Old 03-15-2011, 10:53 PM   #5071
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
I wired up my boost gauge today, but now when I turn the car on, it dies. Vacuum leak?
Ramonesfreak2010 is offline   Reply With Quote
Old 03-15-2011, 11:14 PM   #5072
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Possibly, but doubtful. Sure you hooked it all back up?
Originally Posted by chiboy002 View Post
Oooh ok, thats probably the reason cause i had an old ass, 2002, alpine head unit paired up to it which was HORRIBLE. Upgraded to a new alpine and everything was cherry, i love the usb deal but i need a chord, i get scared i'll hit it on an upshift to 5 and break it off lol
Older after market units certainly have shitty radio reception, regardless of brand or quality. Either way, I don't listen to much radio in the car as it is, so the USB made sense for highway usage.
In regard to hitting it, it's not really in the way where it is. Cords are like 5-10 bucks online or even at Best BUy or similar.
Originally Posted by smoked240 View Post
P cause once it gets warm It doesn't do it. Could it just be the gear lube?
Did you bleed the system and adjust the pedal properly? Try that first and see how it works.
Old 03-16-2011, 12:16 AM   #5073
ItsTravis
ItsTravis's Avatar
ItsTravis is an unknown quantity at this point
i got a question, why does EVERYONE gotta hate on the LS engines, i dont get why people get so bummed about a big engine going into a super light weight car??
ItsTravis is offline   Reply With Quote
Old 03-16-2011, 12:43 AM   #5074
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
^ Blame the purists and jdm fanbois.
-Kyle
Old 03-16-2011, 01:26 AM   #5075
Wake
Wake's Avatar
WTF is wrong with being a purist?
I mean I understand the concept behind it, I just personally dont like what V8's have done to drifting.
Im a purist in the form and function of my cars yes. But I am also a purist in the sense that I think people should learn how to drift using the proper techniques instead of just throwing power and torque at it.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 03-16-2011, 01:30 AM   #5076
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
what is wrong with using raw power??? lol,
The reason most people hate v8's is that reason. its alot easier. But wtf a stock dual cam ka with right lsd/ suspension is enough. when the motor runs right anyways.
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 03-16-2011, 01:33 AM   #5077
Schassis707
Trader Rating: (18)
Originally Posted by K_style View Post
Complete stock S15 SR20DET limps after stops at signal light.... thought spark plugs but they are good...
I searched and limping related is Knock sensor...
What could it be?!?!?!?
Limp mode, ecu.. many things can cause this, bad timing, maf, like you sai the knock sensor itself, I know on my KA my o2 was unplugged and my car ran like shit and continued bc my ecu was in limp mode. not wanting to deal with anything i swapped the ecu and all good now
Old 03-16-2011, 10:59 AM   #5078
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
It only does it rarely... maybe once a day....
does S15 have OBD-1 ? or 2 ? I haven;'t checked the ECU but wonder if I can see self diagnostic LED...
Old 03-16-2011, 11:01 AM   #5079
Wake
Wake's Avatar
S15 would be OBD-II, as well as pretty much anything after 96
S.P.P.S. Member #00
Old 03-16-2011, 11:22 AM   #5080
axiomatik
axiomatik's Avatar
Originally Posted by ZenkiKid View Post
anybody know the answer???
IIRC, CA18's and KA24E had the same tach signal. SR's and KA24DE's had the same tach signal. So look at your cluster, and determine if it's CA or SR (pretty sure redlines are different). That should tell you if it's compatible.
Old 03-16-2011, 11:51 AM   #5081
K_style
K_style's Avatar
Trader Rating: (63)
That applies to U.S spec vehicles... not sure if japanese domestic vehicles have same OBD-II ...
Old 03-16-2011, 01:56 PM   #5082
Fearell
Fearell's Avatar
Fearell is an unknown quantity at this point
Anybody know somebody in MD that does custom wiring?
IG: slideonkranze
Fearell is offline   Reply With Quote
Old 03-16-2011, 02:14 PM   #5083
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Yup. I first tried doing it with that dumb box that is on the s13. I can't remember exactly what it is, but useless. It wouldn't bleed with that. bypassed it and then I finally got it bled. I even did it 2 other times after that to make sure. Still the same.
smoked240 is offline   Reply With Quote
Old 03-16-2011, 02:35 PM   #5084
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
i got Q45 differential with ABS and 2 right side z32 tt axle will i have a problem putting it on my s14 with out ABS??? please help i need to know for sure before i put it in my car
Old 03-16-2011, 03:55 PM   #5085
uLmighty
uLmighty's Avatar
uLmighty is an unknown quantity at this point
Send a message via AIM to uLmighty
does the JDM OEM headlights for koukis bolt right on to USDM koukis? or do you need other wire harness for the bulbs/lamps to get the headlights working?
uLmighty is offline   Reply With Quote
Old 03-16-2011, 05:35 PM   #5086
chiboy002
chiboy002 is an unknown quantity at this point
oil shot out from my motor just now, i know the problem and fixed it but the car was running for about 45 seconds - 1 minute MAX just pouring oil out. After i realized i immediately shut it off. Very little oil/pretty much nothing in the pan
How bad can the damage be? The oil, what ever came out of it, seemed to be pretty fine - fresh oil so if there was debris it was from the motor just then.
street dancer.
