Old 10-10-2010, 02:44 PM   #31
puerkone
puerkone is an unknown quantity at this point
I did it and I love the swap it is awesome. =D I also installed the heads up display rev gauge on my nx cluster
best swap ever =D
puerkone is offline   Reply With Quote
Old 10-11-2010, 02:04 AM   #32
RyanS13
RyanS13's Avatar
RyanS13 is an unknown quantity at this point
best swap ever =D
I'm still trying to get this thing in haha. Hit me up.
RyanS13 is offline   Reply With Quote
Old 12-08-2010, 03:17 PM   #33
Zed Nismo
Zed Nismo's Avatar
Zed Nismo is an unknown quantity at this point
Originally Posted by projekt_s13 View Post
Tried this out using your write up and it didn't work. The two wire white plug green/white and red/black. The green is hooked up but where does the red/black one go? Also on the black nx plug it has two yellow/green wires and both are used so which goes where?
I looked on the back of the cluster but for the Black NX plug.. it doesn't show where it goes.. its just pins.. so can someone please let me know where each of the yellow/green wires from the Black NX plug goes.. as well as the red/black wire from the 2 wire NX plug.
Zed Nismo is offline   Reply With Quote
Old 12-09-2010, 03:58 PM   #34
Zed Nismo
Zed Nismo's Avatar
Nurvcom I had another question regarding the wiring. you stated that in the s13 harness.. the center white plug has a white/black wire but i can not seem to find that in my sohc harness or dohc harness.. and that it goes to the red/black wire.. but then later later you put that you have to connect the red/black wire from the black s13 plug to the red/black wire from the white nx plug.. so do i connect all three of these together? sorry i'm just really confused here. would that be the pink/black wire (instead of the white/black as you stated) from the center s13 plug to the black/red wire (instead of red/black) from the white nx plug?
Old 12-18-2010, 01:22 PM   #35
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
do i just guess which yellow wire from the yellow nx plug haha? there are 3 of them. there are alse 2 yellow green wires on the nx black plug.
SW Fab
shiftdrift is offline   Reply With Quote
Old 12-18-2010, 10:11 PM   #36
trinty
trinty is an unknown quantity at this point
if any one can get me the nx digital cluster and knows how to install in i will pay just say how much ..im in ontario cali.91761.....text me at 9098370134
trinty is offline   Reply With Quote
Old 12-18-2010, 11:21 PM   #37
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
SW Fab
Old 12-21-2010, 09:13 AM   #38
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
Has anyone figured out how well it reads 3 digit speeds?
Is this accurate all around (gas levels, temp, speed, & tach?)
Is the tach much more responsive than the speedo?
Anyone try it with single cam temp sensor yet?
I am thinking of doing this for my s13 ka24e-t and figuring out the hud at the same time.
Also how is it backlit? I'm wondering if I can the bulbs with colored bulbs. I want to match my gauges
tastyratz is offline   Reply With Quote
Old 12-21-2010, 09:56 AM   #39
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
the gas level tach and temp are accurate on mine. i have a dohc temp sensor. the speed isn't because i still have a dohc speed sensor, i'm changing it out soon.
SW Fab
Old 12-21-2010, 11:12 AM   #40
5pecialist
5pecialist's Avatar
5pecialist will become famous soon enough5pecialist will become famous soon enough5pecialist will become famous soon enough5pecialist will become famous soon enough5pecialist will become famous soon enough
Hotness!!!
5pecialist is offline   Reply With Quote
Old 12-21-2010, 10:49 PM   #41
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
mad props that cluster looks dope
yetijeff is offline   Reply With Quote
Old 01-02-2011, 01:02 AM   #42
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
So, this CAN'T be done to an S14? I skimmed through and saw the post 'to bad not for an S14', thats about it. I have a spare S14 cluster/sub-harness and would just need to get the NX stuff. Would the SOHC speed sensor trip the CEL on OBDII models? I'd love to do this if possible without setting off a CEL for a P0500.
Pacman is offline   Reply With Quote
Old 01-26-2011, 12:47 AM   #43
Dark Spec
Dark Spec's Avatar
Dark Spec is an unknown quantity at this point
I just did it on mine as well and i love it. I had problems with the wires as well since i have a newer cluster with different color wires but i went through the wireing diagrams on both the 240sx and NX1600 and figured it out... pics and vid yo.....
the vid is not that great because its off my phone
http://www.youtube.com/watch?v=hN7sDKKqp2U
Dark Spec is offline   Reply With Quote
Old 01-27-2011, 11:09 AM   #44
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Why is the cluster tripping out? lol
projekt_s13 is offline   Reply With Quote
Old 01-27-2011, 12:17 PM   #45
Dark Spec
Dark Spec's Avatar
Its just its demo mode... you can put it like that to see if all the lighting woks
on mine, 2 of the RPM sections is out
Old 01-27-2011, 12:22 PM   #46
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Not a bad looking piece, but not fond of it enough to do it on my car.
