Old 05-09-2017, 10:24 AM   #31
bjreynolds202
bjreynolds202 is a well-known jackass
Blue55, I noticed you put up a video on the track with the CTS V calipers and stock rears. How was that experience? Any issues with locking up the fronts too much? How was the balance, fade, modulation, etc?
My Simple S14 Build
bjreynolds202 is offline   Reply With Quote
Old 05-09-2017, 10:42 AM   #32
Blue55
Blue55 is an unknown quantity at this point
It was very close to what I expected. CTS-V fronts, stock rears. So massive front bias. The setup is fairly easy to modulate, but it's not hard to lock up the fronts. I am deliberately building it out in steps so I can work out the kinks at each step.
I'll install Z32 rears next and most likely I'll install a brake proportioning last since I anticipate those brakes will shift the bias too much to the back.
Zero fade, but I'm not getting maximum braking potential right now as the rears are just along for the ride. So no fade, easy to modulate, heavy front bias, pretty good feel.
Blue55 is offline   Reply With Quote
Old 05-09-2017, 10:53 AM   #33
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
Big advantage of the Wilwoods is the pad size. Wilwoods use a 120mmx61mm pad whereas the CTSV uses a 110mmx54mm pad. The design of the Wilwood pad also fully contacts the rotor, whereas the Brembo pad tapers off at the edges making the contact patch even smaller.
tb13 is offline   Reply With Quote
Old 05-09-2017, 11:01 AM   #34
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
1) The rears tend to not do much work to begin with on these vehicles. The stock bias is 65-68/35-32 (or something like that). With the CTSV front/stock rears you are sitting somewhere in the 75-77/25-23 range currently
2) I would advise against a proportioning valve and tune balance via brake pads. I ran DTC 60/70s front and DTC 30/Hawk blue rear depending on bite or tire compound.
3) With Wilwood 1.75 F (4 piston) and 300ZX rears, the bias was very very close to stock. Your rear 300ZX brakes will NOT move the bias so far to the rear to necessitate a proportioning valve.
Do the math if you would like to confirm for yourself
Goodluck!
Old 05-09-2017, 11:28 AM   #35
Blue55
Goodluck!
That's great input Ralliart! My plan has always been to do the brakes step by step and test after each piece has been complete.
How do you calculate bias? TCE Performance has a calculator, but, I don't know how to get a pad's Cf value.
http://www.tceperformanceproducts.com/bias-calculator/
Old 05-09-2017, 11:30 AM   #36
Blue55
Actually that's wrong. The pads have 100% contact with the rotors in my setup.
Old 05-10-2017, 12:45 PM   #37
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Originally Posted by crash n' burn View Post
Didn't think Andy was still doing stuff for the S-chassis. I thought the F40 brackets were the last ones.
Andy is still making them, I think he makes large batches at a time, so multiple orders help justify him making them I'm sure.
onehundredoctane is offline   Reply With Quote
Old 05-10-2017, 01:40 PM   #38
Agamemnon
Agamemnon's Avatar
Link?.........
Old 05-11-2017, 06:25 AM   #39
onehundredoctane
Originally Posted by Agamemnon View Post
Link?.........
https://www.facebook.com/TrackProven/
Old 12-17-2017, 08:21 PM   #40
smmsak
smmsak is an unknown quantity at this point
Hey guys sorry to thread jack but imnlooking into either of these calipers. For those of you thatbhave the wilwood superlites, is there a part nimber for them or are they universal and you just buy the mounting bracket? I see they are cheaper than the ctsv right now but not sure how many models of superlites they would have? Any help wpuld be great!! Thanks
smmsak is offline   Reply With Quote
Old 12-18-2017, 03:10 PM   #41
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Can we have a separate sticky/discussion for brake setup only? Like the roll center thread but for brakes only.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 12-19-2017, 07:56 AM   #42
onehundredoctane
I have a set of the Track Proven adapter brackets, part number for the calipers is 120-11130, they should be the 1.38" piston for 1.25" rotor.
Summit Racing shows them for $165.22 each, and these weight under 8-11 lbs
Rotors to use with these are Z33 track rotors, each source from anywhere.
Old 12-28-2017, 02:27 PM   #43
koukimonst3r
koukimonst3r's Avatar
koukimonst3r is an unknown quantity at this point
Anyone have info on how to make the ctsv 4 pot rears work? Currently have z32 rears, TIA.
ig : koukimonst3r
koukimonst3r is offline   Reply With Quote
Old 12-29-2017, 08:38 PM   #44
Blue55
Z32 is pretty ideal for the rears. CTSV 4 piston in the rear will be WAY too much rear brake bias. These are very light cars. The Cadillac is ~4,000lbs.
Old 04-26-2019, 06:19 PM   #45
boSted_13
boSted_13 is an unknown quantity at this point
Are there any detailed threads on s13’s/ anyone running gen 1 CTS V calipers with angle mod
I’m thinking of driftknuckles.com
boSted_13 is offline   Reply With Quote
brake upgrade, calipers, cts-v, ctsv, z32
