Old 11-06-2010, 11:52 AM   #3301
srstan
srstan's Avatar
srstan is an unknown quantity at this point
Originally Posted by jdm2191 View Post
Do KA Single Cam Spark plug wires work on a Dual Cam KA?
no. the single cam has different boots. wont fit the dohc valve cover
srstan is offline   Reply With Quote
Old 11-06-2010, 11:54 AM   #3302
srstan
srstan's Avatar
Originally Posted by sickrbs14 View Post
is s13 sr20s obd1
yes....it only has one o2 sensor
Old 11-06-2010, 12:00 PM   #3303
S14DB
AFC #1
S14DB's Avatar
No
Originally Posted by TheQ View Post
My crank pulley gave out on me today...am looking for a used one off another engine. Do you know if a crank pulley off of any year of KA24DE will work?
91-98 240sx are all the same.
Old 11-06-2010, 01:30 PM   #3304
axiomatik
axiomatik's Avatar
Originally Posted by madd ocx View Post
quick question, are the front lower control arms for the s13 and s14 the same or is there a difference? i heard the s14 arms for are longer, but dont how true it is..
everything I've read says that S14 FLCAs are 10mm longer than S13 ones.
Old 11-07-2010, 01:06 AM   #3305
Urbanfer
Urbanfer is an unknown quantity at this point
Send a message via AIM to Urbanfer
anyone selling a 91 AC bracket w/pulley and belt lmk thanks!
Urbanfer is offline   Reply With Quote
Old 11-07-2010, 01:09 AM   #3306
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
s14 arms have different ball joints than s13.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 11-07-2010, 12:04 PM   #3307
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
ok i was just wonering cause it seems everywhere you look you see s13 control arms selling for like 100 bucks for bth new and s14 be like 200 each.. i wanted to know if there was a difference cause they look the same to me and i heard they are interchangeable.. so you couldn't use the s13 with s14 ball joints?
madd ocx is offline   Reply With Quote
Old 11-07-2010, 12:31 PM   #3308
PNgo12
PNgo12 is an unknown quantity at this point
My rear caliper leaks and when it goes low I just refill the master cylinder. It went low and I filled it but now I've lost all pressure in my brake pedal. I'd have to press it to the floor for it to work. I've been pumping the brakes to get fluid back into the system but the pressure still isn't back. The cylinder worked fine before this. What else can I do to return the pressure?
PNgo12 is offline   Reply With Quote
Old 11-07-2010, 03:59 PM   #3309
nothix
nothix's Avatar
nothix is an unknown quantity at this point
AEM Oil Temp Gauge in an Greddy Oil Filter Sandwich plate.
What adapter do I need to get this to work?
From searching I have found that the AEM is 1/8 NPT (along with 2 other larger adapters) and that the Greddy may be in BSPT.
There are two ports in the Greddy Oil Sandwich that may be used, I'm guessing one is a 1/8 BSPT and the other is larger.
Can anyone confirm, or add to this information? I'm looking for an adapter.
Thanks!
'89 Sil80, SR20DET, GT2871r .64
nothix is offline   Reply With Quote
Old 11-07-2010, 04:00 PM   #3310
nothix
nothix's Avatar
replace or rebuild the leaking caliper.
Old 11-07-2010, 06:03 PM   #3311
singlecamslam
Can someone tell me the thread pattern of the s14 godspeed rucas, the male heim joint part.
Old 11-07-2010, 06:51 PM   #3312
PNgo12
The pressure in my pedal was fine when it was leaking. I go out to drive my car today and I lost all the pressure. It was working fine yesterday. I just need a quick fix to get the pressure back so I can drive to school. Still looking for a new caliper so yeah.
Old 11-07-2010, 08:00 PM   #3313
nothix
nothix's Avatar
you're getting air in the system from the leaking caliper.
Bleed the system real good, but air will get in the system again once you start to use the brakes. Really, there's no temporary solution that I'm aware of.
Old 11-07-2010, 08:22 PM   #3314
Kasilvia88
Kasilvia88 is an unknown quantity at this point
does anyone know where I can get 3 mm brake pad spacers for q45 brake conversion or any information on how to make them. I did a search on google and zilvia and couldnt find the information i need.