GLEAM
Old 03-16-2011, 07:50 PM   #5087
Mista Lee
Mista Lee's Avatar
Trader Rating: (26)
Mista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud ofMista Lee has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to Mista Lee
I don't have another s chassis to look at so here's my question..
Where does the big ground from the main harness connect to? I did the battery tray but once I connect the battery it'll start smoking.
Boo I have no friends.
Mista Lee is offline   Reply With Quote
Old 03-16-2011, 07:59 PM   #5088
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Just picked up a 1.5 way, besides taking it in for it to be checked. Any way i can see if its worn out or needs a rebuild?
If im switching it from an s14 to s13 casing should i still take it in for pre load & back lash adjustment?
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 03-16-2011, 09:03 PM   #5089
towlie
That sounds kinda gnar. Where was the oil coming from? What was the previous problem? Could be a very bad gasket leak or cracked oil pan, somewhat easy repairs (if you know what youre doing)
Old 03-16-2011, 09:27 PM   #5090
chiboy002
it was pretty awful, like a black explosive diarrhea coming from my car
It was cause my sandwich plate was seated wrong, there was a gap and when the pressure built up it just squirted like a porn star.
I just wanna know the severity of the damage, which i'm almost positive it isnt much
street dancer.
GLEAM
Old 03-16-2011, 09:35 PM   #5091
towlie
Clean it up real good and throw a new o-ring/gasket on it. No harm no foul. As long as it didn't run for long on minimal oil your straight
Edit: hope you werent doing any ricer revs lol. As long as it was just idling it should be fine... My buddy forgot his oil cap when we added a quart to his KA once, didnt realize until his 'oil pressure' light started winking a few miles down the freeway.. Oil was everywhere all over the bay and shit, cleaned it up and topped it off it still ran fine. Use brand name oil and make sure it's flushed. Keep a close eye on all fluid levels. Let It idle and make sure rpm's/temp gauge is all normal, then forget about it.
Old 03-16-2011, 09:35 PM   #5092
iLOVEASIANGIRLSS
iLOVEASIANGIRLSS is an unknown quantity at this point
can sum one tell me if this clutch kit is worth gettin? thanks
EXEDY CLUTCH KIT & RACING FLYWHEEL 91-98 NISSAN 240SX - eBay (item 400203084172 end time Apr-15-11 12:24:35 PDT)
Pearl White 95 base S14
iLOVEASIANGIRLSS is offline   Reply With Quote
Old 03-16-2011, 10:29 PM   #5093
chiboy002
yeah naw dude it was chilling outside my garage and i noticed very frequent oil drops from when i pulled it out, nearly shat myself when i saw it lol. I'll be monitoring the pressure via some better gauges as well as oil temp. RPMs were a tad bit on the high side but i wouldn't doubt thats cause i fucked with IACV 3 days ago haha, i also have an alternator problem so w.e
Thank you for the help, i was worried
street dancer.
GLEAM
Old 03-16-2011, 10:39 PM   #5094
Schassis707
Trader Rating: (18)
why dont you just swap the inner workings and not have to deal with any axel changing or anything, shit the differential is already out, its like 20 more bolts and done...
Old 03-16-2011, 10:39 PM   #5095
towlie
Oil temp gauge=don't even trip.
No problem
Old 03-16-2011, 10:41 PM   #5096
Ramonesfreak2010
So I finally got running my rebuilt sr20. After the first drive, it couldn't keep an idle. I did the following:
-Check for vacuum leaks, reads 20 inHg at idle
-Check for boost leaks, none
-Check TPS voltage, .45-.5 volts at idle/acc on
-Redid timing, timing is good
-Cleaned iacv, helped kinda
-Checked iacv if it was bad
-Adjusted iacv, helped a bit
-checked maf, nothing
-checked coilpacks and sparkplugs, nothing
-checked injectors, nothing
-swapped fuel pump to walbro and put a new z32 fuel filterm nothing
Now, the car doesn't hold an idle when its cold. When its warm, its fine. Bad coolant temp sensor? Thats the only thing I can think of. I have ordered it and should be here by Friday.
Old 03-16-2011, 10:42 PM   #5097
jdm240sx122
jdm240sx122's Avatar
jdm240sx122 is an unknown quantity at this point
At what point do you think valve springs are needed in a build? Or what stage/level cams usually require them??
jdm240sx122 is offline   Reply With Quote
Old 03-16-2011, 10:44 PM   #5098
jdm240sx122
^^You should try cleaning the MAF sensor....It cant hurt to try.
Old 03-16-2011, 10:49 PM   #5099
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Having an impossible time trying install the fuel tank o-ring. Not sure how it fit in there before I disassembled everything, but its diameter is much larger than that of the seat it is supposed to fit in.
Is there any trick to this? Would freezing it shrink it enough?
Old 03-16-2011, 10:55 PM   #5100
Greenz32
Greenz32 is an unknown quantity at this point
hey guys im putting together an exhaust for my 94' 300zx tt and ive found downpipes and im gonna get the hks cat back but im finding it tough to find some midpipes with high flow cats. Does anyone know where i can find a pair for 350 or less?? any website links or tips would help
Greenz32 is offline   Reply With Quote
