01-23-2011, 05:49 PM | #4171 |
idk just thought it's something to know, but thanks for the radiator stuffs
street dancer. GLEAM |
01-23-2011, 05:50 PM | #4172 |
how can i tell which side AN fitting i need/have for an oil cooler in which i don't know the brand (brand name is hard to read) or what it is? (bought from someone used)
01-23-2011, 09:28 PM | #4173 |
Help please! Okay so I'm swapping the ka24e for a ka24de and as I was unbolting the tansmission crossmember onm the autotranny and the bolts snapped! They came off but half or more of the boltis still stuck in there, what should I do? How am supposed to bolt on the manual crossmember, so I freaked out! Any tips, ideas?
01-23-2011, 10:59 PM | #4174 | |
1. vice grips (usually fails) 2. hammer and chisel ( also fails) 3. bolt extracting drill bit (works pretty well with heat and pb blaster, either or) 4. tac weld a bolt/nut to the bolt and then wrench it off. Make it a good strong weld if its a nut that you are welding on, do it so the inside where the threads are is where you weld, you don't want to weld the nut and bolt to your crossmember
01-23-2011, 11:59 PM | #4176 |
Thanks guys, I hated my self when the bolt heads snapped! Three snapped only one bolt is holding the crossmember. The bolt extracting bit and easy out kit sound promising, can they be found a home depot? Any advice on how to unbolt the driveshaft from the differential? I've been trying And spraying wd40 but they wont budge. Almost began strip the bolt :/ just effing up.
01-24-2011, 12:13 AM | #4178 |
Good its not the end of the world, thanks guys. So for the other stiff ass bolts like the one on the driveshaft, any other tips besides using copeious amounts of wd40 and brute force with hammers and a fence pole?
01-24-2011, 05:23 AM | #4181 |
Ok , My power windows and sunroof just all of a sudden stopped working , Checked every fuse , relays are fine. I'm stumped. S14 btw. Any help will be appreciated.
01-24-2011, 09:17 AM | #4182 |
Anyone make their own skid plate for an s14? I don't wanna pay 150 for a pbm one. What'd you use and what were the dimensioons?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
01-24-2011, 10:24 AM | #4183 | |
First if you know anyone that has one or find someone with one, you could trace/copy it...if that's not an option, id get ahold of big sheets of cardboard and start building a template off of that |
01-24-2011, 10:48 AM | #4185 | |
Trader Rating: (58)
Feedback Score: 58 reviews
-4 = 4AN 4 goes over /16 to create the size 2AN = 2/16 = 1/8 3AN = 3/16 4AN = 4/16 = 1/4 5AN = 5/16 6AN = 6/16 = 3/8 etc etc Measure the output side of the hole to get your size Check the power window amp. I wasn't sure it also controlled sunroof though.
01-24-2011, 11:56 AM | #4186 | ||
01-24-2011, 12:51 PM | #4187 | |
And thinking of getting the stage 8 bolts + fasteners, and getting Copper locking Nuts instead of the nuts from stage 8. Think good combo?
01-24-2011, 01:59 PM | #4188 | |
Trader Rating: (58)
I'd order the OEM studs and nuts, and then use the OE locking plates as well. You can use Z32 Turbo part numbers, they interchange. Here is a link to the locking plates...these are crucial into keeping the nuts on. PLATE-LOCK - 300ZX (Z32) 1990-1996 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
01-24-2011, 02:09 PM | #4189 |
front tower bars...
s13 and s14 are interchangeable, right?
http://bhworld.wordpress.com/ |
01-24-2011, 02:18 PM | #4191 |
Thanks.
01-24-2011, 02:51 PM | #4193 |
Isn't having a stop sign illegal though? I just wanna buy a sheet of aluminum, but to save the hassle of measuring everything myself, I figured I'd ask. Worse comes to worst I'll just measure myself. I'll probably use the same sheet metal as PBM uses for their skid pads.
01-24-2011, 03:49 PM | #4194 |
Trader Rating: (58)
You want something thick enough to absorb some impact, and not immediatly bend up into the pan as it is.
To me a stop sign, or diamond plate, are really the only true decent materials to use for a skidplate.
01-24-2011, 04:58 PM | #4196 | ||
AFC #1
The teardrop shape holds the bolt/nut against the turbo. Keeping it from backing out. If you are having problems with the studs walking out I would get the Bolt kit not the nut kit. The 25mm vs 30mm is the bolt/stud length. I don't think 5mm is going to be an issue. Stock manifold I would get the nut kit. Bolt kit for aftermarket. Those copper ones are easy to use. But they can stretch out over time it you have stress on them. Quote:
01-24-2011, 05:26 PM | #4197 |
Yea I decided to get Z32 inlet studs, and copper nuts. Going to weld the top of the studs to the manifold. And get a flex pipe for my exhaust.
Should be all gravy after that. Hopefully... Oh and the Stage 8 kit is $27 for the nuts. And $41 for the bolts. Incase anyone wanted to know, because they don't show the price on their site...
01-24-2011, 05:37 PM | #4198 | |
dude wd40 sucks for loosening an old bolt. It's just a lubricating oil, it doesn't penetrate very well. Plus it causes cancer. Get pb-blaster (made of fish oil) which works wonders, and i've heard the Freeze-off or w.e works good too, never used it though. But either way, no prob
The pbm one seems fairly easy to make, just cutting and bending will be kinda janky if you do it ghetto like. the bolts are, at least for s13, 2 in the back of the cross member, 2 on the tension arms, and 1 on the radiator support.
01-24-2011, 05:57 PM | #4199 |
what's an o-disk wheel/difference from a disk? Fitment on s13?
and uuuuuuuuh for filling up my oil cooler, do i fill engine and then fill up the lines/cooler separately or what? If i fill up the cooler and lines, any problems if it opens up and i have pretty cold oil flowing into the engine from the cooler since it's just sitting there getting cool from the air?
01-24-2011, 06:01 PM | #4200 |
I have a ka24de and I bought a new thermostat, installed it, put in coolant, ran the car. My upper radiator hose is hot, the radiator is hot, the engine is hot, the lower radiator hose is not.?
I tested the thermostat in a pot of boiling water and it worked fine. I installed it right, but its not opening. Im thinking of running it without a thermostat. So to the point, whats the plus & downside running the car without a thermostat? any idea what else it could be besides the thermostat? |
