Old 02-20-2009, 12:50 AM   #31
Almedarj
Almedarj's Avatar
Almedarj is an unknown quantity at this point
Send a message via MSN to Almedarj
I like the info charles gave thanks man and i am sticking with an na/ka and already have an intake, 3" cat-back, test pipe, spark plugs + wires, stage two clutch act, and flywheel i just need the other stuff and is obx a good header i've heard other wise
Almedarj is offline   Reply With Quote
Old 02-20-2009, 01:17 PM   #32
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
Thumbs up
Originally Posted by J90lude View Post
Boost!!!
cant argue that fact eitehr 9 psi made 311 whp and 279 wtq here
Jus Skott is offline   Reply With Quote
Old 02-20-2009, 01:32 PM   #33
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
You only listed two things that don't transfer over to turbo cars. Why do people even ask for advice when they don't want to listen to it? Save your money and go turbo, or sell your NA parts later for 1/4 of what you paid when your car is still slow and you realize turbo was a better option.
DRIFTINDY
txrxs is offline   Reply With Quote
Old 02-21-2009, 12:46 AM   #34
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
buddy is making 165whp on his ka..
for the amount of work he's put into it.. not sure if it's really worth it.
talked to him today said he probably put 1k into it :|
JRas is offline   Reply With Quote
Old 02-21-2009, 02:41 AM   #35
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
More info on your setup, please. lol
There's some guys on KA-T.org making 330+whp at 10 psi, but they don't like to give specifics about their specs.
Yeah, not worth it at all. I could EASILY put together a turbo kit good for 200+ whp for about a grand.
N/A is cool... but not for KA's. Too much money and effort for too little payoff.
-Kyle
Old 02-21-2009, 02:43 AM   #36
soreballz
soreballz's Avatar
Trader Rating: (22)
Oops, double post.
-Kyle
Old 02-21-2009, 02:59 AM   #37
Jus Skott
Jus Skott's Avatar
Thumbs up
lol roomie just dyno'd 140 whp on a once cam slam (KA24E) w/ a few bolt ons. ZOMG advanced timing, egr and pcv delete, a/c deleted, power steering delete, electric fan, gutted cat and a little grinding of the intake mani at his pops garage.
lol my motor came from one of the member on there. but it had a blown head gasket and i have reworked a few things since then.
enthalpy tune.
msd 6a
msd 8207 blaster coil.
9:5:1 aries pistons
248 91 ka24de cams
D/W 750cc side feed
T3T4 50/.63 ar
38mm tial wg
spearco IC
hks ssq bov
egr delete
z32 mass
apr head studs
3 layers of a cometic hg
comp clutch stage 4 6 puck
oem weight flywheel.
3" exhaust all the way back.
shimmed j30 diff otw (prob. will fail.)
I can tweek a bit more out of it. but you know order parts online and ya have to play the waiting game.
Old 02-21-2009, 11:48 AM   #38
JRas
JRas's Avatar
well the thing is he already has an SR.. believe it or not he drives the KA track car more.
he did a high compression build on the ka, using sohc pistons to raise the compression.
than he made custom ITB's.. mind it's a lot cleaner now this is right after he finished making it.
Old 02-21-2009, 01:13 PM   #39
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
I'm still dying to super charge a KA but I haven't seen the results to warrant the money so far.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 02-21-2009, 01:17 PM   #40
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Boost.. I was thinking of doing NA/KA but that looks like too much money and work. I had the same idea in mind has you do.
I plan to boost my KA but only a bit not too much. Take your time and research. Go to KA-T.org look around.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 02-21-2009, 01:28 PM   #41
Shift_Dr1ft
Shift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enoughShift_Dr1ft will become famous soon enough
N/A KA is cool, but your better off spending that money on a turbo kit or a supercharger. If you bought headers already then supercharge the KA.
Shift_Dr1ft is offline   Reply With Quote
Old 02-21-2009, 08:20 PM   #42
Almedarj
Almedarj's Avatar
a supercharger would be cool and different but i cant find a superchager kit am i not looking hard enough and its not that i dont want to boost its just i'm not doing that on this car i can get another one to do that to i want an na/ka because i want to see what i can get outta it.
Old 02-21-2009, 11:57 PM   #43
kingkilburn
Philosopher King
There isn't really a viable kit for super charging. If you are really interested there is a section for it on KA-T. It seems fairly simple to do if you can do a little fab work.
