09-01-2016, 05:00 PM | #31 |
got an all stock 97 base model, if you'd want to trade with cash on my end as well. its all stock but it recently got rear ended. both rear quarter panels were damaged as well as the trunk and rear bumper. took it to the shop n got the damage pulled out and its all back to normal but it's just bare metal right now. needs bondo work on the quarter panels. original 5 speed with a new 5 speed installed last year. has a sunroof but it doesnt work. passenger window doesnt work as well. has around 195k miles on stock ka24de
09-02-2016, 01:06 PM | #32 | |
PM'd you back. |
09-04-2016, 05:12 AM | #35 |
Cccc
Lmao seriously???
Remove that shiit neo AFC and the blow off valve, get a stock recalculating Bov (r33 model) & I extremely urge u to get another ecu for your series rb26 s1 or s2 whatever you have and its corresponding harness, get it running !!!STOCK!!! so the ECU programs itself.. OONNCE you HAVE IT RUNNING DDRIVING NORMAL BY ITSELF. Thennnnn my friend you order a topsecret ECU tune for a air fuel controller mod and a non recalculating bov.. You cannot I repeat cannnottt run a bov without a regular ecu tune. Trust me I used to daily drive a neo rb25 s2 for years and never took a dump or didn't start on me. Its all in the tune After its running AND idling normal STOCKKKK. Its a race engine it being why its called an RB... RRACEBREA26DOUBL-exhuastcammedTurbo. The ecu is reading an air fault after the maf or at the o2 sensor. Your ecu will automatically cut fuel thinking its overflowing fuel into the pistons to prevent blowing the rings. Your fuckn welcome. Now go get a rb series maintenance book and For gods sakes order ngk lazer cut all platinum spark plugs fully synthetic oils and start over. Please fix that car, its all errors in the way you set up the fuel management and air management. Not my first "skyline not running help meee" rodeo. Its all in the tune remember.
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines Last edited by gotspins13; 09-04-2016 at 05:17 AM.. Reason: Typo |
09-19-2016, 09:41 AM | #38 | |
Thanks bud... problems solved.
