Old 11-19-2010, 08:47 PM   #3451
ViciousCesar!
ViciousCesar!'s Avatar
ViciousCesar! is an unknown quantity at this point
hey guys. i've been having a problem with my ka24e not starting some times. sometimes i'll start it and it'll die if i don't give it gas for a few seconds. other times it doesn't want to start at all and it doesn't only do it on cold starts either.
i don't know if this will help but...
-getting shitty gas mileage (40-50 mile 1/2 tank street drving and no i don't drive fast)
-slow response when i give it gas
-has new fuel filter and fuel lines
ViciousCesar! is offline   Reply With Quote
Old 11-19-2010, 09:02 PM   #3452
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
KAE and KADE lower harness the same?
REVIEW
killer240 is offline   Reply With Quote
Old 11-19-2010, 09:16 PM   #3453
TheEightyNine
TheEightyNine's Avatar
TheEightyNine is an unknown quantity at this point
10w40
but is there a reason you think you need a different viscosity oil?
Just the fact that my engine has a good amount of miles on it. Just wondered if changing would be beneficial.
TheEightyNine is offline   Reply With Quote
Old 11-19-2010, 09:49 PM   #3454
S14DB
AFC #1
S14DB's Avatar
5/10w-30 is factory fill. if it's been working fine then why change. Going to a thicker oil is just a bandaid for worn bearings and rings.
Old 11-19-2010, 11:16 PM   #3455
Wake
Wake's Avatar
Which is exactly what the problem is with most higher mileage KA's IMO.
It will be funny when people actually realize how cheap it is to rebuild a KA.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 11-20-2010, 01:11 AM   #3456
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Idk if it's even possible but is it possible to run dual tunes on a Apexi FC unit to run one for 91 and the other for E85 just be switching two between different settings? Or which Management is able to do that for SR?
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 11-20-2010, 06:09 AM   #3457
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
I don't know first hand, but, I bought an emanage blue a while back and the laptop it came with had two tunes saved to it. I'd imagine you could just switch between the two and then just readjust the airflow knobs on the unit each time.
but, as i said, i wouldn't know first hand. i never put it to use so it's just collecting dust...
c72c is offline   Reply With Quote
Old 11-20-2010, 09:25 PM   #3458
TheEightyNine
Could anything negative happen if i switch to a
thicker oil?
Old 11-20-2010, 09:44 PM   #3459
NickyD0403
NickyD0403's Avatar
NickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the rough
I have 2 questions. My car (240sx) has been sitting for about 5 months, and in the 5 months, I haven't changed anything major besides the rear brakes. I changed them from sti brembos to Z32 brakes.
When I went to start the car and drive it for the first time after sitting, I had to jump it, and as soon as I turned the car off, the battery died. It ran fine, drove it up and down the street a few times, but as soon as I turned the car off the battery went dead. And it does this every time I try to drive the car. It's an Autozone Duralast battery, so could it possibly be a bad battery after sitting a few months? Or am I looking at an alternator problem or something?
I started it a few times in the driveway with no problems, it kind of started doing this randomly.
Other thing is, I have a supercharger like whining noise coming from what sounds like the rear right side of my car. It's accelerational, gets louder as I go faster.
The hub has a little play in it, but nothing serious. Old car had much more play, and didn't make this sound. I changed out the right rear axle when I swapped shells because the bearings were shot, replaced it with a junkyard axle (out of a J30 with I think like 230k on it >.<) , and when I looked under the car, theres some silver grease on the cv boot and subframe. Could it just be an axle or is it more likely to be the rear end? It didn't do this before the car sat for an extended time.
Thanks!
NickyD0403 is offline   Reply With Quote
Old 11-21-2010, 03:49 PM   #3460
89SwapXE
89SwapXE's Avatar
89SwapXE is an unknown quantity at this point
engine
just want to know what kind of bolt you guys use for putting the engine on the engine stand? i cant seem to find any bolts that are long and same threadpitch besides the starter bolts. any help would be great.
89SwapXE is offline   Reply With Quote
Old 11-21-2010, 06:21 PM   #3461
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
I have a full S14 SR AC system (engine bracket, compressor, lines, condenser, idk what else) that I just deleted out of my bay. Is it worth anything?
Im getting mixed prices and info when looking. THANK YOU, THANK YOU, THANK YOU.
sonomadrifter is offline   Reply With Quote
Old 11-21-2010, 07:24 PM   #3462
Slikk Logic
Slikk Logic's Avatar
Slikk Logic is an unknown quantity at this point
which brake pads give me a good locking ebrake for drifting? i have a s14 stock brakes and i already adjusted the cable to oem spec..ive heard project mu bforce and some even nissan factory pads
no success without excess
Slikk Logic is offline   Reply With Quote
Old 11-22-2010, 01:19 AM   #3463
sickstatus
sickstatus's Avatar
sickstatus is an unknown quantity at this point
Send a message via AIM to sickstatus
i've been trying to look for a old advisers thread about 1month-1yr ago selling s14 exhausts. it was a new exhuast style[brand?] from japan. i cant seem to find it since i forgot the advisor. anyone remember who it was? thanks!
straights are for fast cars, corners are for fast drivers.
sickstatus is offline   Reply With Quote
Old 11-22-2010, 01:35 AM   #3464
sickstatus
sickstatus's Avatar
found it =p
http://zilvia.net/f/intake-exhaust/3...per-light.html
Old 11-22-2010, 03:37 PM   #3465
fckillerbee
fckillerbee's Avatar
so problem still is there. I swapped out a fuel rail, injectors, and fuel pressure regulator...still having sputtering problems under accel between 1-3k.
question 1. what would foul spark plugs do in a working motor?
question 2. what happens when the car has too much backpressure?
and please...no guessing. if you have experienced it, or was involved with the experience...please help. I've changed things that we have already guessed about.