Old 02-22-2009, 12:41 AM   #44
Jus Skott
Jus Skott's Avatar
IMHO if your are looking to go NAKA or SCKA do yourself a favor and find a friend that can fab and weld. you'll be better of in the long run.
Looking for yard parts, PM me.
Old 02-22-2009, 12:59 AM   #45
Shift_Dr1ft
Supercharging will require some fab work. Check on KA-T.org they have lots of great information there. If you want to buy a supercharger kit for the KA try talking to Thomas Knight, I remember a while back he made some kits and sold some. He has a website, google him up.
Old 02-22-2009, 09:57 PM   #46
Almedarj
Almedarj's Avatar
okay so if i were to supercharge the ka i could just use the spot were the old power steering pulley was mounted right and just have a buddy fab a bracket to work off that and would i need to get all of the same shit i would need to get for a turbo setup as well if i'm just gonna run like 7 to 10 psi
Old 02-22-2009, 10:25 PM   #47
kingkilburn
Philosopher King
Ideally you want the super charger on the intake side but if you run a centrifugal charger you can put it any where.
This is the conventional way;
With the charger used in this pic I think all you need is the proper size pulley to run it in its optimum range and an intake run to it. Look up nomadtrash, it's from his car.
Old 02-22-2009, 11:58 PM   #48
mondojackal
mondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choices
Send a message via AIM to mondojackal
Originally Posted by Slo_Slidewayz View Post
^^ What he said...
With every bolt on possible, Im thinking youre looking at about 150-160ish... Add to that some light wieght shiz (wheels, flywheel, 1-piece driveshaft, etc etc) you will have plenty of pick up to fool around with on a day-to-day basis.
Once you bring "high comp" into the mix, thats when it gets really pricey. Fuel management, ECU, tuning, and gas alone are just askin for lots of dollas lol
The KA will make a decent amoutn more than 150-160 with full bolt-ons. A healthy KA with I/E will make 155whp.
With full bolt-ons, it should be around 175whp.
mondojackal is offline   Reply With Quote
Old 02-23-2009, 12:59 PM   #49
Almedarj
Almedarj's Avatar
okay so i did some lokking into supercharging the ka and only like three people have it completed i'm thinking i could just use a kit off the infinity G and place it on the exhaust side using the mounting pionts from the powersteering pulley to mount the s/c. and as far as i know at 7 to 10 psi i would be as quick as sti's and evo's wich is pretty good especialy since they wouldn't expect to be passed or for me to stay next to them without seeing a FMIC
Old 02-23-2009, 01:51 PM   #50
kingkilburn
Philosopher King
I don't think you will be making gains that big but if you do the entire car with that goal in mind it's not an unrealistic goal.
Old 03-02-2009, 08:50 PM   #51
Almedarj
Almedarj's Avatar
okay so i talked to some people and they've suggested giving it a go and i can't see why not if i was originally looking to get only 200hp two the wheels 230 to 240 to the wheels is better and for less money just more time involed and it would be really cool and different
Old 03-04-2009, 12:41 AM   #52
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
just so you know. a 3" exhaust is not the best for a na ka. 2.5 is the largest you want to go. 3" actually creates more back pressure than 2.5 because it allows the gases to cool faster which makes them more dense and harder to push out the pipe.
my car= reman kade, injen short ram, stock cat, resonator, 2.5" resonator back=142whp, 151wtq
with the 3" the day before it made 137whp, 148wtq.
now if you go forced induction like everyone here wants you to, then my statement is null and void. good luck.
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 03-04-2009, 05:26 AM   #53
slo_slideways
slo_slideways's Avatar
slo_slideways is an unknown quantity at this point
For what NA KA? For YOUR application, 2.5" did yield better performance gains, but don's jump to conclusions and say a built NA motor should run the same exhaust as your stock motor. On a KA that is even mildly built NA (little bit more than just intake/exhaust), a larger diameter pipe will be more beneficial...
A higher HP motor needs to push that gas out faster. A higher comp motor has more gasses to get out and needs them out faster, especially if valve lift/duration have been modified. Too much back pressure is lack of win and there needs to be a happy balance between flow restriction and velocity. You want the exhaust to exit the combustion chamber and speed along at the highest velocity possible - you want a FAST exhaust flow.
