Old 06-25-2012, 10:52 AM   #301
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
Just curious would it be a big deal if the bung that is placed on the rear of the Valve Cover Goes to the CrankCase and then the Middle part goes to the Turbo Intake Piping. I'm just thinking for a cleaner hose routing option and since this is how its done on the S14/S15 SR anways. Thanks!
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 06-25-2012, 11:10 AM   #302
slider2828
slider2828's Avatar
It would... cause that side bung, is on the side, as you turn a corner like all right hand turns, the oil would spill over.... it takes considerable pressure to pull oil through the top blow hole (whale reference hahaha)...
But you can make it clean like on page 10
Turn and Burn!
Old 06-25-2012, 11:21 AM   #303
GroundPerformance
Trader Rating: (44)
It make sense now. THanks!
Old 06-26-2012, 06:30 AM   #304
benson93
benson93 is an unknown quantity at this point
Originally Posted by hOngsterr View Post
hey what hoses do you guys use that can stand the heat, heater hoses that are used for coolant? or would PS hoses work, fuel wont work, they become hard and brittle.
Also, benson, from looking at your pics, you didnt need to weld? And the best way to get metered air is from the maf piping?
Hay Mate,
Hoses I used (Black ones) are high pressure oil hosed from hydraulic suppler here in Australia (Pertik) more than suitable for the job. and like 'slider' said I needed the heat sleeve above the manifold as no pipe I could find was standing up to the temps above it, even now the orange bit is starting to decay (rated at above 1000c) also quite expensive. approx $70 for the pipe.
Yea I didn't weld I taped the hole in the top rocker and used a threaded 3/8th elbow with rubber washers for a good seal, also taped a 3/8th fitting into the intake (pain in the ass stainless) pipe also with a thick rubber washer for a good seal. On the 't' I used a epoxy 'steel' clay to block the front outlet.
Cheers
benson93 is offline   Reply With Quote
Old 06-26-2012, 09:45 AM   #305
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
ahhh i see, even cheaper alternative haha.
thanks for the reply!
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 06-26-2012, 10:23 AM   #306
slider2828
slider2828's Avatar
You can get a good seal with JB Weld as well... on the intake, but on the valve cover you gotta tap that with threads, believe or not, there is a lot of pressure that is build up in there....
Turn and Burn!
Old 07-22-2012, 03:32 PM   #307
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
So I'm in the process of doing this myself and my question is this. Will -10 ss braided hose fit on the factory oil return? The oem tube at the back of the engine under the exhaust manifold is what I'm talking about.
ForeignMuscle is offline   Reply With Quote
Old 07-23-2012, 09:48 AM   #308
slider2828
slider2828's Avatar
Sorry dunno about an's just measure it....
Turn and Burn!
Old 07-23-2012, 11:17 AM   #309
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I guess I could give an update. No matter what I did to the catch can I had massive blow by. Compression is good, didn't make sense.
I pulled the valve cover a bit ago and found the drivers side oil squirter, BROKE. Was squirting oil right at the baffle.
WTF, dunno how that broke, but replaced it and no more oil in the can.
di-devol is offline   Reply With Quote
Old 07-23-2012, 11:17 AM   #310
ForeignMuscle
How do you not know?? How do you have the stainless steel braided hose hooked up at the crankcase return? Ya'll are using -10an fittings to replace the T in all the photos I have seen, therefore, the hose going down to the oem crankcase return tube is -10. Does it fit on the tube, or do you modify it somehow? Anyone?
Old 07-23-2012, 11:30 AM   #311
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
The -10 male fitting in the stock location has a 90 deg -10 push lock fitting attached. Then -10 push lock hose goes from there down to the oem crank case breather tube.
so yeah i guess it does fit....
- Hong
Old 07-23-2012, 11:38 AM   #312
ForeignMuscle
I'm not using push lok so I figured the ss braided line might have a smaller i.d. than rubber hose so I asked. Thanks
Old 07-23-2012, 12:08 PM   #313
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
i made one out of .exhaust pipe , huge freeze plug ,and a outboard piston turned down in a lathe!
blessedhellrider is offline   Reply With Quote
Old 07-23-2012, 01:12 PM   #314
slider2828
slider2828's Avatar
I am not using AN lines. You don't HAVE to use AN lines. Therefore I don't know.....
Don't get so mad.... geez....
Turn and Burn!
Old 07-23-2012, 01:15 PM   #315
slider2828
slider2828's Avatar
Yeah that is soooooo weird.... and to squirt into the baffle.... did the cams get damaged or anything?
Turn and Burn!
Old 07-23-2012, 05:20 PM   #316
ForeignMuscle
Haha not mad bud. Just got confused.
