Old 10-08-2019, 05:38 PM   #31
BenRice
BenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura aboutBenRice has a spectacular aura about
So close!!!
Agree about removing the CAS and spinning it to see if the injectors click, but before that just try cleaning the contacts on the CAS plug first. Remember, the CAS plug needs to push on reasonable hard and clicks when fully seated (if the plug isn't broken)
If the plug contacts are cleaned & the injectors click when the CAS is spun, it may be worth pulling injectors to see if they're wet or dry.
If they're wet, and seeing as though it's not a stock harness, are you 100% the injector plugs are plugged into the right injectors?
BenRice is offline   Reply With Quote
Old 10-08-2019, 05:41 PM   #32
BenRice
Oh and when you want to post another photo, click the Image icon and enter the Direct Link url when prompted and it will embed
Like this:
Old 10-08-2019, 05:48 PM   #33
NoBrakes!
NoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the roughNoBrakes! is a jewel in the rough
Ok so when i go back after work ill do the test light and check with the cas then update. I also forgot to mention that unplugging the cas had no change at all. So if i take that piece out and spin the shaft on it i can hear clicking where injection is supposed to occur via clicking or when someone is cranking the motor?
Natural selections finest
NoBrakes! is offline   Reply With Quote
Old 10-08-2019, 05:53 PM   #34
S14rebuild
Unbolt the cas from the engine, leave it plugged into the harness.... turn key to ignition on(not cranking) and turn the cas. U should here injector clicking as u spin the cas.
But to 100% verify, use the test light or noid light. Hook test light to 12volt postive and test the negative pin on the injector. While turn the cas by hand....u should see the test light flash. (Can do the same test with cas plugged in and bolted down on engine, just crank the engine over)
Were testing to see if the injector is getting its ground from the computer.
Cas send signal to ecu on engine postion while turning...computer takes that signal...knows when to fire each injector and then grounds out that circuit and the fuel injector fires.
So u have fuel pressure, so were now focused on fuel spraying into the cylinder.
Old 10-08-2019, 05:54 PM   #35
S14rebuild
Looking at a -
faulty cas(not likely cause u have spark)
Ecu (again not likely very random to have 6 bad injector drivers bad)
Wiring issue
But lets do the tests stated abouve first.
Old 10-08-2019, 06:06 PM   #36
NoBrakes!
Originally Posted by S14rebuild View Post
Looking at a -
Wiring issue
Oh ok cool will definitely update
Would it be a wiring issue through the wiring specialties harness? It is brand new freshly made.
I was also told i could have the lines swapped on the chassis end so ill probably pull em to see which one sprays fuel when i prime the pump just to confirm completely.
Old 10-08-2019, 06:07 PM   #37
S14rebuild
No need to check that u got 40psi...ur good on the fuel lines
Old 10-08-2019, 06:15 PM   #38
NoBrakes!
Okay, and it couldnt be the fuel quality either?
Old 10-08-2019, 06:17 PM   #39
S14rebuild
Well lets make sure the injectors are acually putting the gas in the cylinder.
It could be gas quality.
Old 10-08-2019, 06:20 PM   #40
NoBrakes!
Originally Posted by BenRice View Post
So close!!!
Fingers crossed then, im pretty sure there in the right ones since they are numbered on the harness i cant remember while im away but thats a easy check. Cyl 1 is furthest to the front right
Old 10-08-2019, 06:23 PM   #41
S14rebuild
Cylinder #1 is the injector towards the front of the engine
Like this
Firewall
6
5
4
3
2
1
Radiator
Old 10-09-2019, 12:42 AM   #42
NoBrakes!
So i got out of work extremely late and still went to test the injectors with a test light but i didnt do that second test ill have to wait till wednsday night or Thursday due to me being out of town. However
Hooked the test light up to 12v from the battery (keep in mind this is a incandescent bulb test light not a led). Touching the light to the ground side caused the test light to light up in the on position same for the power wire. Touching the ground while cranking caused the test light not to shine at all and that was for both sides (power and ground)
Old 10-09-2019, 12:43 AM   #43
NoBrakes!
