off the bump stop, but I am worried if I do this will my outer tie rod will now hit my control arm. What can I do to prevent the outer tie rod from hitting my control arm and to increase my angle like I hoped to do? Thank you. |
11-25-2013, 02:48 PM | #5977 |
Who cares if your tie rod hits your LCA? It's your new bump stop at that point. If you can go that far, fab up a new steering stop like above. Not rocket surgery.
11-25-2013, 03:43 PM | #5979 |
That is a pretty sweet looking bump stop. Never seen that one before, learn something new everyday. I will be chopping up my bump stops thank you for the help.
Lexus V8 Into S13 Build |
11-25-2013, 05:22 PM | #5980 |
I've reqd back into this tjread and can't seem to find an exact answer to my question.
If I were to extend my s13 flca's by 30mm, would I need to run s14 outer tie rods (which I believe are longer) in order to compensate? |
11-25-2013, 05:36 PM | #5981 | |
It's the Inners that are longer.
If you look through again you should be able to find a post with the Lengths of different Nissan Tie-Rods that fit our Racks. Most requiring S14 Outers due to the Thicker Rod/Thread pitch change.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
11-25-2013, 05:36 PM | #5982 | |
I know it a PITA because the taper shank on that one is a mile long.
11-27-2013, 02:37 PM | #5983 |
im piecing together a new set up.
ive moved my steering rack an inch forward extended my LCA by 1 1/4" getting PBM pro knuckles for my tie rods I have s14 tein inners with the slip on spacer and for outers i have q45 moog. they are the same thread pitch as s14 and appear to have the same taper angle, but the taper seems to extend further then a s14 moog(sold my old knuckles so have nothing to bolt it into currently) the q45 moog outer are a little over an inch longer then a s14, so i think this setup will work. waiting for my knuckles to get to me to bolt it all together. |
11-29-2013, 03:06 PM | #5984 |
Looks like i30 inners with q45 outers are the best budget minded forklift steering rod I have to extend my s13 outers so my wheels can go full swing. I've already extended my outers almost an inch and feel if i give it more track i'm really gonna run out of thread. Lol.
Just another broke ass drifter |
12-01-2013, 10:07 AM | #5985 | |
So are these jams still happening, or should we start looking into other options?
@MMyriad |
12-01-2013, 12:24 PM | #5986 |
They're delaying them as long as they can because they need to make their money back on the knuckles, and they realize once these come out nobody is going to want to buy a whole knuckle.
12-01-2013, 08:28 PM | #5989 | |
I thought this was kinda cool. A typical low car on the left, my car on the right.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 12-01-2013 at 09:53 PM.. |
12-01-2013, 11:59 PM | #5990 | |
12-02-2013, 03:25 AM | #5991 | |
We will be running a small production batch in the next month or 2. Keep an eye on our facebook page if you're not already on it for further updates: www.facebook.com/gktech |
12-02-2013, 09:08 AM | #5992 |
Is somebody have issues with clearance after forwarding the rack?
My downpipe rubbing steering shaft when then engine is moving under load. any easy solution? Its a PITA removing the downpipe |
12-02-2013, 09:32 AM | #5993 |
dent the downpipe or move your exhaust hanger to pull it over.... or even better, replace your engine mounts so your engine doesnt move as much...
12-03-2013, 12:08 PM | #5994 | |
With that RC correction, will it hit on 17" wheels at the inner barrel if the offset isn't negative?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
12-03-2013, 12:10 PM | #5995 | |
What is the functional difference between these and the full knuckle kit?
12-03-2013, 01:19 PM | #5996 |
There is more than 1/2in clearance there, but we're about to find out for sure. I have 17" wheels coming in the mail for the front.
12-03-2013, 04:41 PM | #5997 |
Everyone should buy the knuckle still & resist the urge to cheap out on the bottom bracket because while you are saving money you are killing the KPI and Scrub Radius. Thats the compromise you have to consider & thats why its still worth your money for a complete knuckle.
12-04-2013, 02:32 AM | #5998 |
Just ordered PSM inner tie rods thinking they would be long enough with my 15mm extended S14 LCA, PSM forged knuckles and moog outer tie rod ends and they aren't. (S13)
I was thinking about purchasing two of the "big angle spacer" people sell for the steering rack to space the inners further out. Any thoughts or better ideas? Thanks |
12-04-2013, 04:14 AM | #5999 | |
^apparently the q45 outers are longer and might work... you could give that a shot. I'd try to avoid the large spacers.
12-04-2013, 05:53 AM | #6000 | |||
@MMyriad |
