Old 11-11-2010, 12:29 AM   #3361
jing
jing's Avatar
jing is an unknown quantity at this point
Control unit door mirror
jing is offline   Reply With Quote
Old 11-11-2010, 01:39 AM   #3362
variable
variable is an unknown quantity at this point
oops. too late on my part.
variable is offline   Reply With Quote
Old 11-11-2010, 04:35 AM   #3363
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
what NGK part number is it for SR's with mod do i know its a 7 or something but can someone verify? thanks!
JohnnyDrfiter22 is offline   Reply With Quote
Old 11-11-2010, 06:40 AM   #3364
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
will the ebrake setup from a 300zx just bolt up to my 97 se or do I need 300zx hubs?
dudermagee is offline   Reply With Quote
Old 11-11-2010, 07:17 AM   #3365
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
if it's already 5 lug it'll bolt up.
you'll still have to pull your hub off to put the backplate and drum assy on.
c72c is offline   Reply With Quote
Old 11-11-2010, 09:55 AM   #3366
obsolete
obsolete is an unknown quantity at this point
Anyone know the size and length of the bolt that attaches the a/c bracket to the block on s14 SR20?
obsolete is offline   Reply With Quote
Old 11-11-2010, 11:12 AM   #3367
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Can anybody tell me why my bumper is sagging? And if I'm missing something can anyone let me know what it is and how I can remove the bumper!
For reference here are some old pictures:
EDIT: I was looking at the cars for sale thread and found this, it's from superninjadragon's car.
But is this what my bumper needs? If so, where can I get this?
For Sale #1 | For Sale #2
Old 11-11-2010, 01:19 PM   #3368
JK2005
Trader Rating: (24)
JK2005 is an unknown quantity at this point
Feedback Score: 24 reviews
Its weird. I double check and it gets wired into this and not the fuse box.
JK2005 is offline   Reply With Quote
Old 11-11-2010, 01:29 PM   #3369
hartig
hartig is an unknown quantity at this point
so i got some DMAX 180sx position lights (the ones that are the position lights + turn signals) and i was just wondering where i could get some sockets for the position lights (looks like it should be a 194 bulb in a socket with 3 tabs.
anyways, where could i get one of these? it looks like it should take the light from the corner light.. but i dont wanna get rid of those
hartig is offline   Reply With Quote
Old 11-11-2010, 02:13 PM   #3370
nothix
nothix's Avatar
nothix is an unknown quantity at this point
Originally Posted by nothix View Post
AEM Oil Temp Gauge in an Greddy Oil Filter Sandwich plate.
What adapter do I need to get this to work?
From searching I have found that the AEM is 1/8 NPT (along with 2 other larger adapters) and that the Greddy may be in BSPT.
There are two ports in the Greddy Oil Sandwich that may be used, I'm guessing one is a 1/8 BSPT and the other is larger.
Can anyone confirm, or add to this information? I'm looking for an adapter.
Thanks!
^THIS^ its holding me up!
'89 Sil80, SR20DET, GT2871r .64
nothix is offline   Reply With Quote
Old 11-11-2010, 03:09 PM   #3371
hartig
also, new a new problem has arisen..
my starter wont turn my car on. i took it out to get it tested at advance auto parts, and it works fine.. but when its in my car it just makes one loud clicking noise then does nothing.
i had already removed the clutch switch by the pedal, but back when i had problems with that the starter wouldn't make any noise at all..
any ideas? s13 redtop sr20 by the way
Old 11-11-2010, 04:05 PM   #3372
ki_JDM_ds
ki_JDM_ds's Avatar
Trader Rating: (56)
Feedback Score: 56 reviews
I'm pretty sure it's for the factory security system. When you unlock the car put the key in the ignition the mirrors would open. Maybe the previous owner had it hooked up to work when he unlock/locked his car. Pretty cool though. If you want to get rid of them let me know.
It sounds primitive but... Have you tried tapping the starter with a hammer while it's making that clicking sound? It could be a bit jammed.
ki_JDM_ds is offline   Reply With Quote
Old 11-11-2010, 07:49 PM   #3373
chiboy002
chiboy002 is an unknown quantity at this point
s13 passenger side-marker lamps fit. Go to a junkyard and get them for like 2$ with about 3-4 inches of pigtail left.
street dancer.
