05-27-2013, 05:17 PM | #31 |
Man, wtf are you babbling about? If your worried about keeping the rpms below 3600 and disconnecting the turbo to stop the motor from overheating you sir need to buy a fucking honda and DD that.
Ooh I cruise at 3500 rpms on highway for a few years never once came close to overheating and my engine under rocker covers are cleaner than that. Fyi clean that swap up looks like a first time slop shop swap |
05-27-2013, 05:25 PM | #32 |
If you guys are done with this other stuff you are talking about.
I wanted to say that my car started for like 5 sec then shut off at first the fuel pressure was at 55 ish then it diped down to 20ish and now the car does not want to start. so i added a fuel pump to the list. i hope this takes car of the problem |
05-27-2013, 08:56 PM | #33 | |||
I love how your story continues to change, Now it doesn't really overheat cuz you failed to install a $10 part from autozone. Quote:
Wow you don't even know when the OEM thermo opens at correctly.. The OEM thermo opens at 170*F not 195*F What is so bad about 3,600+rpms? Do little magical elves form and start hammering on Rod bearings? If 3,600 rpm harmful to the engine why did Nissan set the rev limiter to 7,500 RPM and not 3,600? Why is it that every SR in the states not suffer from this bearing failure issue? If 3,600 was such an issue then they would have all died a long time ago. You do know when you get engines to "swap" you get the bottom of the barrel engines (much like the majority of the US) that were at one point missiles that were beat the fuck out of on a weekly basis until the chassis was too bad to drive, especially if an American owned it, cuz 70% of the time they never changed the oil in it. It's impossible to make an engine last forever without rebuilding it. Yeah oil tends to look cleaner longer when you drop the lower pan and clean out all the left over oil that doesn't come out during a regular oil change. Mine looks like that too after drift events and my 400+ mile trips for 7 hours straight. Quote:
Why not a Red top? You do know that all RWD SRs use the exact same internals right?You probably didnt though. Time and a place? a Red top is not a place? the fuck are you smoking? Why is it that my customers running stock bottom ends and a GT2871R that DD them and drift them not have any issues in Louisiana 100+ heat? I dont think one person has agreed with any of your crack pot theories, So obliviously you are wrong in every aspect
05-27-2013, 08:57 PM | #34 | |
05-27-2013, 09:09 PM | #35 | |
why would it be high at first then go low. also the hummmmming that the pump does at the start well it just stoped doing that. can that be because the filter was dirty. i live in the desert and its been 1.5 years since i crank it over been building this car for a long time. and also this setup was on another member car so the fpr should already be set |
05-27-2013, 09:14 PM | #36 | |
Never trust others ppl work, How do you know the PO knew what they were doing.
05-28-2013, 07:52 AM | #37 | |
also i do have low fuel but i did put 2 gallons can it be the filter that is fucking it up. and the buzzing that the fuel pump does just stoped. |
05-28-2013, 09:30 AM | #38 |
Buy a $14 z32 fuel filter at the auto parts store if you even have to worry about it. Also check the bag on the pumb maybe its clogged if you have a dirty tank. As far as wiring its simple if you need to check hardwire it and see if it works could be bad grounds or not seeing proper voltage. Another is get a multi meter even a cheap $20 one is better than assuming its wired right.
05-28-2013, 09:52 AM | #39 | |
05-28-2013, 10:24 AM | #40 |
also forgot to ask if anyone have a pic of the fuel lines that two metal lines that head to the bottom of the car just to make sure i connected the lines right. a pic would be cool. thanks
05-28-2013, 02:01 PM | #42 | ||||||||
Keep talking. Im sure it makes you feel better. Post up some videos of engines you've built and tuned. |
05-28-2013, 05:55 PM | #43 |
IF you are not trying to help me with my swap take that smack talk somewere else. im trying to get my swap running. since you have over 10 swaps then post you'r help on here and stop fucking up my thread.
05-28-2013, 06:19 PM | #44 |
Usually the fuel on the aeromotive units, flows in to the sides and out through the bottom. Maybe it doesn't matter with your model? just saying!
