Off Topic Chat All non related chat goes here. |
09-20-2016, 06:17 PM | #31 |
I wouldn't mess with a GE block. You can get vvti GTE's for $2k and that already comes with the FFIM, oil squirters, bulletproof internals and the Aristo A350 trans that you could sell for a couple hundred.
09-20-2016, 06:32 PM | #32 | |
09-20-2016, 07:19 PM | #33 | |
Who said that? I said FMIC. They come with a stock SMIC. Just have that rebuilt.... |
09-22-2016, 03:36 PM | #39 |
09-22-2016, 03:39 PM | #40 |
If youre 20K deep into a JZ swap it better be making some serious numbers.
An auto 2jz swap is 2K. I could see $10K being a much more realistic number for a reasonably modded jz |
09-22-2016, 03:43 PM | #41 | |
$6-10k is the number. Engine and Trans maybe cheap, but everything else will nickel and dime you. |
09-22-2016, 04:35 PM | #43 |
09-22-2016, 05:02 PM | #44 | |
1jz thread making full torque around 3k rpm 300 whp on a real dyno http://zilvia.net/f/showthread.php?t=500787 2jz making about 400 hp on a number jet dyno (about the same whp as on e real dyno dynamics dyno) full torque at about 5200 rpm http://www.clublexus.com/forums/sc-1...automatic.html im going to stop here since we all should know not to question the internet god named corbic |
09-22-2016, 06:19 PM | #45 | |
JZ swap cost stupid expensive
That's the only thing intelligent you posted. So you want to compare a VVTi Manual 1JZ on a Mustang Dyno with whatever small ass stock location turbo to a Non-VVTi Automatic 2JZ with a PT6262 on a Dynojet. 6262 is also a what, 700hp Turbo and he's only making 450? Omfg lag? I'm sure your going to spout off some internet nonsense about 1JZ heads but the realty is they don't flow any better then the 2JZ NA heads. I'll take the off the shelf pets and 500cc of displacement thank you. Fuckers pay $3k+ for 200cc stroker kits. Why would I pay more to get a smaller displacement engine made from harder to get parts? |
09-22-2016, 10:20 PM | #46 | |
still only gets full boost at 4k rpm while the 'inferior' 1jz is 1k rpm earlier http://www.clublexus.com/forums/perf...n-numbers.html shouldnt you be trolling a mustang form with all your shit talk of displacement being such a great advantage to make power? |
09-22-2016, 10:47 PM | #47 | |
"Full Boost" what the fuck are you even blabbering about. You are comparing two completely different modified engines on two completely different dyno systems. How is a 1JZ going to make more power if everything is the same except the displacement? Here ya go. http://dustrunnersauto.com/1jz-vs-2jz/ As far as trolling. If you are so worried about how soon you get "full boost", just do what I did.... |
09-23-2016, 02:26 PM | #48 |
if it means anything...
I spent less than 7k to do a proper 1jz swap, and its been the best choice Ive made with this shitbox s13 so far. Mods: FMIC, Competition Clutch, 1pc driveshaft, exhaust, bigger intake, stock boost. I planned to upgrade turbo, injectors and shit eventually but stock is everything I always wanted my built SR's to be. I daily this car, drive it to the track, drive the track, drive home and to work the next morning. In 2.5 solid years of abuse Ive replaced a powersteering pump (I may or may not have been at fault for destroying) and an ALT. Both parts which and can be bought locally. Another plus 1JZs are neat.
cONtRol FReAkS |
09-23-2016, 03:56 PM | #49 | |
Ok well, anyways... there are a number of other cars I'd prefer to spend $20k on rather than JZ swapping a 20-30 year old shit box. $10k is my limit as far has how much I'd want to pour into a 240.
"Simplicity is the key to brilliance." - Bruce Lee |
09-23-2016, 04:24 PM | #50 | |
This goes back to just grab a SC300, they come with 2Js lol. I'd build a Boostang. Sucker is basically a badass drag/street right from the get go. Easy to build rear and suspension. If you want Auto a th400 is dirt cheap. This guy built a 200mph 1000whp stang for like $10k total. |
09-23-2016, 04:33 PM | #51 | |
Back in like 2005 Super Street listed their top $10k used car picks. It was like EM1 Si, NA Supra, GSX, and Impreza RS. They then had their $10k S13 build to show how it could stomp stock Evos and STis. |
