08-30-2016, 06:40 PM | #41539 |
I think my car is finally 'ok' enough to post in here.
Auto base model with ABS, sun roof and power locks. The only thing missing were the 5 lug (which kicked my AZZ!!!!) and fog lights. I'm doing the front 5 lug swap tomorrow. Keep in mind that the rear small glass tint you're seeing, is not really tint. It's the glue that REFUSES to come off.
08-30-2016, 06:56 PM | #41540 | ||
5 lug swap wasn't as bad as I've read... just expensive. Sent from my SM-G930P |
08-30-2016, 07:17 PM | #41541 | |
In terms of rims, just get the stock SE rims to hold you over until you find the rims you really want. My hubs came up to around $320.
08-30-2016, 07:38 PM | #41542 | |
Well, I hadn't budgeted doing the conversion. It's just that when I dropped the subframe to replace the bushings, I realized the bad wheel bearing, worn brakes, and balding tires. Didn't make sense replace those when i had 5 lug hubs and wheels that've been stored for almost a year.😅 $240 5lug hubs. $180 pads/rotors $200 tires $500 wheels.... f'n base model problems. Sent from my SM-G930P |
