02-12-2010, 12:19 PM | #481 | ||
we made them specifically for z32 uprights for Def's group buy but a few people have used them on the s-chassis edit: member's jr-ss build thread: http://zilvia.net/f/chat/286970-my-b...-lay-down.html |
02-12-2010, 05:04 PM | #482 |
Update: Stopped by Skullwork's again today. Thanks to Mano and Tower240sx for taking the time to take a look at the spindles. Very obliged
Bad news. The rear hubs do not work for the z32 rear e-brake kit. We threw around a few ideas how to make it work, but by altering the cable, milling down the spindle, etc. the cost was just not worth it. I'll talk to DW to see if they have plans to develop another set that will work, so I'll keep ya'll posted. In the meanwhile it'd be great if someone in the US were able and highly competent enough to develop a rear spindle huhuhuh.
.25 till 3 |
02-12-2010, 05:14 PM | #483 |
hmm that sucks i guess driftworks should put the option into the shop to buy the fronts only for people who use z32 drum brakes aka the euro spec stock ebrake on the s13
02-12-2010, 10:46 PM | #484 | ||
I will be sure to include accommodations for a working Z32 e-brake. We're also looking at a second caliper option. As well as being able to use the 12.75'' rotors (with Z32 calipers) from the track edition 350z. |
02-13-2010, 12:20 AM | #485 | |
That'd be great if you can develop something like that. I'd opt for the z32 ebrake. Please keep us posted on your development.
.25 till 3 |
02-13-2010, 07:08 AM | #486 | |
Well skullworks could too i guess right Guys dont forget a z32 shock mount option in the rear I have no e-brake but i was wondering didnt dw have an extra bracket of sorts for an e-brake (was it hydro e-brake with an extra caliper or something) |
02-13-2010, 02:31 PM | #487 |
Man, I really wish someone had the connections to make cast aluminum drop knuckles for the rear. It's so simple and nice looking.
02-17-2010, 10:43 AM | #488 |
Hey just to let you know guys, I was looking at the pictures of the Driftworks S15 with the knuckles installed, and by my calculations, at the ride height it is at, the knuckles place the roll centers darn near the ideal places. The rear one is about 2 inches below the diff (center of gravity is about the middle of the diff or a little higher), and the front one is right on the bottom of the crossmember (center of gravity being the crank centerline).
This makes the roll axis and the mass axis nearly parallel, which should (and does) make for a very neutral handling car. BTW, you do NOT want your front control arms to be perfectly level. This causes positive camber gain during suspension stroke. Pics so you don't have to go back to the first page: Video that shows the front knuckles installed: http://vimeo.com/3871773
02-17-2010, 03:13 PM | #489 |
Eh I just saw the video... if the spindles are the ones in that video that give that much lock me not want.. i dont want that much steering lock.. wth... that's spelling nightmare on a road track condition... i dont want dorifto :S
02-17-2010, 03:19 PM | #490 |
Well you don't have to turn your steering wheel that much in all corners... unless you might be auto-x'ing.
.25 till 3 |
02-17-2010, 03:20 PM | #491 |
hahaha, why? It's not like you have to use it.
It's still 2.5 turns lock to lock. Shouldn't be hard to get used to the quicker steering. Just ask mmdb, he loves it and he doesn't drift. You can install larger steering bumpstops too if you want. EDIT: HAhaha, mmdb you just posted the same time I did.
02-17-2010, 03:25 PM | #492 | |
.25 till 3 |
02-17-2010, 03:40 PM | #495 | ||
As I'm driving the car more and more, the car doesn't feel as balanced as it should. The front wheels load, and continue to carry the load through the corner. It's only passed corner exit that the rears feel loaded... and when that happens and I gas it the rear wants to slide out. Definitely needs some rear stiffness. So I really cant' wait to get the DW or equivalent in soon. Btw I got my clutch installed... it wasn't too bad... it's just that the transmission is so much heavier than the KA transmission. On top of that I have an oil leak so I screwed up somewhere. I guess that's what this weekend is for.