GLEAM
Old 11-11-2010, 08:03 PM   #3374
chiboy002
how do i get my NRG hub to sit horizontal when the wheel is sitting right? NRG slim hub (not even verified if its an s13 hub cause it doesnt really sit right) and none of the teeth fit so it sits 100% horizontal. It's been bothering me also... i have a little ocd lol
street dancer.
GLEAM
Old 11-11-2010, 09:55 PM   #3375
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
i have an s13 ka motor head/block im going to be swapping into my s14.
question is will all my s14 components such as intake manifold, dizzy, etc bolt right up.?
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 11-12-2010, 01:25 AM   #3376
c72c
c72c's Avatar
Trader Rating: (25)
I know this sounds a bit obvious, but, is your battery charged?
Old 11-12-2010, 06:04 AM   #3377
hartig
it just clicks once.. then does nothing. when i took it to advance, it worked fine so i doubt it was stuck
my volt gauge says it is
Old 11-12-2010, 06:22 AM   #3378
240sx123$
240sx123$ is an unknown quantity at this point
Battery terminals loose or corroded? If the starter works out of the car but not in it, its either not getting power or not getting enough power. Try running a wire directly from the battery to the starter terminal, and see if that makes a difference.
240sx123$ is offline   Reply With Quote
Old 11-12-2010, 07:11 AM   #3379
obsolete
It's prob ur starter relay by ur pass headligh. Try bypassing it by jumpng it
Old 11-12-2010, 08:08 AM   #3380
c72c
c72c's Avatar
Trader Rating: (25)
also check your power and ground to make sure they're not loose.
check at the battery, the starter, and the chassis.
Old 11-12-2010, 01:05 PM   #3381
udon!
udon! is an unknown quantity at this point
were s13's ever sold in japan with manual windows/locks?
udon! is offline   Reply With Quote
Old 11-12-2010, 02:03 PM   #3382
hartig
well i put the starter back in today.. and tried to start it.. and it works?
problem solved itself i guess
Old 11-12-2010, 02:21 PM   #3383
obsolete
anyone????
Old 11-12-2010, 02:46 PM   #3384
arnrpn
arnrpn is an unknown quantity at this point
Hey guys, i'm having some trouble starting the car randomly, all i get is a click sound when i turn the key, ive changed the starter, battery and checked all the wires so im sure its not any of those, i THINK it may be the main relay as ive heard of this being a similar problem on hondas so my question is:
where is the main relay on a 91 nissan 200sx?
arnrpn is offline   Reply With Quote
Old 11-13-2010, 03:16 PM   #3385
fckillerbee
fckillerbee's Avatar
FUEL PROBLEM
so the past week, i have been noticing that my car has kinda been bogging a little between 1-2k. Now I have a super small exhaust (keep the attention away), and i know back pressure has a factor. But today, I smelled fuel inside my car....and now it's bogging between 1-3k.
Now when I got home, I hear what sounds like bubbling from inside my car. sounds like it's coming from the fuel tank. i even opened my trunk, and it def sounds like its coming from the fuel tank.
an ideas on what this may be? fuel pump going out, and now i'm not getting fuel?
fyi motor has 90k, on a 250k chassis.
Old 11-13-2010, 03:19 PM   #3386
fckillerbee
sometimes you get bad parts. i would check to see if you might have recieved a bad part. get it tested for free. and you have a 200sx?
Old 11-13-2010, 03:24 PM   #3387
fckillerbee
take off your bumper man...does it have a bumper support? if it doesn't....its probably cheaper to get a shop to make you one.
Old 11-14-2010, 01:50 PM   #3388
cole shoes
cole shoes is an unknown quantity at this point
yo guys. i was curious if anyone knew what hood is on dai yoshihara's discount tires s13? also where to find rocket bunny body kits
cole shoes is offline   Reply With Quote
Old 11-14-2010, 02:59 PM   #3389
c72c
c72c's Avatar
Trader Rating: (25)
if you're talking about this one
you're not going to find another like it. It was the hood off their is300. they modified it to fit the 13.
i remember someone posting a link to order the kit, but don't remember where... search this thread or the identify this thread.
Old 11-14-2010, 05:21 PM   #3390
JKL1031
JKL1031 is an unknown quantity at this point
Is it possible to adjust the shift linkage in an s14?
I posted before about going into 2nd before going into first to prevent grinding, but not always. I also have a slight scratch in 3rd. I hear the linkage can be adjusted, and then that its the synchros. Also tonight i figured if i jiggled the shifter and then popped it into 3rd, it wud go right in. Im going to try some amsoil while im ahead.
JKL1031 is offline   Reply With Quote
