10-24-2013, 06:02 AM | #31 |
The non-vvti 1JZ uses a hydraulic powered cooling fan for the radiator. Said hydro fan runs off a pump that is part of the water pump assembly. You have two option, you can try to find a stock hydro fan (good luck) and run it, OR you can cap off/recirculate the hydro fan pump and just run electric fans. Most people convert from the 1jz hydro fan/water pump to the 2JZ water pump/clutch fan or electic fans.
Holding it and...WHEEL POPS OFF! O^O^O |
10-24-2013, 06:30 AM | #33 |
If you're going to keep the existing hydro fan/water pump assembly, recirculate/loop the hydraulic system and run electric fans; obviously, you're going to get the hydro fan related belt. If you're going to switch to the 2JZ water pump with a clutch fan or electric fans; you're going to get the clutch fan related belt.
10-26-2013, 03:41 PM | #34 |
im in the process removing the A/C compressor on my NON vvti 1jz. do i need a special support bracket to do so? all i could find in the 2j thread was that it is needed for a 2j, any help would be mucho appreciated.
11-01-2013, 03:23 PM | #36 | |
this is from the 2j thread. got no response so maybe ill get some insight here.
can anyone confirm if this works with a 1jzgte stock twins as well? the flange looks to be right |
11-15-2013, 06:31 AM | #40 | |
11-25-2013, 04:21 PM | #44 |
Hey guys am I the only one that uses this? Lol question I am looking to get a sway bar for my s13. I have a 1jz non vvti don't know if that matters, wha brands or what style sway bar do I need? Heard of these ones in austriala but I lost the guys number
11-25-2013, 09:46 PM | #46 |
Rear sump wont work with the s13 subframe you'll have to buy the upper and lower section from driftmotion or used. Most people either get sway bar spacers for stock or the sikky kit
11-30-2013, 11:05 AM | #48 |
Big question, I'm looking into makeing my own sway bar spacers, my school has a milling machine and I don't have enough to buy a whole sway bar so hs anyone made some? How long do they have to be and we'll I just need some specs on them.
02-06-2014, 03:03 AM | #50 |
Hey guys some r154 questions.. Which one fits the s chassis best? Shifter extension or no? What cars did they come in? Also what about the r154's in usdm mark 3 supras. Will that match up good shifter-wise with a jz bell housing of course? Thanks in advance.
02-06-2014, 06:28 AM | #51 |
chaser or soarer trans
http://suspectengineering.blogspot.com |
02-13-2014, 05:25 PM | #52 |
this thread honestly makes my head hurt... a vvti is nothing like a vvl sr20... if you want horse power, stay away from the vvti. The 1jz vvti is a garbage ass motor for high hp. That and finding someone that can even tune a vvti is a task in itself. And as for the price to swap, Gs Motorsports in Irving texas, Known for 240sx will sell you a 2j/5speed and install with piping and wiring for 5k. So im pretty sure this swap can be done for a hell of alot cheaper if you know what you are doing. Just food for thought.
02-13-2014, 05:55 PM | #53 |
hey guys, anyone interested in some 2jz-gte(usdm 550's) injectors with resistor??
http://zilvia.net/f/showthread.php?t=554825
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
02-20-2014, 09:56 AM | #54 |
iam willing to let these go for cheap!!!
04-12-2014, 01:46 PM | #59 |
