07-23-2010, 04:13 PM | #31 | |
i cant track, because a cage is too heavy (tracks dont require cage), so instead i'm gonna drive fast next to cliffs? wut |
07-23-2010, 05:10 PM | #32 |
Part outs make this place go round? Are you assuming that Imma wreck my shit?
I hope not, speaking of haters. Damn playa whats wrong with Santa Rosa? And tracks dont require a cage? Where are you from? At my local track they require one. |
07-23-2010, 05:30 PM | #33 | |
The OP can go to V8Silvia and find dozens of unfinished projects. Daily driveable LS1 S-chassis is really rare to come by. Most LS1 projects are heaps in the storage sheds with no more than hopes and dreams. It takes a LOT of work to pull off the swap in an S-chassis, or money. Most times. Both. I'm on my third iteration with this engine. The first time was a total wreck and I learned what not to do. The second go-round was better but not perfect to what I wanted. The third time is when everything fits perfectly and runs harmoniously. Most of this swap will require you to do your own research since it's not as well documented as a regular SR swap. While it's true that the LS1 hs a lot of documentation, the problems you will have come up when you try to work the drivetrain into the chassis. If you can pull it off for $10k then you're a lot smarter than the average S-owner. If you can pull it off for $7k then you either have some serious hookups or serious skill, or both. When pricing a project like this it's better to be high and have extra money leftover than to be low and don't have enough money to finish the swap. Look on V8Silvia. Now when I convert my backup car, it will cost me less than half of what I spent on the first car, but that's from applying what I've learned in the process. It's not as easy as people make it out to be. I agree. The price for the subframe work alone is a lot. My mounts use the stock subframe. I can pull out the V8 and swap in a KA/SR today with no extra work. |
07-23-2010, 07:13 PM | #34 | |
OP-you should definately do it, itd be a blast to drive everyday but be careful!
Waiting to have my Username Fixed. |
07-24-2010, 01:21 AM | #35 | |
I have a stock S13 that I was thinking about doing an LS1 swap to. I have slightly below average intelligence so smarter people can get by with less. If I did all the work myself, I wouldn't be comfortable with a budget of no less than $13k to have a fully driveable daily with all the features that a stock S13 has. T56 prices have gone down a bit since 5 years ago probably because this swap is geting more popular. LS1 prices are pretty much the same. So are all the accessories. Let's price out the other stuff: Sikky mount kit: $1750 GMPP engine harness: 1700 GMPP ECM: 600 That's already 4 grand on top of the $6.5k drivetrain. You still need: intake and filter radiator hoses radiator fan heater hoses headers downpipe and possibly custom exhaust speedo and tach power steering lines a bunch of other things I didn't bother to list So if you're already over 10g before you add these parts, $15k would still be a bit uncomfortable even if I did all the work myself. |
07-24-2010, 01:29 PM | #36 |
My bad its Johny5...
I paid 2200 for a wrecked 02 z28 with only 52xxx that had a t56...i saved about $1300 to $1500 on that deal but I had to drop the engine myself, but that was no big deal. Im about to get my ls1 s14 done for less than $7500... I have: Sikky Mount Kit with alum. DS and solid mounts Sikky Willwood clutch master cylinder conv. Sikky PS lines Daft Innovations fuel system Bought an s14 lsx exhaust from a guy that wrecked his ls2 s14 BBK shorty headers from a 2000 Corvette then i am going to get a straight pipe welded onto that goes to the exhaust Mishimoto KA radiator w/ I-sis efans Sikky wire harness service and btw I have a brand new Walbro 255lph intank fuel pump for sale if you need it http://zilvia.net/f/sale-items/33355...brand-new.html |
07-24-2010, 04:02 PM | #37 | |
What ECM will you be running? TIP: You can save a little bit of money if you run the headers into a single downpipe and run that into the stock cat. Then you can use a regular S13 cat and catback exhaust. |
07-24-2010, 04:21 PM | #38 | |
07-24-2010, 04:23 PM | #39 | ||
the ls1 stock PCM is just like a stand alone so it can be completely retuned, so im just going to use it and get a tune in the near future msglnght.. |
07-24-2010, 04:40 PM | #40 | |
So you're up to almost 6.5k plus welding labor. What other parts are needed? Does the car run? |
07-24-2010, 09:35 PM | #43 | |
It shouldnt have any codes... Not sure what you mean by OBD II EVAP? like as in emmisions stuff/EGR? The only other parts i will need is some radiator hoses and coolant and oil and i need a PS hardline bc one of mine is crushed, and some radiator tab things...mostly just small stuff, that I know of........................... |
07-26-2010, 11:39 AM | #44 |
G6civcx i would be stoked to see pics of your setup. What engine are you running? I looked over your posts but I really didn't see for sure.
Thanks again for everyone's insight. |
07-26-2010, 09:58 PM | #45 |
Generation 0/I pre-1985 small block chevy.
