10-17-2011, 06:27 PM | #391 |
Finished up the Pinout ID and soldering the Plug pins
10-22-2011, 07:14 PM | #392 |
Well had to work today so i made the best of it. Stage 1 is done.
I hate that S14's dont have a plug for the cluster harness, So I yanked a S13 one and wired it in the S14 so I can easily switch between the R33 cluster and S14 cluster. Cut and wired up each wire one by one to make sure nothing got mixed up since there are a few same colored wires. brought it home for a few touch ups and Bam Works like a charm
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 10-22-2011 at 08:10 PM.. |
10-23-2011, 05:17 PM | #393 |
Fuck what a day, Dont think I'll be doing cluster swaps anytime soon :/
Its a little trickier than it looks especially when theres not much info on this. plus sucks not having a good Soldering Iorn I had to trace all the tracks on both clusters just to make sure i was wiring it up correctly. Almost Done I can now swap between the R33 cluster and S14 cluster. Now i just need to wire up the Oil Pressure and Stock Boost meter
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 10-24-2011 at 06:38 AM.. |
10-23-2011, 06:36 PM | #394 |
Works like a charm
10-23-2011, 08:03 PM | #396 |
Thanks, Yeah I have a bigger turbo sitting in the house, just need to get some injectors and a PFC
10-24-2011, 06:32 AM | #398 |
I was gonna try and do a write up but It got a little confusing in the middle
when I was trying to figure out which tracks were positive or negitive, seeing that a few lights are ground triggered. in the beggining I used this guide for basic location, but then just went for tracing the tracks since there were a few wires not mentioned on here http://www.nicoclub.com/articles/ima...r_into_S14.jpg
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 10-24-2011 at 07:44 AM.. |
10-24-2011, 08:11 PM | #399 |
Installed
Fits pretty damn good, just had to mod the top mounting bracket. Seems the Fuel Gauge is accurate as well as Temps with the OE S14 Sensors I can move it over slightly so there are no gaps All thats left is to wire up the boost sensor and Oil pressure
10-26-2011, 12:37 PM | #401 |
Wow, this is an awesome thread. This is the kind of swap I want to do.
I am new to this site and new to the thread so excuse me. When you did the swap did you have issues with the clearence or issues with the shifter during the install? |
10-26-2011, 12:53 PM | #402 |
Thanks, i try to make with what i got.
No issues with the Shifter, When using a SYKO Kit and an R33 Crossmember the shifter sit pretty much in the OEM location.
10-27-2011, 08:53 PM | #403 |
Did you have any difficulty with the sway bar when installing the rb. I bought an s13 with an RB25 in it and have been having many overheating problems. I took out the engine and the sump has been cut they they welded the bit they cut on the side of it as it didn't clear the sway bar.
10-27-2011, 10:44 PM | #404 | |
As far as cooling get a Nismo thermo, N1 Water Pump, Big radiator, and some FAL fans that pull alot of CFM (Its either 2.5K or 25K CFM canot remember)
10-28-2011, 08:12 PM | #405 |
Great job on the cluster swap. I am new to the seen and a new s14 owner. I am trying to learn as much as I can.
Why an R33 cluster? Are there others that work? Also, is there a guide on the wiring? |
10-29-2011, 12:37 AM | #406 | |
The R33 cluster fits good and the Tach is calibrated for the RB, as well as a stock Oil pressure gauge. You can rewire any cluster into a car, just fitment is an issue
11-01-2011, 08:14 AM | #408 | |
Need new fenders, headlights, Wing, and paint Power FC, injectors, and tune, Possibly some new control arms...
11-06-2011, 08:38 AM | #412 | |
Thanks! Finished wiring up the RB cluster. Now have Oil Pressure and Boost Gauge Yeah almost kinda pointless, but I like Full Functionality Stock R33 Boost Sensor If anyone needs to know the Wire pinouts are Green/Blue Stripe = Switched 12V White/Green Stripe = Signal Red/ Black Stripe = Ground Bam
11-06-2011, 10:13 AM | #413 |
Sweet then I might just be able to get away with a 3 row radiator when I do my swap. That'd probably leave just under a half inch between the motor and radiator though
03-01-2012, 09:36 PM | #414 |
So when are you getting up to that 350hp goal? I see raw brokerage is gonna have that modded mani for sale here soon..are you going that route with a bigger turbo,inj, power and tune?
03-01-2012, 11:48 PM | #415 | |
Been side tracked so much with my other projects and having issue on finding a PFC for the RB. I have a turbo already just need ECU and Inj. But all my plans have changed now since I just received orders to go to Misawa Japan for a few years haha
04-25-2012, 05:41 PM | #416 |
Me and the Mechanic Keyteh Installed a Tomei FPR on the RB
Seriously though some random cat that hopped up in there
04-28-2012, 10:46 PM | #417 |
How are you liking the hyper gear turbo? My car has been running weird and now after I pulled my turbo I'm thinking it could be that. There is about 1/8-1/4 inch shaft play. Is that bad? When my car is under 70 c it runs like shit, sometimes of I step on the gas it will just die out. If it shuts off it won't want to start. If I let it warm up to 70 c it runs good and pulls strong. I'm lost haha. So I have been thinking of ordering a hyper gear turbo.
04-29-2012, 06:17 PM | #418 |
I took off the HG turbo I while ago cuz the Stock ECU doesnt like it.
Felt good when I had it on though. Quick and responsive. That much shaft play on a BB turbo is def not good. Id look into boost leaks and check ECU for codes
04-29-2012, 07:22 PM | #419 |
Alright. Yeah I don't plan on putting that turbo back on. I'll be picking up a hg when I sell my truck. I haven't tried checking codes. Never had to.
rb25 install, rb25 rebuild, rb25 s14, rb25 swap |