Good job either way.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 01-27-2011, 12:24 PM   #47
Dark Spec
Dark Spec's Avatar
yeah... not for everyone but its a nice peace
Old 01-29-2011, 12:56 AM   #48
projekt_s13
I think i have the same newer cluster cuz i tried out the few write ups and they didnt work. Would you happen to have some of your notes you used to wire it together?
Old 01-29-2011, 10:29 AM   #49
Dark Spec
Dark Spec's Avatar
I still need to clean them up, but yeah... what do u need to know?
Old 01-29-2011, 02:26 PM   #50
projekt_s13
Basically what wire controls illumination on the nx cluster and what wire it connects to on the 240 cluster.
Basically what color wires get used on the nx and what they plug into on the s13.
Any info is greatly appreciated.
Old 01-29-2011, 05:43 PM   #51
Dark Spec
Dark Spec's Avatar
If you mean the onefor the dimmer swich on the nx cluster then its the red with blue stripe and it connects to the same red with blue stripe on the 240 center white plug... i belive its pin 42 on 240sx plug
Old 01-30-2011, 01:50 AM   #52
Quiksilvia09
Quiksilvia09's Avatar
Quiksilvia09 is an unknown quantity at this point
Is the lighting Green or White?
They look white on the 1st page but green in your video and pix?
Quiksilvia09 is offline   Reply With Quote
Old 01-30-2011, 11:18 AM   #53
Dark Spec
Dark Spec's Avatar
Its actualy green but it has a filter that aperantly turns it to white but i took it off so it would look a little brighter
Old 02-02-2011, 12:05 AM   #54
epicdrifting
epicdrifting's Avatar
epicdrifting is an unknown quantity at this point
im getting mine tomoorow wooo hopefully i can do it
epicdrifting is offline   Reply With Quote
Old 02-05-2011, 02:00 AM   #55
Quiksilvia09
best swap ever =D
Rev guage???
Do post pix!!!
Old 02-21-2011, 01:07 PM   #56
Chaluska
Chaluska is an unknown quantity at this point
s13
I tackled this project over the weekend..
the wiring posted is close, but not exact, each NX cluster is wired the same, but the colors are different varying if its auto/manual, and year of production. my S13 wiring harness was also slightly differently colored (1991 240sx) I used the s13 FSM, and the NX fsm, compared wires, and then got both clusters, and both harnesses, and took it one wire at a time.
:::Notes of interest :::
-DOHC temp sending unit works perfectly (although cold is 2 notches above the c when cold, instead of right on the C), and the digital temp gauge reads much more accurately.
-DOHC Speed sensor reads DOUBLE, and if wired perfectly, will still maintain a 115mph speed cut, so that means you can go 56 mph, before the engine cuts.. which SUCKS. definatley need the sohc sending unit.
-Gas gauge is accurate
-tach is accurate
Ill let the pictures speak for themselves.
also, for any interested parties, this is a VERY accurate gauge of how bright it is during the day.
Chaluska is offline   Reply With Quote
Old 04-05-2011, 11:59 PM   #57
Quiksilvia09
So can you use a SOHC Speed sensor on this cluster?
Old 04-06-2011, 12:06 AM   #58
Dark Spec
Dark Spec's Avatar
depends on what cluster u get
if im not mistaken the sohc sensor worx only for the 91-92...mine is from a 93 and it was reading doble with both the sohc KA and s13 SR sensor but fixed it and now reads right or 1.5 miles under what the cluster says
Old 04-23-2011, 03:37 AM   #59
alohaworld
alohaworld is an unknown quantity at this point
i would like to see someone take time out of their life to wire them up and put em up for sale... i wonder how much they would go for... nice shit though
alohaworld is offline   Reply With Quote
Old 04-24-2011, 02:28 AM   #60
Dark Spec
Dark Spec's Avatar
i wouldnt mind doing it, its just they are getting harder to come by and to sell it with the wireing all done and proper speed sensor would probably cost upwards of $200 and not a lot of people are willing to pay that for a used cluster