Some baseline measurements for reference. This is a stock single cam KA. The first measurement is from the rear of the core support to the front of the block. The second measurement is frm the bottom of the valve cover to the hood ledge. Small block chevy dimensions: http://www.enginefactory.com/chevdimensions.htm LS1 dimensions: An LS1 is 28.25" from oil pan to the top of the engine. My small block is 22" from the bottom of the oil pan to the top of the valve cover. Then you have to add the intake manifold, carb, and air filter. |
07-28-2010, 01:45 PM | #46 | |
07-28-2010, 02:43 PM | #48 |
I want something more reliable. I have an SR20 with a 2871 turbo and I cant figure out why its now misfiring. I blew the boost sensing hose off the turbo piping and ever since then, Ive had a nasty misfire after 3500 RPM. I changed the plugs, to no avail. Ive checked all the boost piping, all tight. Im sure its not the MAF being dirty cuz it worked fine before the mishap. Ive checked the coils for cracks or anything out of the ordinary. No dice. Its making me crazzy and I just want a car that runs great and I dont have to hunt down gremlins all the time. I cant really leave it anywhere to be looked at because Its my only DD. I bought cheap NGK copper plugs, and gapped them to the same as Blacktrax (in San Jose) gapped my iridium plugs at, which was .025.......still shitty. Like I said, it ran AWESOME until the boost hose came off the piping. Now it just sucks. I dont know what to do!!! I feel like ive run out of options.
08-06-2010, 06:03 PM | #49 |
civ6cx still havent seen any pics of what you have. The KA24 measurements dont do anything for me, since not only do I not own a KA24, also i know exactly what those measurements are. Everyone does. The thing thats missing is your custom build, didnt you say you have the engine 6 inches into the firewall? sounds like quite a job. I want to see. I have not come across anyone who has done this yet, but then again, ive only looked at like 20 or so build threads.
08-10-2010, 11:58 AM | #50 |
i know youve only got good aspirations for this project, but man do your learning fiorst. if you cant diagnose a misfire, then id say spending upwards of 15k on a non native engine swap is not in yopur best intrest.
im really not tryinbg to be a dick, but id learn what you have first, then reconsider.
"just throw in like 8 packs of BBs and do a burnout. DIY shot peen, done and done." |
08-11-2010, 09:26 AM | #52 |
I diagnosed the misfire, it was a broken ground on the coilpacks. Anyway, I appreciate your halp, but its not really something im going to listen about anyway. Good thing im not spending 15K, only 10K hahahaha....its basically the same, I know. Whatever, did you read my first post? Do you own a LS1 s13? No? Have you driven one? Well, thanks for the input i guess...
09-19-2010, 09:04 PM | #53 | |
09-24-2010, 05:43 PM | #54 |
[QUOTE=gippy87;3646538]The ls1 your giving specs on there looks like its a truck ls1 which has a bigger intake mani, not sure on how much bigger but deffinitly sits higher. heres my ls1 with sikky mount kit. it sits very nice and id say even closer to the firewall then my sr was.
Ya, your pics look very similar to the way mine sits. Crazy, im using the Sikky stuff too. We will just have to see how different the handling is ourselves, huh grippy87? How close are you to finishing your project? I just got to make exhaust, do the wiring and hook up the fuel. Im pretty excited.
As long as you're not a ham-fisted retard there shouldn't be a problem. |
09-24-2010, 08:21 PM | #55 |
I'm very excited to see how it performs. I've had a 350rwhp SR and it was awesome so I hoping this is equal or better. Also I'm down to fuel Wiring and exhaust as well. My fuel filter/regulator came in I just have to install it. Also my exhaust piping came in so I just need time to make up a y pipe. Wiring was easier than I thought but I still haven't tested it. I'm hoping for a first start within the next couple of days
10-20-2010, 09:27 AM | #56 |
YouTube - IMG_0070.MOV
I need to fix the idling issue. Other than that, just gotta build the exhaust and cooling system, and extend the wiring harness. So stoked! Cant wait.
10-30-2010, 02:51 PM | #57 |
I've been watching this thread for a while and decided to ask the obvios qu
estion no oneasked the op, What problems are you sr giving you? Not enough torque I assume? 270hp isn't bad in a small car. I drove my friends ls1 s13 while he was in Iraq 2 years ago. It was very fast and had lots of torque accross the rpmband. Whenhe told how much he spent on the swap I laughed my ass off. I won't tell because I don't want to start another 2 page price war. But it wasn't cheap! I just bought another 240 and if I do a swap it will be for a vg30et from a z31. I had sevral early model z31 cars,and it will make good power cheaply. I can get a running vg dirt cheap. My friend sold the 240ls at a big lossand bought a 95z32tt with 45k miles for 10 grand.its a much better daily driver. Having build and driven v8 for all my life yourtires will need to be in the 10" to 12" width range to maimtain any traction LSD is also a must. Btw most cars go off the mountian front first mabey im full of shit, I like my ka and pop up headlights. |
11-01-2010, 02:37 PM | #58 | |
Anyway I wanted the LS1 because Im kinda an idiot. I know its going to throw the chassis off a little bit and it has more TQ than I really need. The 270WHP SR was a lot of fun, but it kept giving me problems. I just want to have a reliable, fun S13. Its not cheap. I could have an S2000 or something like that for what I paid. My next purchase is 18x9 and 18x10 wheels. I do have a Kaaz 1.5 way so that is good.