Kasilvia88 is offline   Reply With Quote
Old 11-07-2010, 08:51 PM   #3315
I LUV MY S13
I LUV MY S13's Avatar
Ive never heard of spacers being needed.
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 11-07-2010, 09:08 PM   #3316
PNgo12
Hmm.. It's been leaking for a longg time though. Its a really slow leak, the idiot light for the brakes only came on twice since I've had the car and its been about six months. The pedal was fine before this but I'll bleed tomorrow and see how that goes. Since its only the passenger rear would I have to bleed all four corners or just the problem side?
Old 11-08-2010, 06:40 AM   #3317
axiomatik
axiomatik's Avatar
You can use S14 FLCA's in an s13 if you install S13 ball joints into the FLCA.
If it only pulled in air at the caliper, you may be able to just bleed that line. If it pulled in air from the reservoir from the fluid getting too low, you will have to bleed the whole system. Bleed the one corner and see how it feels.
Old 11-08-2010, 07:18 AM   #3318
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
Does anyone make 30mm overs for s14s?! I know I can run a 50 and by how I attach it can be smaller.
HS13KLS is offline   Reply With Quote
Old 11-08-2010, 07:44 AM   #3319
DFWZenki
DFWZenki's Avatar
DFWZenki is an unknown quantity at this point
Originally Posted by s14freak93901 View Post
s13 SR and S14 SR intake manifolds are not interchangeable.
Thanks for the response!! Guess thats why i've never seen it done. lol
DFWZenki is offline   Reply With Quote
Old 11-08-2010, 07:52 AM   #3320
PNgo12
[QUOTE=axiomatik;3722148
If it only pulled in air at the caliper, you may be able to just bleed that line. If it pulled in air from the reservoir from the fluid getting too low, you will have to bleed the whole system. Bleed the one corner and see how it feels.[/QUOTE]
Lucky me its the side you start out with first when you bleed the whole system. I'll do that today when I get home from school and update. Thanks.
Old 11-08-2010, 10:24 AM   #3321
S14DB
AFC #1
S14DB's Avatar
S14's are longer.
Old 11-08-2010, 01:07 PM   #3322
nothix
nothix's Avatar
Thanks!
Auto Meter 2269 - Auto Meter Metric Adapters - Overview - SummitRacing.com
will this part work???
Old 11-08-2010, 01:09 PM   #3323
funes
funes is an unknown quantity at this point
Hi all, Does anyone knows if the rocker cover bolts that goes in the center are all the same in all KA24DE engines or only are the same in the 240sx's
i know the s13 has 3 bolts in this place on the rocker cover and the s14 has 2 bolts
funes is offline   Reply With Quote
Old 11-09-2010, 03:29 AM   #3324
ayuaddict
ayuaddict's Avatar
What is a good website to purchase HIDs?
Old 11-09-2010, 09:58 AM   #3325
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Can you weld coilovers in the gas chamber region? Or will the gas combust from the heat?
jacobs13 is offline   Reply With Quote
Old 11-09-2010, 10:45 AM   #3326
S14DB
AFC #1
S14DB's Avatar
Real HIDs or PnP kits?
Old 11-09-2010, 11:00 AM   #3327
MANOlOS14
MANOlOS14's Avatar
MANOlOS14 is an unknown quantity at this point
what size are stock ka dual cam injectors? i know stock sr are 370cc
MANOlOS14 is offline   Reply With Quote
Old 11-09-2010, 11:39 AM   #3328
S14DB
AFC #1
S14DB's Avatar
270 cc
Old 11-09-2010, 11:50 AM   #3329
axiomatik
axiomatik's Avatar
gas-charged shocks usually use nitrogen, so it won't combust, but super heating the gas will likely make it rupture violently. pV=nRT
Old 11-09-2010, 01:24 PM   #3330
willievo
willievo's Avatar
willievo is an unknown quantity at this point
Send a message via Yahoo to willievo
how bad is this damage?
no it doesnt affect the way i drive for those who ask
does any one know a shop that repair this?
My Daily Driver
willievo is offline   Reply With Quote