Old 07-23-2012, 07:24 PM   #317
Almasxxx
Almasxxx is an unknown quantity at this point
Guys whats the true installation to my car ?
i think my is do wrong installation
Almasxxx is offline   Reply With Quote
Old 07-23-2012, 11:25 PM   #318
ForeignMuscle
S14 valve cover doesn't benefit from this. It's fine from the factory. Hoses look to be routed fine.
Old 07-23-2012, 11:50 PM   #319
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
almasxxx-that hose coming off your side eport on your valve cover looks to be routed down to your intake piping right before your turbo. If so, it needs to go to your catch can, then to your intake piping. Read the thread and you will find the answer and pics many times over.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 07-24-2012, 02:29 PM   #320
Almasxxx
everything ok guys ?
Old 07-24-2012, 02:50 PM   #321
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Your intake is sucking in un-metered air through the valve cover from the vented catch can and the open PCV valve port.
Speaking of the PCV valve, what would happen if one replaced it with a regular straight-through fitting and tee'd it into the hose going from the crankcase vent to the valve cover?
It seems that would simplify the system, so both sides could be vented through one catch can.
And I assume not having the PCV valve would be beneficial, since it closes under boost, which is when the crankcase is most pressurized.
Old 07-24-2012, 03:04 PM   #322
slider2828
slider2828's Avatar
Almas.... I wouldn't hook it up that way....
It should be crankcase -> valve cover -> front valve cover -> CLOSED catchcan -> intake...
Make sure its closed system else its useless, you are not drawing vacuum from the head and bottom end
Send me some lovanjoel.... hahaha... Just saw some No Reservation Anthony Bourdain in Turkey!
Didn't know you guys speak english that well over there!
Turn and Burn!
Old 07-24-2012, 03:07 PM   #323
slider2828
slider2828's Avatar
Under accel the pcv valve should be closed. Block off intake port that was connected to pcv. Then pipe the pcv to the catch can....
Should be best....
Turn and Burn!
Old 07-24-2012, 03:24 PM   #324
Almasxxx
okey dude re build system but question whats the diffrence for your say easy way
and other question
can i close this hole ? turbo side ? or out put catch tank to it here ?
Old 07-24-2012, 05:21 PM   #325
slider2828
slider2828's Avatar
You need vacuum from the turbo, so do not close that hole.....
Turn and Burn!
Old 07-24-2012, 05:50 PM   #326
nismolvr
nismolvr's Avatar
nismolvr is an unknown quantity at this point
Originally Posted by simplistek View Post
just add one of these.
the better S14 baffling on an S13 SR.
anyone who is serious about eliminating their catch can from filling up with oil quickly. Should do this Mod. I have a blacktop sr20det , I fn hated blow by, and i hate the red/blacktop valve cover it is a poor design. the baffles are crap. I did some research. I purchased an s14 sr20 notchback. I fabricated one valve cover from both, using Front of red/blacktop valve cover and welding notch back valve cover. The s15 valve cover will not work with s13 coils. My Oil catch can has remained dry and I no longer have oil in my intercooler...The PCV can only do so much and its not enough to relieve crank case pressure.Catch cans will help but you still need to empty them . Do this Mod and your problem will go away!.
S13.4 Hybrid Valve Cover – Crisco! | Touge Factory
nismolvr is offline   Reply With Quote
Old 07-24-2012, 05:53 PM   #327
nismolvr
nismolvr's Avatar
and other question
Thats the incorrect way , You will fill your intercooler with oil that way!
Old 07-24-2012, 05:59 PM   #328
nismolvr
nismolvr's Avatar
NO! route the crank case pipe to the back of your valve cover first.
Then hook up the front valve cover pipe to one side of your catch can , Then hook other end to turbo inlet.
Old 07-24-2012, 07:48 PM   #329
Matej
Trader Rating: (39)
Should be best....
To be specific, I ended up getting an S14 valve cover to have it made into the S13.4 hybrid cover, since plenty people are willing to do the mod for an affordable price nowadays.
Here is what I had in mind. Please let me know if it would have any negative effects.
Also, I noticed that even though the valve cover fittings are for a 5/8" hose, the openings in the valve cover are actually only about 10mm in diameter. Would it be of any benefit to drill them out larger, or is the 10mm enough?
Old 07-24-2012, 10:18 PM   #330
slider2828
slider2828's Avatar
Hey Matej. I would put the pcv to the greatest vacuum source which is the intake/catchcan... To tell you the truth, so you can pull as much vacuum as possible. T'ing pretty much always reduce flows for any fluid and gases. So no T, but to catch can....
I think 10mm is large enough because might start pulling in oil if any bigger....
Turn and Burn!