If your unsure of which line is which(feed or return)? Put hoses on both. place hoses in separate bottle/bucket, prime the pump. the one with fuel is the feed. And should go directly to the fuel rail. The other line should go to the bottom of the regulator.
05-28-2013, 06:58 PM | #47 |
I looked at my friends car and the fuel lines match up im not going to have a chance to mess with it today. I will wake up early and work on the car then and test something first then
the only thing I have check so far is the fuel pump it self. It works great so thats off the list. |
05-28-2013, 08:35 PM | #49 | ||||||||
LOL dude ive been working and building SR/RB/1J/2Z/4AG for the last 10 years Quote:
Maybe they are a dying breed down there in Florida, because Florida retards keep blowing them up or ya'lls importers buy shit engines. Quote:
I have a SR AE86 swap i literally slapped together in a parking lot with left over parts from customers thats more reliable than your cars. I never had any issues cruising on the interstate and drifting it on the track with my Red Top with a T25 running at 3,600 rpms and it had a junkyard radiator in it for a while. So yeah, this is no longer amusing beating this horse. So have a nice day.
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 05-29-2013 at 08:07 AM.. |
05-28-2013, 08:37 PM | #50 | |
dude if you cant figure out which line fuel come out of you have bigger problems. Heres a hint, undo all 3 lines apply power to pump which ever line shoots fuel out goes to the rail why the fuck is there a fuel filter on the FPR?
05-28-2013, 09:44 PM | #51 | |
Thats the fuel supply line same reason you have one in your car. I already know were the lines go. Im going to check wiring next The black/pink wire I think it got lose. Or something from there |
05-28-2013, 10:08 PM | #53 | |
The FPR goes on the return side of the system only. The FPR regulates pressure in the rail by restricting the fuel going to the tank. They way you have it set up is its regulating the fuel pump pressure in between the pump and the FPR witch is pointless It should go, pump>filter>Rail>FPR>tank where does the fuel coming out of your rail going?
05-28-2013, 10:47 PM | #54 |
the way this guy had it setup im beliving its the same hose. aka the green line in my pic.
thats why im on this fourm asking questions i have never setup a an fuel before so i just put it how he had it. |
05-29-2013, 06:39 PM | #55 |
ok guys so I took a quick look before i start to cook for my kids and the fuse is poped. So now i need to find out why it would pop then put in a new fuse.
05-29-2013, 08:57 PM | #56 |
Here's how your FPR should be set up. I can't tell from your pic exactly whats going on. Bottom line goes to the return line to the fuel tank, the line to the left is coming from the fuel rail, the other port is blocked off in this pic. You can run the line from the fuel rail to either left or right port as long as the opposite one is blocked off. This off the rail style FPR is after the fuel rail. So the order should be fuel pump-feed line-fuel rail-FPR-return line. You only use both ports if you have 2 fuel rails i.e. V6, V8, or V how ever many cylinders you have, or the fuel pressure gauge is fed from the 2nd port directly.
in any situation....thou shalt blaze |
06-01-2013, 05:17 PM | #57 |
ok guys my car is geting fuel now i fix that during the week. only now my car still does not want to turn on. i check to see if ecu has power and it does, checked each wire to each sensor one by one and they all have power, now when i was checking for power i had left the key to the on position and my coil was melting any ideas
06-01-2013, 05:30 PM | #59 | |
06-01-2013, 07:50 PM | #60 |
Your welcome. It sucks trying to figure out multiple problems all at once, especially when fixing one issue just leads you to another. As far as that melted coil goes, there is no reason leaving your ignition in the 'ON' postion should melt a coil, (it never happened to mke anyway), unless there is a bigger issue there. I would follow those wires from that coil and see if you can find a short or something. Try and break your problems into 3 catagories in the future to simplify things for yourself, Air-Fuel-Spark. It sounds like it just may be your pump, so install a new like you said and see what happens there. You can just watch the "For Sale" section on here for a few days, someone is always selling those individually or as a set for a price that won't cost you your left nut. I think they are like 80 bucks new depending on who you go through, if you just want to be sure you're getting good ones. Keep going, it'll be worth it when you drive that pig. Plus the feeling that you figured it all out and fixed it yourself instead of paying someone else an obscene amount of money to do it will make it all the sweeter.
