01-20-2011, 12:41 PM | #4111 |
long story short, degreased engine after i saw white smoke. found leak. how hard is it to change the valve cover gasket? ordering the rtv and gasket kit from frsport. looked in fsm and couldn't find torque speccs for valve cover botls. Under the maintenence and engine sections...
1995-1998 Nissan 240SX KA24DE Valve Cover Gasket Kit Nissan Permatex Ultra Grey RTV Silicone Liquid Gasket Maker btw got my suppliess for strut bar. when i find time thats my next project.
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
01-20-2011, 12:50 PM | #4112 |
Replacing the valve cover gasket will not fix white smoke. White smoke is caused by burning coolant- your head gasket is more likely to blame.
Changing the valve cover gasket is about as easy as changing spark plugs. Torque specs are "good'n'tight" or around 10lbft (guessing) |
01-20-2011, 02:06 PM | #4114 |
quick question
bought a fg hood from chaser, and the 2 "layers" are kinda coming apart, it looks like theres some "glue" like stuff thats supposed to hold the 2 layers together, anyone know what i should use?? i was going to use fg, but the stuff thats on there right now seems gooey, like silicone, but its not, any help is appreciated, thanks
01-20-2011, 02:22 PM | #4115 | |
01-20-2011, 03:53 PM | #4116 |
is there any way i can clean my radiator? It has some brown shit inside it which im assuming is either rust, pasty coolant w/ rust, or oil. Don't care either way, i just want it clean
Also, a thing i found out today... ka24de oil drain plug thread pitch is the same thread as s13 lugs and suspension bolts. Something good to know
street dancer. GLEAM |
01-20-2011, 05:03 PM | #4118 |
It's a really thick/heavy fluid, like when you put too much chocolate mix in a cup of milk and you get that slow-moving puddle at the bottom of the cup
I'll try that though
01-20-2011, 05:47 PM | #4119 |
Sounds like oil got into the coolant system or old coolant started breaking down. Look in to chemical flushes. Valvoline has a deluxe radiator flush kit that comes with a cleaner you add, then idle for a while, then evacuate old fluid, also comes with a water pump lubricant chemical. Just water won't get all the residual out of the crevices.
@MMyriad |
01-20-2011, 05:58 PM | #4120 | |
01-20-2011, 07:11 PM | #4121 |
does anyone make a secondary rear caliper kit or adapter for the 240sx? i wanna go hydro ebrake but i want it to be its own calipur
Drives a BRZ and is building a V6 S12 coupe. |
01-20-2011, 08:45 PM | #4122 | |
small answer please? |
01-20-2011, 09:13 PM | #4123 |
I'm gonna flush my radiator soon, and when I do that, I'm gonna replace the upper and lower hoses, along with the thermostat. I was wondering if I should get a NISMO thermostat instead of a new OEM one? The car is a daily driver in the spring, summer, and fall. Stored in the winter. The car will be driven hard on the street, and tracked once or twice a month. Thanks for any input.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
01-20-2011, 09:59 PM | #4124 | |
1 year tour in Korea = no car. FML. |
01-20-2011, 10:32 PM | #4125 |
Yeah that's what I was thinkin. Its only like 30 more so its not a big deal.
01-21-2011, 01:40 AM | #4126 |
does anyone have any input on coilovers. im lookin to finally ditch the lowering springs and buy some. would like something mostly for street use but some track days will be seen. anyone have a decently priced coilover that has been good to them? like under 1k??
01-21-2011, 01:45 AM | #4127 |
Well for 1k Powered by Max, just search them on the forum you will find tons of reveiws and info as well as their website. Also for 1k I have heard good things about Fortune Auto but haven't seen any reveiws (although haven't looked). In my opinion to get decent coilovers for under 1k your best bet to go lightly used and pick them up off of someone on zilvia or maybe craigslist.
01-21-2011, 02:09 AM | #4129 |
01-21-2011, 02:23 AM | #4130 |
yep, that's it. You can also contact DC Dan MAX USA on this site, he'll be able to answer any questions
Here's a link to his thread concerning coilovers http://zilvia.net/f/suspension/34385...ly-thread.html
01-21-2011, 09:11 AM | #4133 | |||||
Trader Rating: (58)
Feedback Score: 58 reviews
You probably just burned the bulb out, it's normal. Take the bulb down to the auto store and just replace it. Probably a 194 bulb, but unsure.
You want thermostat to be in the 175/180 range. This is proper running temperature, and allows the ECU to quit pulling timing to help warm the engine up. Too cold water = not good. Quote:
01-21-2011, 10:09 AM | #4135 |
also the bolt next to the oil cap is leaking oozing a little oil as well. which makes me think it's both the valve cover gasket (corner leak) and the spark plug gasket (bolt leak).
sounds right to you guys?
01-21-2011, 12:55 PM | #4137 | |
What's the operating temperature of the SE-R Sentra one compared to an OEM S14 one? I know the NISMO one is 62 degrees C, and the OEM S14 one is 76.5 degrees C, according to FRsport.com.
01-21-2011, 04:45 PM | #4139 |
Dope. Thanks man. I'll just get stock, screw it. It's a daily stock KA, so heat shouldn't be too crazy anyway...
