Old 04-13-2014, 09:11 PM   #3061
meoww
meoww is an unknown quantity at this point
have a stock 89 s13 what is the best offset for a 17? what is the best width for the wheels? thanks!!
meoww is offline   Reply With Quote
Old 04-13-2014, 11:22 PM   #3062
Nikzilla
Nikzilla is an unknown quantity at this point
I want to get MB Battles 17x9.5 +15 with 235/40/17 for my S13
From what people say it will fit with a roll. But according to this, the new wheel setup will actually be smaller in diameter than stock.
Is this right?
Nikzilla is offline   Reply With Quote
Old 04-14-2014, 02:33 PM   #3063
jameswouldgo
jameswouldgo's Avatar
jameswouldgo is an unknown quantity at this point
Originally Posted by fliprayzin240sx View Post
All personal preference. I'm running similar specs on my current Work Equips (18x10 +2 effectively/10.5 +10) and I'm on 225/40 fronts, 235/40 rears.
Are you rocking spacers? I got a z32 brake kit and wondering if the fronts will fit without spacers.
jameswouldgo is offline   Reply With Quote
Old 04-14-2014, 02:46 PM   #3064
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
17x10 -20 in the rear of an s13 coupe. What size overfenders do you guys suggest? 30mm?
e30gangsta is offline   Reply With Quote
Old 04-14-2014, 05:36 PM   #3065
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yes, thats why I said effective. I'm running 20mm spacers but realistically, only needed like 9-10mm to clear. Kicker is, it's a Work Wheel, they have different faces for brake clearances. I've had a set of Equips that didn't need spacers and cleared my R32/Z32 brakes up front. Do you know what type face you have? O-disk, A-disk and R-disk?
CLICK HERE!!!
Old 04-14-2014, 05:38 PM   #3066
fliprayzin240sx
50mm, gives you more room just in case you decide to run meatier tires. Plus you can bow the fenders in and out to make it fit like a 30mm or even a 60mm depending on how thin the fiberglass is.
CLICK HERE!!!
Old 04-15-2014, 12:11 AM   #3067
jameswouldgo
No I am not sure what type of disk I got. I tried to get it fitted today the rears were perfect, and now installed. But the fronts couldn't clear the calipers, do you think a 10mm spacer would do the job? The shop was also saying I would need longer bolts.
Old 04-15-2014, 06:48 AM   #3068
I'm Redline
I'm Redline's Avatar
According to Allen, you can make them all fit, but the A-Disc, and R-Disc work the best with s-chassis bigger brakes. It's like if you want to do work, or not do work, it still comes down to personal fitment and how much poke, camber, pull, you want to set up. Me, I like the way a 90mm lip looks and a no spacer, no brainer fitment so A-Disc in a 17x9+15 is the way to go. Rock just a slight camber, roll the lips, and done...at least all 'on paper'
My work in progress...
Old 04-15-2014, 08:28 AM   #3069
FLG
FLG's Avatar
FLG is an unknown quantity at this point
I run 9.5" all around with a 35 positive offset (XXR 962)
I need 8mm spacers in the front because my offset makes the wheel rub the strut.
255 wheel in the rear 225 in the front.
FLG is offline   Reply With Quote
Old 04-15-2014, 01:26 PM   #3070
cody_sir
cody_sir is an unknown quantity at this point
did you need to do a pull up front to make it fit? Whats your camber?
cody_sir is offline   Reply With Quote
Old 04-15-2014, 05:47 PM   #3071
fliprayzin240sx
Again, all depends on what the face is. Could be anywhere from 7mm to as much as 13mm from my experience. Yes, you'd need longer studs, 6mm slip on spacers are the most I'm willing to use on the stock studs. Anything more than that is butt pucker factor when I hit a pot hole or track the car goes up.
I'm running roughly 3* up front. If you roll the front fenders on an S-chassis, you're pretty much pulling it at the same time. S14s will take 10js up front with no issue, may have some rubbing issue at full lock, but nothing a big ass hammer can handle. S13s, I wouldnt run anything wider or bigger than a 17x9.5j. Damn wheel well is just freaking tiny compared to S14s.
CLICK HERE!!!
Old 04-15-2014, 10:26 PM   #3072
jameswouldgo
So I ordered some Ichiba spacers 15mm. Would these extended wheel studs do the trick? Thanks for the help bro.
http://www.ebay.com/itm/10x-ICHIBA-5...181265&vxp=mtr
Old 04-15-2014, 10:31 PM   #3073
jameswouldgo
Nvm I believe the kit I got comes with extended wheel studs.
http://www.ebay.com/itm/360482414700...84.m1497.l2649
Old 04-16-2014, 02:03 AM   #3074
fliprayzin240sx
All a matter of preference, I run Nismo extended studs on my car. Has been running these studs for over 7 yrs now.
Not a fan of bolt on spacers since you'd have to check the inside lugs ever so often to make sure they're still torqued in. Also, depending on the face of the wheel pad, if its not hollow out, the stock studs could stick out pass the spacer and not let the wheels sit flush to the hub.
CLICK HERE!!!
Old 04-16-2014, 02:38 AM   #3075
TheRealSy90
TheRealSy90's Avatar
17x11 +6 on the rear of s13 coupe. What size overs would I need to run 0 camber, with what size tire, for a decent stretch. Tried to mount 205/45's and couldn't bead all the way... I'm guessing 50mm overs, but I can't decide on tire size.