On the NA KA I am building (full rebuild, overbore/high comp pistons, dual exhaust cams, dual valve springs, titanium valves, port/polish head and intake manifold, fuel system upgrades) I'm sure as hell not gonna run a 2.5" inch exhaust when I'm done. I'll be running a custom 3" mandrel bend full exhaust with a custom header as well.
I doubt this guy is gonna be running a 2.5 exhaust any time soon...
Originally Posted by Greaser_
Its an insane drive. Spins 275's out back like a turbo car.
REPPIN' NORCAL HARDER THAN HERSHEY'S TURTLE SHELL CHOCOLATE SHIZ!!!
slo_slideways is offline   Reply With Quote
Old 03-04-2009, 11:16 AM   #54
jspeedm
jspeedm's Avatar
Trader Rating: (26)
^^^^Nice setup. i agree with you, but the op was originally talking about just bolt-ons, which would benefit more from 2.5".
Old 03-04-2009, 09:36 PM   #55
Almedarj
Almedarj's Avatar
true i was looking for bolt-ons at first but a little help with other ideas is not bad either and supercharging my car with a centrifugal supercharger would be a super sleeper setup as i wouldn't need a bov because it can freewheel because its got a oneway bearing
Old 03-06-2009, 11:14 PM   #56
rex2sx
rex2sx's Avatar
rex2sx is an unknown quantity at this point
If i amy correct you. The reason your 2.5" helped make more power was becuase it aided in cylinder SCAVENGING. A 3" pipe DOES NOT create back pressure. Pressure is like a measurement of restriction. So what youd be saying is the smaller or bigger you go, no matter what the more backpressur you will see, NO. If you blow through a small straw and a big straw, which one flows more velocity. If you blow through the big straw you flow more AIR or VOLUME. Thats he same thing with exhuast. The smaller pipe flows so fast it pulls the exhuast gases with it. The bigger you go the the slower the engine flows meaning that exhuast gases will not leave the cylinder as fast. Scavenging and backpressure are different. Big pipes hurt scavenging. Small pipes or bends gain backpressure.
Backpressure is not good.
rex2sx is offline   Reply With Quote
Old 03-07-2009, 02:25 PM   #57
Almedarj
Almedarj's Avatar
what did all of that bs mean just give a simple answer please because i already have a 3in exhaust
Old 03-07-2009, 02:39 PM   #58
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Originally Posted by NikeBoy355
Rebuilt S14 KA24DE
eBay intake
Greddy 80mm downpipe
Buddyclub Spec 2 80mm exhaust
80mm testpipe
That's it...
155.0 WHP
155.9 WTQ
KA's love to breath. Stick to the 3". The myth about the KA needing a 2.5" to make more power has been just that, a myth.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 03-07-2009, 02:41 PM   #59
soreballz
soreballz's Avatar
Trader Rating: (22)
You're fine with the 3inch.
-Kyle
Old 03-08-2009, 10:47 AM   #60
jspeedm
jspeedm's Avatar
Trader Rating: (26)
scavenging is done by the exhaust manifold or header by timing the high and low pressure exhaust pulses with each other.
Pressure is like a measurement of restriction. So what youd be saying is the smaller or bigger you go, no matter what the more backpressur you will see, NO. .
absoloutley.
any change in the diameter from the manifold flange creates a venturi
If you blow through a small straw and a big straw, which one flows more velocity. If you blow through the big straw you flow more AIR or VOLUME. Thats he same thing with exhuast. .
a straw is straight and does not change diameter and also you're not going to get 100 degrees of temperature change in a straw. so that analogy is pointless.
The smaller pipe flows so fast it pulls the exhuast gases with it. .
as stated above, it is the low pressure pulses that pull the gasses out.
The bigger you go the the slower the engine flows meaning that exhuast gases will not leave the cylinder as fast. .
that's backpressure
Scavenging and backpressure are different. Big pipes hurt scavenging. Small pipes or bends gain backpressure..
the only way for an exhaust pipe to hurt scavenging is by creating backpressure in the manifold or header and shortening the exhaust pulse width. but yes, bend in the pipe do not help.
well that's true.
the fact is that the op already said he wanted to go forced induction of some sort. so his 3 inch will be just fine.
all motor, ka24de, na/ka