Like this
Firewall
6
5
4
3
2
1
Radiator
Also the injectors are in the right order
Old 10-09-2019, 05:06 AM   #44
S14rebuild
Injector should have.... 1 wire(+constant) key on/cranking/running(this is power feed wire, from a relay)
1 wire(-pulsing) cranking/running(this is grounding wire from ecu)
Test the injector connector for these with it unplugged from the injector
Old 10-09-2019, 07:49 AM   #45
NoBrakes!
Yea the white wire on them seems to be the 12v constant ill have to check the black one again when i return and update.
You can tell ive never done something this involved on a car lol. But is it possible to pull the injector leave it connected and see if it clicks or something? Similar to visually confirming spark. I kno i can do that if i pull the whole rail but with the stock plenem and everything kinda wanna avoid it.
Old 10-09-2019, 08:04 AM   #46
S14rebuild
Yea, no need to pull the rail these test will confirm all we need to know. Were heading in the eight direction with this. U have fuel pressure, so we know fuel is flowing theu the rail. Now were working on getn the injectors to open so fuel can spray out.
Check those wires and will go from there
Old 10-09-2019, 03:26 PM   #47
BenRice
Probably worth mentioning all you're doing is unplugging the harness's injector plug on cylinder 1 and measuring the voltage from those pins
Leave the injectors themselves in the rail and on the car
Also, incandescent bulbs aren't the best as test lights - i used one to measure VCT and thought it wouldn't light up. Grab a proper test light from an auto parts store, they cost peanuts
Old 10-09-2019, 03:55 PM   #48
S14rebuild
Hes using an incandescent bulb test light...not just a bulb with wires
What hes using will work fine for these tests
Old 10-10-2019, 07:47 AM   #49
NoBrakes!
Just tested key on
White wire 12v
Black wire 12v
Both at the unplugged connector
Is something powered that should be grounded?
Old 10-10-2019, 07:50 AM   #50
S14rebuild
White white should have 12v key on
Black should have pulsing ground while cranking/running
Is this the same reault for all 6 injector connectors?
Old 10-10-2019, 07:52 AM   #51
NoBrakes!
Its the same for 1 and 2
Old 10-10-2019, 08:04 AM   #52
S14rebuild
This is a brand new harness?
Weird.... either the computers bad or u have all injector wires shorted to power.
Power flow goes
Power(+) relay---injector---computer(-)
Thats it
Old 10-10-2019, 08:08 AM   #53
NoBrakes!
Power flow goes
Thats it
Printed ecu pinout gonna test injector grounds. It a brand new harnes from them so if thats it imma be pissed i waited forever for this thing
Old 10-10-2019, 08:49 AM   #54
S14rebuild
Yea i def check the grounds.....id find it very odd that all 6 injectors ground wires are shorted though
Old 10-10-2019, 09:26 AM   #55
NoBrakes!
Checked all ecu pins and they have ground so im completely confused ground at the ecu power at the injectors all thats in between is wiring from the harness nothing left to test. I emailed wiring specialties imma see what they say. Garenteed to not be in the show now
Old 10-10-2019, 10:03 AM   #56
S14rebuild
Check continuity between the injector ground pin and its corresponding pin at the ecu.
Old 10-10-2019, 10:32 AM   #57
NoBrakes!
-12v on all im thinking they are all opened somewhere ground side so power just skips the injectors and goes to the open
Old 10-10-2019, 10:36 AM   #58
S14rebuild
There suppose to me open circuit till the ecu grounds it.
Old 10-10-2019, 10:37 AM   #59
S14rebuild
With engine crankn, are u getting ground pulse at the ecu for injector #1
Old 10-10-2019, 10:41 AM   #60
S14rebuild
Pin 107 108 116 shows grounds for injectors
Check for with ley on and whike cranking
https://www.google.com/search?q=rb20...wqHeD4b7tugtvM
no idle, rb20, rb20det, s14, swap
