01-02-2011, 02:47 PM | #3872 |
In the front it may be a bit of a hassle. Might need to pull your fenders, and camber them in. In the rear, They should be alright, not too aggressive, but not sunken.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
01-02-2011, 04:01 PM | #3873 |
Hey guys, I had a question for those of you with cruise control in an s13. My current s13 the cruise works as expected, except I have to turn cruise on every time I start the car. Is that standard for a 240? Shouldn't it stay on until I turn it off?
01-02-2011, 04:45 PM | #3875 |
yeah they would probably be for rears - im deciding against it cause 9.5 is too wide for my anyways. Stock ka would prolly have a heart attack trying to get them to break traction
street dancer. GLEAM |
01-02-2011, 04:58 PM | #3876 |
A 5 bolt vlsd is out of a 300zx correct? I bought an 89 240 guy gave me the vlsd with it. And im curious to know if there worth anything? Do they lock up good?
01-02-2011, 05:09 PM | #3877 | |
doomvillian: those would be 180 kouki tails with covers over the outer lights and the center color matched. icedsole: i would suggest getting the s13 red cts and seeing if that works chances are it will and you have an early model s14 sr. |
01-02-2011, 05:17 PM | #3879 |
Engine:KA24DE
question: My car starts fine in warm weather but if its cold like early morning when i go to work it doesn't want to start.... any ideas??
"NEVER FORGET WHERE YOU CAME FROM........GRASSROOTS LOVE" |
01-02-2011, 05:17 PM | #3880 |
schrapnel85: you have 30mm aluminum z32 calipers. also pretty sure the aluminum ones only came in 30mm
1on1: delete egr its fucking worthless and way less hasle when its gone! |
01-02-2011, 05:34 PM | #3881 |
kits don't really exist because its a fabrication item it requires either welding a bracket to your spindle or building a bracket to come off the spindle, that i know of no one mass produces either option.
01-02-2011, 05:37 PM | #3882 |
01-02-2011, 06:23 PM | #3885 |
trying to think of a good license plate for AZ...i had ZENKI in NJ...but i want to change it up, there are 7 spaces, anyone got some good ideas?
zenki for life |
01-03-2011, 01:39 AM | #3886 |
Ok so my current suspension set up on my 14 is rsr springs on kyb gr2 struts they are pretty stiff for a spring and strut combo. My question is anyone know which camber plates I could run with it and which brand would be best?
01-03-2011, 07:22 AM | #3887 | |||
Camber plates for springs/struts arent really necessary. You can get camber bolts for the front, and rear upper control arms for the rear. |
01-03-2011, 11:17 AM | #3888 |
hey hows it going
i need your guys immediate help....if possible so the problem is that my windshield wipers stay on when key is in the ignition i want to see if i can pull the fuse out but unfortunately the panel display for my fuses is missing...so can u guys give me a link for the fuse box display..PLEASE...ive been looking on yahoo and have no luck |
01-03-2011, 11:26 AM | #3889 | |
01-03-2011, 01:55 PM | #3891 |
Trader Rating: (26)
Feedback Score: 26 reviews
fuse for my turn signals melted inside the fusebox and when i was able to pull it out, one of the prongs were left stuck in there. Tried everything to try and get it out but it's not happening.
What's my best bet to getting my turn signals working again?
01-03-2011, 03:52 PM | #3892 | |
Trader Rating: (58)
Feedback Score: 58 reviews
They 'say' 6 bolts are stronger, however it takes a super severe amount of abuse to ruin them, or a huge amount of power (400+ and some sticky tires)
I prefer the T3 mounts myself (TechnoToyTuning).
01-03-2011, 05:37 PM | #3894 |
Does anyone know about how much an 18x9 or 18x10 SSR Vienna Kreis wheel will weigh? I'm about to get a set, and was curious. Tried Google, didn't find anything.
01-03-2011, 06:39 PM | #3896 |
Ok so I'm retarded and jumped the gun with that drift knob shit. I installed it without removing the spring like I was supposed to. So I tried to pull the drift knob off. Now my ebrake won't stay up and it doesent click when I pull the ebrake up. However when I pressed the drift knob all the way down and try and pull the ebrake up I hear clicks but it doesent sound like the same clicks you hear when you pull it up and it stays up. Anyone know how to fix this?
Sent from my HTC Vision using Tapatalk |
01-03-2011, 09:13 PM | #3897 |
what is the point of a solid shifter? I saw a tomei one and i'm kinda going to be taking apart the shifter stuff for cleaning/maintenance and was thinking i might as well replace it...
Is there any performance gain from that shit? Or just for shorter shift throws
01-03-2011, 09:15 PM | #3898 | |
My cibie ones (French or Belgian) aim to the left with high beams, the low beams cut off to the right Helps for when dicks run with high beams, i blind the shit outta them
01-03-2011, 09:28 PM | #3900 | |
Trader Rating: (58)
Yes, and speed limiters as well.
Gain wise...well,less shit to go wrong, but nothing beyond that. In regard to shifters though, you can't go wrong with a B+M IMO. Solid construction, precise, and ZERO slop or issues. Some do regard it as being a tad notchy due to the greater reduction in throw, but I like the mechanical feel of it (then again, I'm used to most domestic setups, so notchy is normal).
