Old 07-26-2015, 10:34 PM   #31
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Jayzusus! I don't follow the threads any more like that but this.....this just brought me back to what interested me about cars. F-in love it dude!
2muchboost is offline   Reply With Quote
Old 07-27-2015, 07:34 AM   #32
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
wow... just wow.
Awesome build man. The best of everything. Change nothing.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 07-27-2015, 08:13 AM   #33
TheRealSy90
TheRealSy90's Avatar
Looks like you are using 350z axles with adapters to the 2x3 stub shafts. I'm guessing they are the Maverick adapters? Have you had any issues using that setup? I tried the same adapters and axles on my coupe, after installing everything i drove it around the block to check that it all worked and both inner cv's failed and fell apart inside the adapters... So that was a no go and I went back to stock axles It seems like that the adapters having the centers machined out leaves nothing to hold the cv grease cap and internals in the cv so everything just popped out and broke.
Such a good signature.
Old 07-28-2015, 01:53 AM   #34
braydo25
braydo25 is an unknown quantity at this point
Yes, I'm using the Maverick adapters with Nismo z33 axles
Interesting, perhaps bad axles? I haven't had a problem yet - the car however hasn't seen the track up to this point either.
I know specifically you can experience issues with these axles if you run negative camber, or don't have a wide enough rear track width to allow play in the joints with compression / rebound of the suspension (Why Maverick requires 0 camber on factory rear lca's). I am however running wisefab in the rear, which has widened my rear track to the point of fitting the axles great.
I will definitely post up if I begin experiencing issues.
braydo25 is offline   Reply With Quote
Old 07-28-2015, 03:53 AM   #35
TWest
TWest's Avatar
TWest is an unknown quantity at this point
Looking good.. sub'd.. I want to see this thing on the track
TWest is offline   Reply With Quote
Old 07-28-2015, 06:37 AM   #36
TheRealSy90
They were good axles, and I was running 0 camber. I think the rear track actually needs to be widened a bit for them to work properly. So maybe you will be good with the wisefab rear.
Old 07-28-2015, 03:43 PM   #37
braydo25
Coming very soon!
Old 08-01-2015, 12:49 AM   #38
braydo25
Alright! This thing is ready to hit the track! Here's some teaser pics of it 99% finished!
Enjoy!
Old 08-07-2015, 08:33 PM   #39
braydo25
Hey guys, got this thing out for a track day and a good shake down.
We ran into a couple issue with the car but I was still able to get a small feel for what this thing will be when it's 100%.
The main issues for the day were my accessory belt flying off every run due to the amount of torque the motor makes (Common JZ problem) and me not having a tensioner lock or anything else on the tensioner.
The other, more irritating issue was my boost control solenoid shitting out every now and again causing the car to spike boost and hit my overboost cut, which shut the cars revs to 4500 rpm and just dumped fuel - you can easily here when the car is doing this in the video, the whole tone of the motor will change under throttle, and places where I should be taking a high line I'll be taking a super shallow one
Anyways, enjoy!
https://www.youtube.com/watch?v=zE9B-rad-x4
Old 08-07-2015, 09:05 PM   #40
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
You guys call rich at xcessive for the idler belt lock? Normally on the shelfs at all times. And i forget but is yours VVTI or non VVTi?
http://www.xcessivemanufacturing.com...step=4&pid=363
Dustxking is offline   Reply With Quote
Old 08-08-2015, 11:49 AM   #41
braydo25
Yep, actually ordered that 2 days ago - just got here
It's VVTi
Old 08-08-2015, 12:11 PM   #42
Dustxking
It's VVTi
Awesome! Works wonders, best thing I ever purchased for the 2j. My vvti though had to be revamped to do the tension pulley being a different style then non vvti. My year vvti had a nut to bolt style tension, where the xcessive is setup for the bolt style tension. Hopefully yours isnt like mine. If it is you will need to have Rich switch it up.
Old 08-13-2015, 12:02 PM   #43
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Kit should be around $2,000~ for everything to mate a dogbox and get it working with a 2jz.
plus another $8,0000 for the dogbox. I hope one day to be able to run a G-force GSR.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 08-19-2015, 08:38 AM   #44
braydo25
I paid $5,000 for mine through RTS - got a rebuilt one with used case and works fantastic.
Old 08-19-2015, 12:10 PM   #45
Mitsubayati
Trader Rating: (18)
That's a good price. G-force South sells their rebuilts for more than that. Does RTS have a website?
Old 08-19-2015, 01:03 PM   #46
Hatemy7
Hatemy7's Avatar
Hatemy7 is an unknown quantity at this point
Gawwwwwwdddddd dayum!!!!!!!!!!!!!!
Hatemy7 is offline   Reply With Quote
Old 08-22-2015, 11:09 AM   #47
CARkid
CARkid is an unknown quantity at this point
wow.... that's an insanely awesome car
CARkid is offline   Reply With Quote
Old 08-23-2015, 08:33 PM   #48
braydo25
Some testing from last week on the Evergreen Speedway 5/8th's bank.
First time hitting it, lines were pretty awful to start until I figured where I could throw the car and grip up before hitting the wall.
https://www.youtube.com/watch?v=WDSB5zBUMKo
Old 11-19-2015, 08:32 AM   #49
edhogan1224
edhogan1224 is an unknown quantity at this point
http://www.ebay.com/itm/Nissan-240SX-SE-/331712152833
Looks like this car is for sale
edhogan1224 is offline   Reply With Quote
