Old 05-07-2013, 06:16 PM   #271
N2HIFI
N2HIFI is an unknown quantity at this point
3500 is pushing it in reality, I have about 5k in mine between header and exhaust work and all the swap parts... But mines done WAAAY different then everybody else's
Here is my swap
N2HIFI is offline   Reply With Quote
Old 05-13-2013, 08:29 AM   #272
ka-titties
ka-titties is an unknown quantity at this point
what's so different?? more purple?
you can do it for 3500 if you can do things yourself like make mounts and exhaust work. i have under $2k into mine but i built my own mounts, built my own exhaust, and did all my own wiring.
ka-titties is offline   Reply With Quote
Old 05-13-2013, 10:42 AM   #273
DEMo
DEMo is an unknown quantity at this point
My swap breakdown
VQ Motor Set: $1750
Mounts: $60 in material
Shifter: Cut and weld
Driveshaft: VQ35 Pathfinder, Xterra, Frontier Driveshaft
~$45 and have it extended to correct length ~$150 ($200)
Uprev License: $200 + shipping (call uprev tuners and ask for a deal!)
Wiring: 4 hours of thinking, 1 hour of soldering.
Gas Pedal + OBD2 + 350z engine bay harness ($170)
Gauge Cluster setup: Google Nexus 7" tablet + OBD2 bluetooth dongle = Live engine vitals (minus speedometer)($250)
Fuel gauge $40
Fuel Setup Used old tomei FPR with tomei adapters ($100)
Instagram: @hexagarage for VQ S Chassis Parts
DEMo is offline   Reply With Quote
Old 05-16-2013, 03:13 PM   #274
N2HIFI
Cute
no i just did things differently then what i see most people doing for their VQ swaps
motor: 2000 (first motor had a issue and had to buy a 2nd long block)
mounts: 300 (McKinney replicas ebay)
Shifter bracket: 200 (ebay)
Driveshaft: 410 (raw brokerage)
Clutch n flywheel: 450 (competition stage 4 clutch and ultralight flywheel)
Gas pedal and obd 2 port: 200 (bought a box of wiring which included the needed parts)
Osiris ecu flash n tune: 350 (from Z1 motorsports)
Sohc PS lines and resivor: 40 (junkyard)
FPR and gauge: 90 (Fuel labs n marshall)
Stainless fuel lines and AN's and rail adaptor: 270 (earls, jegs racing and ebay)
Headers and modification to fit: 500 (megan racing 350z headers then rebuilt to fit my s14 and clear everything via local fab shop)
Stainless steel clutch line: 45 (ebay)
Z33 slave cylinder: 35 (part store)
Tach: 140 (autometer in dash tach and digital tach adapter)
Gauges: 200 (auto meter oil,water gauges with block adapters)
Coolant crossover pipes to work with my radiator: 100 (local fab shop)
misc nissan nuts, bolts, gaskets and belts: 300 (oem nissan)
Custom Y pipe with cat for single exhaust exit: 300 (local fab shop)
Blox intake spacer: 100 (ebay)
Intake pipe and Blox flow stack: 100 ( ebay n zilvia)
All new motor hoses: 250 (OEM nissan)
actually this list is $6380.. and that does not count i wired my harness myself, fluids and probably another 2-300 in misc things like random hoses, nuts n bolts and different things i needed to get it all together.
Im not saying i did things WAAAY different .. i just spent my money differently is more of a accurate statement
