Old 09-25-2012, 02:47 PM   #4651
Silvi
Silvi is an unknown quantity at this point
What will be the right length to extend? 20 or 25 mm?
Silvi is offline   Reply With Quote
Old 09-25-2012, 03:23 PM   #4652
Z33dori
Z33dori's Avatar
there is no right amount, depends on how much camber/track you wanna add
Old 09-25-2012, 03:28 PM   #4653
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
what size rods are you guys using to weld into the stock lower control arm to be able to adjust?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 09-25-2012, 03:48 PM   #4654
Silvi
I don't really want to add more camber, I got clearance issue with frame rails
My tyre rub the rail before full lock
Old 09-25-2012, 03:52 PM   #4655
Z33dori
Z33dori's Avatar
20mm should be enough, i dont think anyone has done less that that.
Old 09-26-2012, 07:22 AM   #4656
Z33dori
Z33dori's Avatar
my buddy just extended his last night
S13 arms , 40mm extension
Old 09-26-2012, 01:27 PM   #4657
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
that is equivalent to dong a 25mm extension on s14 arms, but way cheaper in the end!
huffandpuff00 is offline   Reply With Quote
Old 09-26-2012, 01:47 PM   #4658
pete240
pete240 is making a name for him/her selfpete240 is making a name for him/her self
Had he done heim joints on the inner mounts he could have gone over 40
pete240 is offline   Reply With Quote
Old 09-26-2012, 06:53 PM   #4659
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
But that would have jacked with the mounting of the tension rods too much.
C. Anderson is offline   Reply With Quote
Old 09-27-2012, 07:43 AM   #4660
shoguner
shoguner is an unknown quantity at this point
So i have a question.
Mikerbike extender his by ~35mm and at full lock his trailing wheel hit the tension rod(correct me if im wrong) so he put spacers on. I want Now i know Cor Integration makes some curved tension rods. Has anyone tried to make their own yet?
shoguner is offline   Reply With Quote
Old 09-27-2012, 07:55 AM   #4661
Silvi
what tie rod + end recommended to use after extending the LCA?
Old 09-27-2012, 10:50 AM   #4662
mikerbike
mikerbike is an unknown quantity at this point
Didn't change the TC rod mounts at all.
mikerbike is offline   Reply With Quote
Old 09-27-2012, 04:09 PM   #4663
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Does anyone know anything about Z32 steering racks?
They seem to go for cheap, even the HICAS ones, and they have a very nice ratio.
S13/S14 rack - 17.1:1 ratio - 3.1 turns
S13 HICAS rack - 14.9:1 ratio - 2.6 turns
Z32 TT HICAS rack - 14.8:1 ratio - 2.4 turns
I know they use an electric pump, but it would just be a matter of blocking off the electric motor, or swapping the upper housing from a 240SX rack. Other than that, everything should bolt up.
The only thing I have been able to find as to why they would not really be an upgrade is that they may have shorter travel. Can anyone confirm this to be true?
Old 09-27-2012, 04:45 PM   #4664
GripTerror
GripTerror is an unknown quantity at this point
whaa? they use electric really? Thats awesome! Thats better than are slush fluid ones then!
GripTerror is offline   Reply With Quote
Old 09-27-2012, 05:17 PM   #4665
Matej
Trader Rating: (39)
Actually, the electric motor is for the HICAS system, I believe.
Old 09-27-2012, 06:14 PM   #4666
Razi
Razi is an unknown quantity at this point
Pretty sure that Z32s have less angle than S13s though.
Not sure if that's due to the rack or the knuckle.
Razi is offline   Reply With Quote
Old 09-27-2012, 10:19 PM   #4667
C. Anderson
40mm from the crossmember mount is ALOT. Also Its better to extend on the other side of the tension rod mount (like above) to help with the wheels hitting the tension rods with high angle knuckles.
Old 09-28-2012, 06:19 AM   #4668
Silvi
Just extended my LCA by 25 mm
But now I still got 2 problems:
1) the wheel is touching the tension arm exactly at full lock.