Such a good signature.
Old 04-16-2014, 01:53 PM   #3076
cody_sir
I will be purchasing some weds lxz for my s14... Sizes will be 18x10.5 and 9.5 with a 225/40 rear and 215/40 front. I only want to roll not pull. My question is can I do this with a +3 offset front and rear or should I go a little higher offset? It doesn't bother me if I need to run more camber. Thanks in advance
Old 04-16-2014, 08:31 PM   #3077
fliprayzin240sx
Really? 205s on 11js? 11j ~ 280mm. You're trying to stretch those tires by 3"...
Go 50mm fenders, then go 245/40-17s. Trust me, that shit will still be stretched. 265s looked stretched on my set of 11j Equips.
If you really dont want a pull, I'd shoot for those sizes in the +20 to +25 range. Itll be pretty conservative.
It'll never look flush with out pulling the fenders. When you flatten the lips flat, that not a roll, you've pretty much pull the fenders some without you realizing it if you got the lips flat.
I say flatten the lips, give the rears a slight pull and I would go 18x9.5 +0 81mm lips FF Disk up front to clear BBKs and 18x10.5 +12 93mm WS-Lo FR Disk in the rears
CLICK HERE!!!
Old 04-16-2014, 08:55 PM   #3078
TheRealSy90
Yeah it didn't work lol. I'll have to try 245/40's on the back. What about the front 10j's? Maybe a 235/35?
Old 04-17-2014, 09:31 AM   #3079
fliprayzin240sx
235/40-17, maybe even 225/40-17 if you can find it for the 10j upfront.
CLICK HERE!!!
Old 04-17-2014, 04:51 PM   #3080
cody_sir
thats exactly what im going to do... did more research seems like the best option
Old 04-18-2014, 12:42 AM   #3081
juhd
juhd is an unknown quantity at this point
how to tuck 18x9.5 +12s in the rear of an s13? need a pull?
juhd is offline   Reply With Quote
Old 04-18-2014, 01:26 AM   #3082
fliprayzin240sx
Camber and stretch...you'd pull if you want to run less camber. Kicker is, you can only pull so much until all you're really doing is flattening the inner fender flat.
CLICK HERE!!!
Old 04-18-2014, 07:55 AM   #3083
shift_down
shift_down is an unknown quantity at this point
I have an S13 hatch with coilovers and complete aftermarket adjustable arms
I have 17X9 +10 wheels
The front fenders are +30mm
I am planning on running +30mm in back
I am planning on buying Sumitomo HTR Z III Tires
Should I run a 245/40/17 or 245/45/17 up front?
Should I run a 275/40/17 in back?
I am looking to get good fitment with the least amount of negative camber, and I am wanting around 275 width in back
I have been looking here: http://zilvia.net/f/showthread.php?t=166563&page=16 but cant find much on s13s
Any input?
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
shift_down is offline   Reply With Quote
Old 04-18-2014, 03:03 PM   #3084
fliprayzin240sx
All up to you, matter of personal preference. Personally, I wouldnt run 275mm wide tires on 9j since itll look like beach balls. The tires will roll over the side cuz its wider than the rim. 9" equates to roughly 230mm.
Personally, I'd go 225/45-17 or 235/40-17 up front and 255/40-17 in the rear max.
CLICK HERE!!!
Old 04-23-2014, 08:15 AM   #3085
ThrasherS13
ThrasherS13's Avatar
ThrasherS13 is an unknown quantity at this point
hope this helps some of you guys alittle.
suspension:
Tein super drift series coil-overs
circuit sport ruca's
circuit sport rlca
circuit sport front control arms
circuit sport rear traction arms
isis front tension rods
wheels & tires:
17x10j +15 str 526 "grids" front and back "NO SPACERS" and about -2.5 camber
(fronts) velozza 215-40-17
(back) nankang ns-20 215-40-17
ThrasherS13 is offline   Reply With Quote
Old 04-23-2014, 08:26 AM   #3086
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
No it doesn't help.Without offsets its virually useless.
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 04-23-2014, 09:47 AM   #3087
shift_down
Thank you. I ordered 235s up front and 255s in back. I will post pics when I mount them.
Old 04-23-2014, 10:14 AM   #3088
ThrasherS13
sorry man, I'm a noob!!! they are 17x10 +15
its been edited and thanks for bringing that to my attention.
Old 04-25-2014, 10:30 AM   #3089
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
Need some opinions guys .I have a stock s13 coupe . has fortune auto coilovers already . I'll be buying some gramlights 57dr soon just can't decide on the sizing . I've looked at some examples but would a 18x9.5+12 rub at full lock? Or should I do 17x9+12 to be safe. . now for the rear its either 18x9.5+12 or 10.5+22. Want to keep it stock bodied with just a little roll or pull getting rid of all the wheel gap. Any info or inputs would be greatly appreciated guys .
Vicious Beaner! is offline   Reply With Quote
Old 04-25-2014, 12:15 PM   #3090
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
^^^you can do 18x9.5+12 with a 215/35 dont rub on front and in the back i have 10.5+22 with 235-40 no rubbing but you have to do a roll and pull in both ...hope that helps