.25 till 3 |
02-17-2010, 04:23 PM | #497 |
I still don't understand what the hell these things do? They extend the angle/lock for drifting more?
Or they just 'reposition' things? I was trying to understand it and I believe someone asked about massive caster moving the tie rod forward at one point vs the rack... or something like that.... therefore making the tie rod pushed forward... would then this move the tierod at the rack end forward as well to make it more parallel or am I imagining stupid things and that's not what it's for (if it even is a problem). Explain to me this |
02-17-2010, 05:41 PM | #498 |
I figured that with all the sus heads in here someone would know what to call this part, which does pertain to sus arms.
On aftermarket rear upper control arms you know the piece the hiem threads in, and then that piece threads into the arm? It is the piece that is threaded inside and out and allows for the alignment to be adjusted with out disconnecting the arm and turning the hiem. I hope this is sufficient for someone to give me a common name so I can find some for some arms I am making for myself. And if you know of a place that sells this piece in metric vs standard that is great, but standard is fine too.
Facebook Link: https://www.facebook.com/brickhouseproductsllc |
02-17-2010, 05:49 PM | #499 | |
Baker calls them Weld In Adapters - bottom of the page Rod End Seals, Weld In Adapters, Spacers And Reducers Rubber Boots Lock nut jam nuts |
02-17-2010, 06:20 PM | #500 |
Someone answer my question
Another question to mmdb directly again, I am guessing you have 0 toe or slight toe in then with the new spindles if it has such turn in characteristics no? I run 1/8 (or was it 1/16) toe out on on the front of my s13... eh i bet with these spindles i wouldnt want that i guess and should run 0 or even toe in (used to run 0 toe front) |
02-17-2010, 06:40 PM | #501 | |
Those move the tie rod forward, making overcentering basically impossible because the tie rod arm of the knuckle will never be that far foward.
02-17-2010, 07:42 PM | #503 |
Hahah, only if you really need it. If you don't use that much lock or you never experience overcentering, then there's really no need for them.
02-17-2010, 09:35 PM | #504 | |
Trader Rating: (29)
Feedback Score: 29 reviews
Heim adjusters If you are thinking of building your own RUCA's it is cheeper to buy them. |
02-17-2010, 10:52 PM | #505 | |
It really depends how you feel the car should handle. On tighter tracks I'd run a little bit more toe out in the front and less toe in in the rear. On higher speed tracks you'd might want to do the opposite. But again, it's whatever helps you build confidence in the driver seat and allows you to follow the racing line.
.25 till 3 |
02-18-2010, 05:50 AM | #506 | |
I guess it's a little off topic, so pm if you'd like, but I'd really like to hear your thoughts on the subframe foam, as I was thinking about this + some chassis foam while everything is already disassembled. What foam did you use?
In Zipties We Trust..... |
02-23-2010, 11:44 PM | #507 |
Got in touch with Ben recently over at DW. Apparently they fitted the rear with a non-z32 brake assembly and assumed it would work... unfortunately it doesn't. Ben noted that it'll be a future modification in their design, but that doesn't really help me. So just to note, the DW rear spindles will NOT work with the z32 rear brake assembly.
Anyway, I went back to Skullworks and spoke with Mike and Juan. They'll be modifying the spindle to fit the e-brake cable through and create a custom set of sphericals for them. I'm pretty excited to see what these babies will do. Apparently Suzuki? aka scorch 15? lapped Tsukuba with a relative set of modified rear spindles. They look to be SP-tec? which is good news, considering the rear knuckle pivot points aren't "exclusive" to DW's design compared to sp-tecs according to Ben.
.25 till 3 |
02-25-2010, 10:58 AM | #509 |
Good to know that I'll be able to have sphericals made if it comes down to buying DW knuckles.
02-25-2010, 11:11 PM | #510 |
Sounds good. Can't wait to see the modded versions, as it means it'll be able to work on my car Front roll center adjustment through hubs is almost non existent for my car. But hopefully some modded LCAs along with the remodels DW rear spindles would do wonders for my car. I wonder how different roll center adjustment is between your guys' MacPhearson strut design, and my multi-link rear.