So I thinkin to buy thoseany recommendations?)
Driftworks Geomaster Tension Rods S13 S14 S15 R32 R33 R34 Z32
2)I cut my inner and outer tie rods by 15mm because of the rack spacers and now I got zero screwing on the inner after the extension.
So im really need recommendation which inner and outer tie rods I have to buy.
Thanks!
Old 09-28-2012, 06:28 AM   #4669
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Thanks!
1) How many more degrees of travel do you have before hitting the steering stop? (either LCA or rack) If it's just a degree or two, you might be able to get away with sliding on a small spacer for clearance. If not, those tension rods should help.
2) Are you saying that you cut down your tie rods and now they're too short? If so, go get another set of stock tie rods and run those...? If not, PBM's new tie rods are really sweet, I just got a set this week and they're significantly longer (and stronger) than the stock setup. Combine this with an S14 outer and you should be good to go?
thefro526 is offline   Reply With Quote
Old 09-28-2012, 06:51 AM   #4670
Silvi
The rack spacer add about 20mm total of rack traveling. At full lock the tie rod hit the lca and full lock to other side the wheel hit the tension rod. So i will try an 5 mm spacer and hope it helps. If not i guess I will order DW rods.
About the tie rods, I cut them before the extension. the reason was that the rods are too long and i cant recanter the rack and avoid toe in.
Im looking for better and lowered than the stock outers, something like those:
http://www.imageinmotion.com/pics/ci...RE-0014-HC.jpg
Thanks about the PBM inners, I will order them
Old 09-28-2012, 08:57 AM   #4671
mikerbike
I'm not sure if you're arguing my point or agreeing it. Either way, what you say is correct.
Now that I've extended my control arms ~37mm, I have decided it's overkill. And if I ever extend control arms again, I'm only adding ~25mm.
Old 09-28-2012, 06:43 PM   #4672
Matej
Trader Rating: (39)
S13 or S14 ones? On S13?
I guess I will go with 30mm then.
Old 09-28-2012, 09:58 PM   #4673
C. Anderson
A little bit of both. I think it's fine to adjust on the inside for fine tuning but 40mm seems like a lot of stress for a stock arm at that spot.
Old 09-28-2012, 10:40 PM   #4674
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
My buddy Mestiso is running the Corr TC rods. I believe the front control arms are extended 25mm from stock S13. They are Battle Version weld in adjustable kit.
Here is a pic at Top Drift...and no he did not spin.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 09-29-2012, 12:13 AM   #4675
oni jake
oni jake is an unknown quantity at this point
Any video? That picture is just not doing justice to me. Things look to be fucked up to achieve good angle.
oni jake is offline   Reply With Quote
Old 09-29-2012, 12:57 AM   #4676
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
The ugly cars usually get the dopest angle, haha.
nieko is offline   Reply With Quote
Old 09-29-2012, 02:02 AM   #4677
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
that roll center looks messed up.
Motary is offline   Reply With Quote
Old 09-29-2012, 04:48 AM   #4678
thefro526
thefro526's Avatar
Bricks make anything look presentable.
Random, but do you have any fender mods? Tubs/No Inner Fender/Whatever?
Old 09-29-2012, 09:15 AM   #4679
Jonnie Fraz
Trader Rating: (29)
No video...Not sure what you mean by "to fucked up to achieve good angle."
Here is another shot at Sonoma...
With the Corr TC rods are limit is now the front sway. Corr now has a new front sway to allow more angle.
Old 09-29-2012, 09:59 AM   #4680
nieko
It isn't that random bro, that is what this thread is for! And at the time this picture was taken... no.
The only thing I had done to the front for clearance was my friend THOR. (BFH) lol. I literally sledgehammered everything that hit then spray-painted it black and did an event and wherever the paint was missing, I did more sledgehammering.
What really ended up limiting me was my tension rod/sway bar.
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
