08-15-2020, 04:54 PM | #1 |
Sr20 breaking up under load
My sr20de plus t will free revv fine but as soon as it sees load and boost it will break up heaps and cough and splutter. I have changed plugs multiple times have had coils tested and came up okay (although sometimes it doesnt mean anything as they arent tested when hot etc) i have also done a new coil loom and had injectors cleaned. Still has the same problem. Will likely source some different coils and see if that fixes it but has anyone got any other ideas?
08-15-2020, 05:14 PM | #4 |
I had this problem. For me, it was the coilpacks. At first , I wrapped them with electrical tape, which helped. The old coil packs can arc to the valve cover. I am now running qr25de coil packs, and wrapped for extra measure. The car starts so much easier, and runs smoother
Sent from my SM-N910V using Tapatalk |
08-15-2020, 06:52 PM | #5 |
08-15-2020, 06:52 PM | #6 | |
08-16-2020, 10:30 AM | #9 |
^that
Mine was a Tial so it was the mechanical spring weight blowing open connected or disconnected. I had to change the spring to a heavier one to fix it. Figured it out by removing it and wrapping the pipe with ductape for a test run. Definitly dirty but it works |
breaking up, missing, s14, silvia, sr20 |