Old 11-22-2010, 03:56 PM   #3466
oilsquirt
oilsquirt is an unknown quantity at this point
Hello, my rod bearings were bad so i bought new ones
My original ones were part number 12118-60J00
They sent me part # 12118-1N500 rod bearings
Will these work?
oilsquirt is offline   Reply With Quote
Old 11-22-2010, 04:18 PM   #3467
Wake
Wake's Avatar
yes
Con rod bearing (US 0.25) Jan 1991 - Aug 1996 #12118-60J00, 12118-1N500
http://zilvia.net/f/tech-talk/110449...nce-guide.html
S.P.P.S. Member #00
Old 11-22-2010, 04:27 PM   #3468
SofaKingFast
Trader Rating: (43)
SofaKingFast is an unknown quantity at this point
Feedback Score: 43 reviews
Send a message via AIM to SofaKingFast
Hey guys, I have a quick question regarding the Circuit Sports braided line kit for my T28 blacktop. I have the water line connected fine for the water feed (fitting closest to the block), but the problem is the water return. The 90 degree fitting fits fine on either the water neck or the turbo side, but the straight fitting doesn't seem to want to fit anywhere. If I try to connect it to the water neck, it hits the power steering pump. If I try to connect it to the turbo side, it hits the wastegate actuator arm. I've seen on some actuators that the arm is bent in that exact location which would solve my problem, but the arm on my turbo is straight. I'm close to starting up my car after 2 months, and this is the only thing left in my way! Thanks for any help guys.
Ryan
SofaKingFast is offline   Reply With Quote
Old 11-22-2010, 07:54 PM   #3469
whippet
whippet is on the path to ruinwhippet is on the path to ruin
Does this exhaust ruin the look of the car?
whippet is offline   Reply With Quote
Old 11-23-2010, 02:54 AM   #3470
kalypso123
(ノಠ益ಠ)ノ彡
I think the wing is the real problem.
QUESTION:
does going super low on coilovers ( collars removed ) require the purchase of suspension arms or will oem arms suffice.
Old 11-23-2010, 05:11 AM   #3471
240sx123$
240sx123$ is an unknown quantity at this point
At the very least you will need a camber kit and rear upper control arms.
240sx123$ is offline   Reply With Quote
Old 11-23-2010, 08:23 AM   #3472
nathanong87
nathanong87's Avatar
RUCAS adjust the camber...
if u are going to go SUPER LOW, u need at least RUCAS and Toe Rods (for the rear to make sure ur alignment is super wacky. changing camber changes toe.
natelife.tumblr.com
Old 11-23-2010, 08:59 AM   #3473
fckillerbee
thicker oil?
too thick...and motor wont start. the guys that have snow...usually change from one viscosity to another depending on weather.
Old 11-23-2010, 09:01 AM   #3474
fckillerbee
car drives though...does it drive different than normal. think you an i may be having a similar problem from what it sounds like.
Old 11-23-2010, 11:48 AM   #3475
240sx123$
In the rear.
And in the front, he'd need a camber kit. Or camber plates on his coils.
Old 11-23-2010, 02:59 PM   #3476
sonomadrifter
Ryan
I think you're talking about an issue I had when I did mine, although I had earls or some other brand. The lines are designed to use a SR PS pump not a KA pump which I am going to assume you have?
I had to buy a 90. Fixed.
Look like this?
Old 11-23-2010, 04:41 PM   #3477
SofaKingFast
Trader Rating: (43)
Look like this?
Thanks for the reply, that's exactly my problem. I'm going to pick up my new fittings today from ANPlumbing.com if anyone else is searching for this I purchased a 90 Deg. Female AN Swivel to Male (-6AN). I didn't realize there was a difference in the design of the PS pumps, as people always said they were interchangeable but I guess not in terms of clearance. Thanks for your help!
Old 11-23-2010, 04:55 PM   #3478
TheEightyNine
Ok, since theres really no issue ill just stick to the standard stuff.
thanks
Old 11-23-2010, 05:20 PM   #3479
kalypso123
(ノಠ益ಠ)ノ彡
sweet, will the front need anything also?
Old 11-23-2010, 07:29 PM   #3480
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Coilover Noob Question (I never adjusted damping settings on Megans):
But uh, on my Fortune Autos, I tried adjusting the dampening using the knobs. And I noticed that y'all use the word "clicks" when you guys are talking about how much you turned the knob.
But when I tried adjusting it, I did not hear any clicks. Are my coils different? Am I supposed to just adjust according to how many spins I put in?
For Sale #1 | For Sale #2
