06-03-2012, 06:57 PM | #4201 | |
very nice thanks.. i like the bolt idea to set the stop.. have you used the car with this setup? did you have any weird steering with the suspension moving up and down and the knuckle rubbing on that bolt? |
06-04-2012, 12:18 AM | #4202 | |
Trader Rating: (29)
Feedback Score: 29 reviews
Here is the car at Top Drift... |
06-04-2012, 11:11 AM | #4203 | |
Trader Rating: (58)
Feedback Score: 58 reviews
I should really get back to playing with the Mustang racks to see if I can make it work.
06-04-2012, 12:53 PM | #4204 |
kinda off topic,....anyone verify that 97ish i30/i35 inner tie rod idea.
curious so i can buy some.....lol
cONtRol FReAkS |
06-04-2012, 12:56 PM | #4205 | |
WTB: 1(one) battle version toe rod
-Mike |
06-04-2012, 03:04 PM | #4206 | |
ps: compared those rods with s14 ones. from the middle to the end that threads into the outer tie rod, s14 ones are 11mm thick and i30 ones are 13mm... so looks like they're longer AND thicker |
06-04-2012, 03:18 PM | #4207 | |
The Jegs Pinto rack has a 15:1 ratio. http://www.jegs.com/jegs/jegsmanualrack.html |
06-04-2012, 03:56 PM | #4208 | |
Holy shit man,. yeah, this is great to hear. Pics would be awesome,.....buuuut prolly gonna buy them regardless....lol edit: so just to be sure, 97 i30 inners is the right year/model
cONtRol FReAkS |
06-04-2012, 04:30 PM | #4209 | |
so yeah, just by looking at FSMs i'd suggest checking out tie rods for i30 years 96 to 99 and when going to buy them, to be on the safe side, always grab an s14 inner tie rod with you and check that the thread diameter & pitch match. i'm pretty sure they do but it doesnt hurt to verify Last edited by frifox; 03-16-2018 at 02:07 PM.. |
06-05-2012, 12:19 AM | #4210 |
I usually use NAPA Online whenever i want to compare suspension components.
they've got all of the thread pitches/lengths/tapers listed. Pretty useful! |
06-05-2012, 03:11 AM | #4212 |
A little update:
We are now ready to start prototyping. For those that have missed it what we have here is a billet 7075-T6 aluminium modular knuckle for the S chassis (S13 and S14/S15) with Chromoly spindle. The steering arm is completely modular (we currently have a standard and DW spec arm as shown in this image which offers great angle and quick steering response), the brake caliper mount is radial and we currently have the standard position mount (either with or without ABS sensor provision) aswell as a mount to run R33 GTR (324mm rotors) with your standard 4pot Nissan calipers. The knuckle corrects roll center by 40mm's by raising the spindle height and the steering arm is adjustable in height (aswell as being modular). The knuckle provides +/- 2 degrees of camber and is car specific and parts are interchangeable. Ie. you will be able to order the knuckle with S14 spindle, with S14 ball joint insert but with S13 strut bolts (12mm Vs S14/S15 having 14mm). This is NOTHING like any other knuckle on the market. From here we go to prototyping/on car testing and we should see these late 2012. Estimated price at this stage is $599/pair (AUD). Any questions, feel free to ask away. A breakdown of the specs: ETA October, 2012 Estimated price - $599/pair (to be confirmed) For those that have missed it what we have here is a billet 7075-T6 aluminium modular knuckle for the S chassis (S13 and S14/S15) with Chromoly spindle. Featuring: - spindle height raised 40mm's to correct roll center - modular steering arm (choice between 2 arms at the time of ordering) - adjustable steering arm to correct bump steer (as seen here: http://www.facebook.com/photo.php?v=10151055582888296) - modular caliper mount with ABS provision (choice between 2 brackets at the time of ordering; standard and extended bracket to suit 4pot caliper with 324mm R33 GTR rotor - S13 version is: 2.52kg which is a 24% reduction over standard - S14/S15 version is: 2.63kg which is a 31% weight reduction over standard and DriftWorks item which weighs in at 3.8kg's - adjustable KPI/Camber +/- 2 degrees - mix and match when ordering. Ie. ability to order the knuckle with S14 spindle, with S14 ball joint insert but with S13 strut bolts (12mm Vs S14/S15 having 14mm) - CAD files available to the general public for steering arm and caliper bracket development More images can be seen here: http://www.facebook.com/media/set/?s...3379304&type=3 Last edited by GKTECH; 06-05-2012 at 08:25 PM.. |
06-05-2012, 07:33 AM | #4215 | |
That's based on the unit as pictured complete here: P.s here's a short video of the steering arm in action: http://www.facebook.com/photo.php?v=10151055582888296 |
06-05-2012, 09:36 PM | #4216 |
this is the car setup. maxed out camber plates outwards and extended lca's to get, if my math is correct, 3* front camber... or that's what it was before i raised fronts by 20mm. was rubbing the wheel well & fenders in all possible places
LCAs, Tension Rods, Knuckles, and Coilovers are by Parts Shop Max. Outer Tie Rods are stock s14 and Inner Tie Rods are from Infiniti i30. |
06-06-2012, 12:16 PM | #4218 |
got passed this link today. makes some interesting points about camber gain, caster and wisefab kits. its inline with my way of thinking to a certain degree
http://www.inertia-ms.com/blog/?p=781
[SIGPIC][/SIGPIC] |
06-06-2012, 12:29 PM | #4219 |
for now, yes it is... the tie rod and the knuckle arm are pretty much inline at full lock right now so i'll need to move the steering rack forward to allow for more angle. i'll be doing that later since the angle i'm getting right now is more than enough for my 210k half dead KA
06-06-2012, 12:41 PM | #4220 | |
That looks like a really exciting product! Weight savings, modular steering arm, and radial caliper mounting option!? What calipers are those radial mounting bosses designed for? And being able to increase the king pin angle 2 degrees should raise the roll center as well. Have you calculated how much the roll center is raised by increasing the KPA 2 degrees, but still maintaing say 3 degrees of camber?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
06-06-2012, 01:11 PM | #4221 |
frifox, that L bracket looks like a great quick adjustment between our stock setting and where you need the bumpstop to be. Great idea.
To test weather that will work in all situations with your settings, take out the front spring, and jack up the wheel, and let it down to make sure the stop is making proper contact during all points of compression and droop.
06-06-2012, 01:47 PM | #4222 | |
06-06-2012, 02:53 PM | #4223 | |
That's a very specific scenario and unfortunately we haven't calculated the roll center within that scenario. The KPI doesn't need to be changed, that's entirely up to the users preference and how much they want to play around with different settings. |
06-06-2012, 02:55 PM | #4224 | |
Here's the overhead shot of the 2 arm options (more options to come in the future) Last edited by GKTECH; 06-06-2012 at 03:25 PM.. |
06-06-2012, 08:05 PM | #4225 |
HHNNNNNNNGGGGGG!!!!
Knuckle is looking great GKTECH. Letting the design be open source is going to make this thing blow up. I know I've got quite a few plans for additions over time!
06-06-2012, 09:46 PM | #4226 |
If you are making both the steering arm and brake caliper bracket modular, why not make the knuckle symmetrical so that the same knuckle could be L or R depending on which side you bolted the steering arm or brake caliper bracket to? Couldn't this decrease machining cost, to be making only one instead of two different knuckles?
06-06-2012, 10:15 PM | #4227 | |
06-10-2012, 01:37 PM | #4230 |
Only downfall is the lack of threads into the rack, so no room to run the slip on spacers. But I bet they would work great with a pair of those bolt on spacers.
-Mike |
